Anyone tried this part?
I was doing an install in a friends CRV today. I routed the wires all clean and everything but happened to look online and found this thing:
http://www.partsexpress.com/pe/showd...number=071-580
I was looking for an alternate source, so she would still have her single 12V adapter available for ipod, etc.
This tutorial turned me on to that part:
http://www.xmfan.com/viewtopic.php?t=45962
"I used the Littlefuse adapter to run a new circuit for the power over from the fuse box....I really wish I had done my car this way instead of splicing off the nearest outlet. I didn't have to alter anything in the car, and there's no addtional draw on any of the original fuses. I stuck the adapter in spot #4, because the instructions said not to replace a fuse higher than 10 amps, and it was the most conveniently located one that switched on and off with the key. I ran the red wire of the Radio Shack outlet from the cubby to down near the fuse box and crimped them together. Another few zip-ties kept it all out of sight behind the dash. I grounded the black wire to the screw on the left-hand side of the cubby. Once I plugged in the 3V adapter that came with the Roady, I stashed the whole thing in some of the empty space under the cubby."
