Old 05-21-2008, 11:17 AM #1
gkatmar's Avatar
gkatmar gkatmar is offline
gkatmar is on a distinguished road
gkatmar's Avatar
Need help installing line converter for aftermarket amplifier
I need some help installing a line converter for an aftermarket amplifier for a new subwoofer. I remember seeing this a while back but I can't find it anywhere. Does anyone know what the color of the wires and which ones are neg and post that go to the JBL Sub.
2003 SR5 V8 4x4 - Black with tan interior (SOLD)
2007 Tundra SRF - White (SOLD)
2007 Sport V8 4x4 - Silver (SOLD)
2014 4Runner Limited 4x4 - White
gkatmar is offline   Reply With QuoteReply With Quote
Old 06-03-2008, 03:28 PM #2
Run4urLife's Avatar
Run4urLife Run4urLife is offline
Run4urLife is an unknown quantity at this point
Run4urLife's Avatar
Did you get this figured out yet? I might could help if you explain your question a little more clearly.
still rollin
Run4urLife is offline   Reply With QuoteReply With Quote
Old 06-22-2008, 02:15 PM #3
gkatmar's Avatar
gkatmar's Avatar
Well I removed the JbL sub and there are 4 wires. A green, yellow, black, and orange. I'm not sure which ones are positive and negative and left and right?
Old 06-22-2008, 02:48 PM #4
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
This is a dual voice coil subwoofer. Use an ohmeter to find continuity for each pair of wires. To find out which is positive take a 9 volt battery and using clip leads touch the battery to each voice coil while watching the speaker cone. It will either move in or out each time you touch it with the battery. Positive is when the cone moves toward you. Do this again for the other coil so they will be in phase when you hook them up. By the way this is a mono set up intended for two amps which use the same signal.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 06-22-2008, 03:26 PM #5
gkatmar's Avatar
gkatmar's Avatar
How do I figure out which one is left and right
Old 06-22-2008, 03:38 PM #6
drmorbius's Avatar
drmorbius's Avatar
There is no left and right both coils use the same signal. This is done so you can give more power to the sub using two amps. If you think about it you can't give one speaker two different bass signals. It would sound like crap!
Larry
HTML code is Off
FS peripheral svenr line output converter eric4runner Classifieds - buy & sell (no commercial ads please) 0 02-14-2009 09:44 PM
Need help installing Line Output Converter for new Sub gkatmar Engines / Suspension / Wheels / Tires / Audio / Accessories 0 06-22-2008 02:13 PM
line out put converter rawlins32 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-07-2008 12:21 PM
Installing a line output converter in a 1999 4R Limited airbag Engines / Suspension / Wheels / Tires / Audio / Accessories 4 08-04-2005 12:05 AM
line level converter slammdchevy Engines / Suspension / Wheels / Tires / Audio / Accessories 7 06-26-2005 12:01 AM
