12-15-2019, 07:49 PM
#166
Can you reupload the images, please
12-22-2019, 10:40 PM
#167
Yes, please. Very cool but WHY DO PEOPLE STILL USE PHOTOBUCKET
I just dont get it, do they still use MySpace?
(ok, im done)
01-02-2020, 05:01 AM
#168
4-wheel power slides now and If you download the wiring diagrams in the stickies it shows
Jeden Tag casinobonus ohne einzahlung
die den Glücksspielern vielfältige
03-11-2020, 02:54 AM
#169
2004 checking in! Big Thanks to Wolverine for tracking down that stability control module. I was read to run a wire across to the 4x4 module from the button's plug when I finally found you post. Cut the red/white and spliced it into the Red/blue, everything worked exactly as described!!
1997 4Runner SR5 4x4 : 315k miles
2004 4Runner V8 4x4 : 215k miles
03-29-2020, 12:40 PM
#170
Where did you read to cut the red/white and splice.....?
10-06-2020, 06:24 PM
#171
2004 4WD V8 4Runner Trac Off Button
Hey Y'all,
I did some serious investigation to figure out how to cleanly defeat the TRAC control on the 4Runner. After wiring diagram searching I finally figured out that we're pre-wired for a TRAC OFF switch. I pulled the panel under the steering wheel and found the 2 clips tucked up and away above the fuse panel. There's one with a blue clip and one black. The wiring diagram shows that there is a red wire with a white stripe. That wire is in the BLUE harness clip. So that's what I'm using. Ordered a TRAC OFF switch today from eBay. Part number: 84988-AE010. The button from a 2WD for "AUTO LSD" is equivalent to this switch, just reads different. If you need that part number, its 84988-35050. But to be consistent, I wanted my 4WD to have the TRAC OFF reading on the button.
Getting the button next week. Will update then.
10-17-2020, 02:10 PM
#172
Originally Posted by bmorey
Hey Y'all,
Did you get this going?
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
10-17-2020, 10:09 PM
#173
So I bought a switch on eBay. Installed the thing and it lights up. Doesn't matter what mode I put the truck in, nothing comes up on the dash to confirm Trac has been turned off... super frustrating. I'm not totally abandoning the idea, but I'm wondering if the button isn't working quite right.
2004 4Runner Sport Edition 4WD Titanium Metallic -
Ironman 4x4 Lift and UCAs, 33s Falken Wildpeaks, Custom 2-Drawer System, Prinsu Rack, Frontrunner RTT, Ironman 4x4 Awning, Cali Raised Sliders, 1 Inch BL, Lost Trails Low Profile Front Bumper, Badlands Apex 12k Winch
10-20-2020, 08:26 AM
#174
I know this is only three days old but if you have some more luck with this please update, I have an 05 and want to keep this mod as clean and oem as possible. Interested in if you can get this to work.
2005 Sport / v6 / Icon stage 2 / toytech 1'' body / DO Front / 285/75/17 BF Goodrich KO2s / Fifteen52 Turbomac HD / Prinsu Full Length / Baja Designs & Factor 55 Goodies / Overland Custom Designs Links
10-21-2020, 04:38 PM
#175
Sorry I haven't had any time at all to further investigate. If anyone else is willing to find a TRAC OFF switch on eBay, Amazon, or a junkyard, the crowd-sourced information would be super helpful. I'm really hoping my button is just not working/I don't know the sequence to put it into trac-off mode. If anyone has any information on how to do the Trac-off procedure for 2008/09 4Runners that could be helpful too.
10-24-2020, 02:20 AM
#176
Why is it so hard to find info on how to do this cleanly on my 07 4runner v6
10-28-2020, 03:11 PM
#177
I'm waiting on a 84988-AE010 switch to come in from Toyota. I think we have to take this a step further. And cut the red white wire and tap it into the red/blue wire at the skid control ECU as demonstrated by
@ SSt4r
. My skid control ECU is under the dash on the left side in my 2003. I think later years it was moved to under the hood at the ABS module.
Here's my thread on this issue. Even though it's been covered numerous times I had a hard time wrapping my head around it. I think the basic gist is all you are doing is grounding out red/blue wire which is tricking the ECU into thinking the CDL is engaged.
TRAC Off Mod for 2003 V8 4WD
11-02-2020, 12:31 PM
#178
Ok this is pretty simple. Modify your switch to become on/off instead of momentary. This was the hardest part for me. Find your skid control ECU. On my 03 it was under the dash to the left if the parking brake. Find the connector with the red/white wire. Cut the red/white wire and tap it into the red/blue wire with a wire tap. Plug up your modified connector to the existing wiring harness in the dash. You can now push it whenever and the "VSC OFF" light comes on. My CDL light didn't come on. Only the VSC OFF light came on.
11-02-2020, 08:05 PM
#179
klavender1 - thank you for the good work!
Have you given the "trac off" features out? Meaning, did you successfully defeat all of the nannies by just pushing the button?
11-02-2020, 10:31 PM
#180
I'm gonna say yes? I was only able to test it out in my yard. So not much room to really get on it. But stomping it on dry grass it never cut out.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
