Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 11-02-2020, 10:47 PM #181
bmorey bmorey is offline
bmorey is on a distinguished road
Originally Posted by klavender1 View Post
I'm gonna say yes? I was only able to test it out in my yard. So not much room to really get on it. But stomping it on dry grass it never cut out.
Can you send a pic of the skid control ECU you tapped into?
2004 4Runner Sport Edition 4WD Titanium Metallic -
Ironman 4x4 Lift and UCAs, 33s Falken Wildpeaks, Custom 2-Drawer System, Prinsu Rack, Frontrunner RTT, Ironman 4x4 Awning
bmorey is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 10:46 AM #182
klavender1 klavender1 is offline
klavender1 is on a distinguished road
Here is the skid control ECU. It is under the dash in-between the parking brake and brake pedal. At least on our cars (2003 & 2004 V8s). The red arrow points to the plug you'll need to unplug and work with.
1103200928_HDR
Find the red/white wire, cut it and tap it into the red/blue wire.
1103200929
That's it! Once you plug in the modified TRAC switch, it works as intended. The switch lights up at night, pushing it anytime causes the "VSC OFF" light to come on.
klavender1 is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 03:09 PM #183
You're the man! Thank you for the detail and insight. I spent WAY too long modifying my switch to the on/off mode instead of momentary. I ended up sorta getting guitar string to work, but it feels super fragile and may get stuck in the on position... in any case, I'm gonna grab some wire taps from ACE today and see if I can tap the two wires together.
Old 11-04-2020, 10:33 PM #184
It's done! My '04 has the same procedure as yours. I spliced the red/white into the red/blue. I modified my switch to finally work consistently. I actually took apart the DAC button to get the exact dims and wire thicknesses I needed to get it to work. I ended up using guitar string (high E and a G string) to match the components of the DAC switch.
When I hit the button, the CDL light comes on, but no engagement of the locker, and the VSC Off light comes on as well. Everything seems to work as intended!
Thanks so much for the help @klavender1
Old 12-18-2020, 11:42 AM #185
awhitney1 awhitney1 is offline
awhitney1 will become famous soon enough
So I did the VSC off mod and the vsc light comes on and I can spin the wheels with the throttle not being cutoff, but it appears that ATRAC is still enabled. I thought ATRAC was disabled when VSC is off?
Any help? Thanks!
awhitney1 is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 10:53 PM #186
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Any help? Thanks!
ATRAC is separate from VSC.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 10:56 PM #187
You didn't do anything new - if you read the rest of the threads, wiring for 03/04 is detailed for using a stock switch and modding the switch is also detailed.
https://www.toyota-4runner.org/2605960-post144.html
HTML code is Off
'01-up 4wd System (A-TRAC, VSC) and TORSEN T-3 Thai General Discussions 57 09-01-2020 09:35 PM
Tacoma has VSC & Atrac.... opinions wanted about lease. Falls General Discussions 26 12-07-2008 03:33 PM
'08 VSC off mod for an '07 G.I.G. 4th Gen T4Rs 2 12-03-2007 03:07 AM
VSC, ATRAC compatible with larger tires? tifojo Off-Roading 3 02-16-2007 01:31 PM
ATRAC and VSC Clarification and Defeat Mafster 4th Gen T4Rs 7 11-02-2005 11:57 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
