Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 12-15-2019, 07:49 PM #166
Kats916 Kats916 is offline
Kats916 is on a distinguished road
Originally Posted by CJ3Flyr View Post
I completed the VSC-off mod on my T4R. The cool thing about this mod is the ATRAC is still active.
A great thank-you to Andries at T120. This is his hard work not mine.
What it's like after the mod is complete:
In 2wd dash lights are on (VSC & Diff lock). I didn't mess around enough to decide if VSC is working, traction control IS working; I'm assuming it has full VSC. It has all the familiar noises and accompanying reduction in power. The system seems to get confused if you attempt to change from 2HI to 4HI with the switch on. Lights get stuck in flash mode.
In 4HI it works as advertised You have an unlocked Torsen center diff and no interference from the VSC; the VSC and Diff Lock light are on. You can definitely feel/hear ATRAC doing it's thing. The same deal in 4LO... I can lock and unlock the diff while in 4HI (or 4LO) with my switch on. It locks & unlocks ok. When unlocked the diff lock light continues to flash even after the diff unlocks. It is not a perfect mod. It beats the heck out what Toyota gave from the factory. I am thrilled!
My advice is to not do a mode change with the added VSC switch on (grounding the wire). I may retract/amend that as I learn more. For now I plan to lock and unlock the diff, switch 4HI to 4LO with my added VSC switch in the off (ungrounded or open) position.
The bottom line is it's a great mod that facilitates the use of 4HI and 4LO without VSC interference and the center diff unlocked.
Andries saved me thousands! I was having serious 'VSC-off' envy of the 2008 guys!
This is the original Andries, aka Bulldog, thread: VSC Disable on Pre 2008 4Runners - Toyota 120 Platforms Forum
For further discussion of what the mod will do and why you may or may not want it read here:can you turn off the vsc? - Page 3 - Toyota 4Runner Forum - Largest 4Runner Forum
Below are some how-to pics Battery should be disconnected for this procedure! There's a TSB that discusses the risks; basically disconnect the battery. Do not turn or change 4wd mode knob until it's all back together and powered up.
Can you reupload the images, please
Kats916 is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 10:40 PM #167
psjbeisler psjbeisler is offline
psjbeisler is on a distinguished road
Yes, please. Very cool but WHY DO PEOPLE STILL USE PHOTOBUCKET
I just dont get it, do they still use MySpace?
(ok, im done)
psjbeisler is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 05:01 AM #168
Ravenn's Avatar
Ravenn Ravenn is offline
Ravenn is on a distinguished road
Ravenn's Avatar
4-wheel power slides now and If you download the wiring diagrams in the stickies it shows
Jeden Tag casinobonus ohne einzahlung
die den Glücksspielern vielfältige
Ravenn is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 02:54 AM #169
xcessiv xcessiv is offline
xcessiv is on a distinguished road
2004 checking in! Big Thanks to Wolverine for tracking down that stability control module. I was read to run a wire across to the 4x4 module from the button's plug when I finally found you post. Cut the red/white and spliced it into the Red/blue, everything worked exactly as described!!
1997 4Runner SR5 4x4 : 315k miles
2004 4Runner V8 4x4 : 215k miles
xcessiv is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 12:40 PM #170
WarChild's Avatar
WarChild WarChild is offline
WarChild is on a distinguished road
WarChild's Avatar
Where did you read to cut the red/white and splice.....?
WarChild is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 06:24 PM #171
bmorey bmorey is offline
bmorey is on a distinguished road
2004 4WD V8 4Runner Trac Off Button
Hey Y'all,
I did some serious investigation to figure out how to cleanly defeat the TRAC control on the 4Runner. After wiring diagram searching I finally figured out that we're pre-wired for a TRAC OFF switch. I pulled the panel under the steering wheel and found the 2 clips tucked up and away above the fuse panel. There's one with a blue clip and one black. The wiring diagram shows that there is a red wire with a white stripe. That wire is in the BLUE harness clip. So that's what I'm using. Ordered a TRAC OFF switch today from eBay. Part number: 84988-AE010. The button from a 2WD for "AUTO LSD" is equivalent to this switch, just reads different. If you need that part number, its 84988-35050. But to be consistent, I wanted my 4WD to have the TRAC OFF reading on the button.
Getting the button next week. Will update then.
VSC Off, ATRAC On Mod complete!-img_0076-jpg  VSC Off, ATRAC On Mod complete!-img_0072-jpg  VSC Off, ATRAC On Mod complete!-renderedimage-jpg  VSC Off, ATRAC On Mod complete!-img_0075-jpg
bmorey is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 02:10 PM #172
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Originally Posted by bmorey View Post
Hey Y'all,
Did you get this going?
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 10:09 PM #173
So I bought a switch on eBay. Installed the thing and it lights up. Doesn't matter what mode I put the truck in, nothing comes up on the dash to confirm Trac has been turned off... super frustrating. I'm not totally abandoning the idea, but I'm wondering if the button isn't working quite right.
2004 4Runner Sport Edition 4WD Titanium Metallic -
Ironman 4x4 Lift and UCAs, 33s Falken Wildpeaks, Custom 2-Drawer System, Prinsu Rack, Frontrunner RTT, Ironman 4x4 Awning, Cali Raised Sliders, 1 Inch BL, Lost Trails Low Profile Front Bumper, Badlands Apex 12k Winch
Old 10-20-2020, 08:26 AM #174
Currie_1's Avatar
Currie_1 Currie_1 is offline
Currie_1 is on a distinguished road
Currie_1's Avatar
I know this is only three days old but if you have some more luck with this please update, I have an 05 and want to keep this mod as clean and oem as possible. Interested in if you can get this to work.
2005 Sport / v6 / Icon stage 2 / toytech 1'' body / DO Front / 285/75/17 BF Goodrich KO2s / Fifteen52 Turbomac HD / Prinsu Full Length / Baja Designs & Factor 55 Goodies / Overland Custom Designs Links
Currie_1 is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 04:38 PM #175
Sorry I haven't had any time at all to further investigate. If anyone else is willing to find a TRAC OFF switch on eBay, Amazon, or a junkyard, the crowd-sourced information would be super helpful. I'm really hoping my button is just not working/I don't know the sequence to put it into trac-off mode. If anyone has any information on how to do the Trac-off procedure for 2008/09 4Runners that could be helpful too.
Old 10-24-2020, 02:20 AM #176
Hupo224 Hupo224 is offline
Hupo224 is on a distinguished road
Why is it so hard to find info on how to do this cleanly on my 07 4runner v6
Hupo224 is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 03:11 PM #177
klavender1 klavender1 is offline
klavender1 is on a distinguished road
I'm waiting on a 84988-AE010 switch to come in from Toyota. I think we have to take this a step further. And cut the red white wire and tap it into the red/blue wire at the skid control ECU as demonstrated by @SSt4r . My skid control ECU is under the dash on the left side in my 2003. I think later years it was moved to under the hood at the ABS module.
Here's my thread on this issue. Even though it's been covered numerous times I had a hard time wrapping my head around it. I think the basic gist is all you are doing is grounding out red/blue wire which is tricking the ECU into thinking the CDL is engaged.
TRAC Off Mod for 2003 V8 4WD
klavender1 is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 12:31 PM #178
Ok this is pretty simple. Modify your switch to become on/off instead of momentary. This was the hardest part for me. Find your skid control ECU. On my 03 it was under the dash to the left if the parking brake. Find the connector with the red/white wire. Cut the red/white wire and tap it into the red/blue wire with a wire tap. Plug up your modified connector to the existing wiring harness in the dash. You can now push it whenever and the "VSC OFF" light comes on. My CDL light didn't come on. Only the VSC OFF light came on.
Old 11-02-2020, 08:05 PM #179
klavender1 - thank you for the good work!
Have you given the "trac off" features out? Meaning, did you successfully defeat all of the nannies by just pushing the button?
Old 11-02-2020, 10:31 PM #180
I'm gonna say yes? I was only able to test it out in my yard. So not much room to really get on it. But stomping it on dry grass it never cut out.
HTML code is Off
'01-up 4wd System (A-TRAC, VSC) and TORSEN T-3 Thai General Discussions 57 09-01-2020 09:35 PM
Tacoma has VSC & Atrac.... opinions wanted about lease. Falls General Discussions 26 12-07-2008 03:33 PM
'08 VSC off mod for an '07 G.I.G. 4th Gen T4Rs 2 12-03-2007 03:07 AM
VSC, ATRAC compatible with larger tires? tifojo Off-Roading 3 02-16-2007 01:31 PM
ATRAC and VSC Clarification and Defeat Mafster 4th Gen T4Rs 7 11-02-2005 11:57 AM
