09-15-2008, 01:02 PM
Fishing pole transport
I was curious as to those of you with a T4R that fish, where do you normally put your fishing poles in/on the T4R? I am kind of anal and think "a place for everything and everything in its place" and wondering what good storage ideas there are for fishing poles with the T4R.
Plus, if you have any pictures of your setup please post those too.
Thanks,
Eric
Future 4R owner?
09-15-2008, 03:00 PM
Registered User
Registered User
rods
My surf rods go in a Thule roof mounted ski rack. Fresh water rods hang on my interior roof rack. I don't have any pics, but see link.
http://www.cabelas.com/cabelas/en/te...037&hasJS=true
09-15-2008, 10:01 PM
Real Name: Jeff
Real Name: Jeff
Re: Fishing pole transport
I do a lot of fishing . Depends what length your rods are to begin with . I mostly do lake fishing and the rods are 7 feet and they are 2 piece so I take em apart and just store them in the back . You could always fold one back seat down and have a lot more room .
I have a sub box and can fit 3 rods , 2 tackle boxes ,my big cooler and rod holder and some clothes in there , pull the cover thingie over it all , without ever touching the back seat area .
Thanks,
1998 4Runner 4WD Ltd
09-16-2008, 01:42 AM
I guess I should have put that in. I currently I have 6' 6" rod that does not break down. So I need at least that much room.
Eric
Future 4R owner?
09-16-2008, 10:34 AM
Growing up we used a piece of 4" PVC pipe. One end the cap was clued on, and the other was just pushed on/pulled off. You can cut the pipe to however long you need it to be. If you just have one rod, you could use a smaller diameter pipe, if necessary.
09-16-2008, 11:29 AM
That's a good idea, too. I will most likely have multiple rods in the future and the one I have now is a spinning reel, so I am not sure that would fit in a 4" diameter tube. Will have to see. I do think I want to check out some bait casting reels just for their compact size.
Eric
Future 4R owner?
09-16-2008, 02:13 PM
Real Name: Jeff
Real Name: Jeff
Do you have the factory roof racks ? I've always thought it would be cool to build a small rod holder deal and just strap it to those racks on top . You wouldnt even have to have 2 piece rods then ,plenty of room . Hell , you buy a 6" or ? " diameter PVC pipe and strap that up there , make it whatever length you want . Make up some cool decal and slap it on there
09-16-2008, 04:17 PM
i just left mine all rigged up reals in the back and then the poles leaning over the back seat with the tips sitting on the roof right above the front passenger window, I would drive around with passengers in the back and front with no probs at all. the rod are anywhere from 6.5 - 8.5ft fly rod.
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
09-16-2008, 04:33 PM
You can fit multiple rods in a 4" pvc pipe, however you would have to remove the reels and alternate the guides, when you insert / remove them. Think we had 4 or five rods per 4" tube, and 1-2 in a 3" tube.
If you are going to put them on the roof, you could clue the front end, put a threaded insert on the backend so you can gain access to the rods.
Throw some paint on the outside, and it should blend in to the roof rails.
09-16-2008, 05:31 PM
I didn't buy it yet but my friends use a snowboard roof rack. It has a lock on it too....but it won't do much with the rods in there. But I'll hold multiple rods with reels! Just make sure you have reel covers or take the reels off.
2007 SPORT 4x4 | DDM 4300k HIDS | Dobinson Coils | Bilstein 5100 | JBA UCA |SuperPro LCA | Goodyear SS brakelines | Allpro 1.5 spacers | Toytec sway mods and diff drop | Energy Suspension poly sway bushings | TRD Exhaust | RSG Sliders | Defiant Light Bar
02-19-2011, 08:59 AM
02-22-2011, 03:00 PM
I do the same unless they are in a soft case that I carry them in. I'll take better care of my rods than my wife
2003 Sport Edition V6 - Titanium Metallic
XREAS, Daystar 2.5F/ 1.5R, 265/70/17 BFG All Terrain KO,
Spidertrax 1.25, WeatherTech DigitalFit, NKG Iridium IX Spark Plugs
02-26-2011, 06:37 PM
I surf fish and use two 9 foot surf rods and they store easily in a roof mounted ski rack which you can buy for about $80.00 if you shop around on line. Just google SKI RACKS there are a ton of different listings and prices.
02-27-2011, 04:26 PM
Live on Hatteras this is the setup that I use.
GT Double E
02-27-2011, 09:58 PM
Real Name: Sergio
Real Name: Sergio
yakima fat cat 6 roof rack works when its fishing season
HTML code is Off
