Old 02-05-2016, 12:54 AM #46
MikeyMike MikeyMike is offline
MikeyMike is an unknown quantity at this point
Not sure where you read there were 2 antenna cables but there is only one. However, the blue wire from the vehicle harness goes into the "antenna booster power control terminal" on my Pioneer deck, which like @jrhess3 stated, it's for the power to the antenna.
2008 4Runner Urban Runner 4WD Titanium
Morimoto Elite 3Five 4500K | 20% tinted front windows | V-LEDS LEDs | Goodyear Wrangler A/T Adventure
2002 BMW M5 Chiaretto Red
MikeyMike is offline   Reply With QuoteReply With Quote
Old 02-19-2016, 10:32 AM #47
secretspy711 secretspy711 is offline
secretspy711 is on a distinguished road
So, years after the original post, there is still no harness for the Urban Runner?
I plan on installing an Android unit:
Joying® Aftermarket Best Head Unit, Car Stereo, Android Car Radio Audio Joying 2015 Best Wholesale In Dash Head Unit Quad Core 1024*600 Android 4.4.4 kitkat Car Stereo GPS Double 2 Din 7 inch Radio Audio navigation system 16GB memory Airplay OBD2 Wif
It says it supports steering wheel controls... Do I need an adapter or no?
EDIT: I don't think it needs one. It can learn the controls by itself. 6:00 in this video:
https://www.youtube.com/watch?v=3LpvY61RUJs
secretspy711 is offline   Reply With QuoteReply With Quote
Old 02-19-2016, 03:54 PM #48
ohjj13 ohjj13 is offline
ohjj13 is on a distinguished road
I read in a number of posts on the limited and sports there were two antennas, but You are correct that mine only has the single. However, The reception is still in need of improvement. I've checked and the radio amp is working. I'm in the country so that may be the problem. Thanks for the replies
ohjj13 is offline   Reply With QuoteReply With Quote
Old 06-17-2016, 01:20 PM #49
prasta's Avatar
prasta prasta is offline
Real Name: Patrick A Ruster
prasta is on a distinguished road
prasta's Avatar
Did you ever install this? If so, I'd be interested in hearing your thoughts!
2013 Toyota 4Runner Trail
prasta is offline   Reply With QuoteReply With Quote
Old 08-30-2016, 11:30 PM #50
Cpay916 Cpay916 is offline
Cpay916 is on a distinguished road
2008 urban runner tom tom
Hello i recently bought my 2008 4runner urban runner with the tom Tom navigation. I tried a few harness kits but obviously they dont work. I believe it has a factory amp. Im trying to instal an aftermarket deck. But cant get a kit. Do i cut the kit attached already and what about the stock amp. I have the stock harness kit, gps antenna and another plug which i believe is for the amp. Not jbl. Its a tom tom. Anything helps. Thank you.
Cpay916 is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 01:51 AM #51
SteveAndStaci SteveAndStaci is offline
Real Name: Steve
SteveAndStaci is on a distinguished road
Real Name: Steve
Hey there. Take a look at my post (post number 35) on page 3 of this thread... That may help. I was really confused when I first started. You want to keep the harness from the stock system. Cut the plugs off and use wire connectors to attach them to the wires of your new stereo, using the table reference in Post 35. It may be slightly different if you bought a different stereo than me but at least the purpose of each wire is listed. Let me know if you need help! I'm in England this week so may be slow to respond.
SteveAndStaci is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 10:36 AM #52
leftyguns21's Avatar
leftyguns21 leftyguns21 is offline
Real Name: Chris
leftyguns21 will become famous soon enough
Real Name: Chris
@Cpay916 its not the same as the normal factory plug, there are no harnesses you can get for it. just have to cut the wires and re-connect them. it should not have a factory amp, its just an odd HU connected to speakers normally. only the JBL system has a factory amp.
here is my thread of the install with other links within the original post if you need more info
New Nav Unit Installed Pioneer AVIC-X920BT
leftyguns21 is offline   Reply With QuoteReply With Quote
Old 08-31-2016, 11:25 AM #53
Plugs
Thank you for the information. So that round plug is just coming straight from speakers. Not an amp? So just color code and then speakers are from that round plug? Appreciate any help. Ive installed many audio systems and this has me confused. Lol.
Old 08-31-2016, 12:00 PM #54
Real Name: Chris
Real Name: Chris
its been several years since ive looked back there but correct, the plug coming in is just speakers/power so on so on, no amp. I chopped it off and hard wired to the wires on the HU
the colors are off though if I remember correctly so be careful. I recall they don't follow the normal convention. look through the links and find the wire colors/diagram before you start. my link also has the wire diagram to keep the steering wheel controls working and light up.
Old 09-10-2016, 12:21 PM #55
@cpay916 its not the same as the normal factory plug, there are no harnesses you can get for it. Just have to cut the wires and re-connect them. It should not have a factory amp, its just an odd hu connected to speakers normally. Only the jbl system has a factory amp.
Here is my thread of the install with other links within the original post if you need more info
thank you brother. I finally got it done. .
**Urban Runner Stereo Replacement Information**-snapchat-3649892757581821545-jpg
Old 09-11-2016, 02:12 PM #56
Real Name: Chris
Real Name: Chris
@Cpay916 good to hear. thats a crazy looking deck there. kind of tron-like
Old 09-11-2016, 02:17 PM #57
HAHA YA IT IS ITS JUST A SIMPLE PIONEER FH X 720bt DIDNT WANT A SCREEN AFTER I SOLD MY OLD ONE. REALIZED I DONT WATCH DVD OR USE THE NAVI ON IT. SO I GOT THIS. SCREEN WOULD HAVE LOOKED BETTER. DO YOU KNOW WHERE I CAN GET THE SAME HARNESS I HAD TO CUT FROM? 1 WIRE GOT CUT WAY TOO SHORT AND I HAVE TIED WITH A WIRE NUT. LOL.
Old 09-12-2016, 09:34 AM #58
Real Name: Chris
Real Name: Chris
dealership is probably best place to get new harness. if its only one wire. could probably get just one wire and soder it together
Old 12-31-2016, 10:28 AM #59
vdavis vdavis is offline
Real Name: Vance Davis
vdavis is on a distinguished road
Did you ever find out where the green wire that goes to the parking brake switch is actually attached?
vdavis is offline   Reply With QuoteReply With Quote
Old 12-31-2016, 10:33 AM #60
Where did you atttach the green parking brake wire. I have 2008 Urban Runner. have finished install of Pioneer 8200nex but cannot figure out the green wire. Pioneer says unit will not fully function without attaching it.
HTML code is Off
'07 4R has a bad stereo G.I.G. General Discussions 16 08-05-2008 07:46 PM
2005 4Runner LTD Factory Stereo replacement options meljunew 4th Gen T4Rs 2 05-02-2008 12:34 AM
99 runner won't run when engine hot! juneau Problems & Warranty Issues 1 03-14-2007 09:08 PM
Getting another 4 Runner Chance 4th Gen T4Rs 24 05-28-2006 11:52 PM
06 Stereo in 05 Runner? PRFlyer26 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-28-2006 09:42 PM
