03-21-2022, 01:51 AM
#91
Originally Posted by riceandpho
use the regular sw as a guide, see if you can see the wire color are the same for that harness. now on the camera harness, you might just need to use the other guide and find the signal for the rca + and -. there is no need for that harness your trying to plug and play, its needs to be directly hardwire.
see if you can use the purple/red , pink/red , black white, red is accessory wire and black is ground. this is for the steering wheel part.
wire colors are all different, the truck wires are red/yellow=sw-1, purple=speed, brown/black=ground, blue/yellow=sw2, the wires from the axxess and maestro are different also. I also cant find what the wire colors on the maestro and the axxess are what colors are for sw1 &2 speed and ground. Ive spent hours online trying to find the info with no luck.
this is so confusing I am beyond frustrated, urban runners wiring suck ass they couldnt just use standard wiring like every other truck, I am not sure I want to attempt this myself dont want to ruin a brand new stereo if I screw something up. it just sucks I spent all this money and i cant get it installed.
03-21-2022, 02:23 AM
#92
they used to have hard wire diagram for the maestro, just need to look it up.
but on the maestro harness, did you see the wire colors i mentioned before, the harness that came with the unit, you might find the same colors on that exspensive harness you have too.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
03-21-2022, 02:42 AM
#93
if you disect the expensive harness, you see only the maestro uses the power, and ground, the signals for steering wheel controls, and odb 2, see where the harness needs the actual power and grounds. some grounds are all together on the harness, the other parts of that harness is aux, radio speaker wires and vss.
The steps it take to replace your radio in a Toyota 86 using a Maestro RR - YouTube
i only glanced at some disected parts
03-21-2022, 12:23 PM
#94
Thank you for the help I really appreciate it. I looked on the harness that came with the maestro fount the pink/red black/white and the purple/red there is no red wire. colors on the TO harness are different. That video unfortunately didnt help me.
03-22-2022, 10:12 AM
#95
now you located the pin out on the original harness, match up the pin out on the expensive harness, if they used different colors, youll atleast know which pin out is being used.
04-02-2022, 01:01 AM
#96
2008 Toyota 4Runner Urban Runner Edition Questions -
check that out, i found the hardwire diagram of the harness. you might want to disect some wires and use only certain plugs. install is straight forword. i was going to purchase the harness by itself to disect, but i only use the power and ground and ac for my installs.
HTML code is Off
