Old 07-31-2018, 02:14 PM #16
brmaher brmaher is offline
brmaher is on a distinguished road
Originally Posted by blue2006 View Post
chuck, crutchfield has stuff that will fit...
i was curios if the 4th gen Nav head unit had its own amp or are the 5 speakers and sub driven by a standalone amp? Im thinking about updating the speakers but am curious about the power in the system
I'm curious about this as well because my sub is making a buzzing noise after a friend was loading my trunk and hit the speaker mesh with a 2x4
brmaher is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 10:59 AM #17
plutonic's Avatar
plutonic plutonic is offline
plutonic is on a distinguished road
plutonic's Avatar
Originally Posted by Ultraphage View Post
I haven’t found where anyone has addressed this, and Crutchfield has no guidance and there techs are clueless.
The 4th gen 4runners have a 2ohm system...correct? If you want to replace and/or upgrade, the easiest thing to do is to add a Bluetooth connection (most people have music in devices rather than CD’s or cassettes) and upgrade the speakers.
Well, all the threads are about swapping the head unit (which negates the issues with resistance) and speakers and Crutchfield is only concerned with the SIZE of the speakers.
Can someone who knows what they are talking about chime in please? If I replace the stock speakers with ones that are rated 4ohms, then the volume should be decreased right?
So then, unless you replace the entire system(head unit, amps,etc), you should need to replace the speakers with ones that are rated the same...right?
Are there any decent 2ohm speakers that can just be swapped out and don’t cost a ton? Is this not what everyone should be doing?
How do you “disable the tweeter” to replace the stock speakers with a single 2-way speaker?
Any audio wizards here to answer these questions?
plutonic is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 07:02 AM #18
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
are you just wanting to replace the factory speakers? do you have aftermarket radio? or jbl? if its the non jbl i would try these out
KFC-XP6902C | Speakers | Car Entertainment | KENWOOD USA
are you going to have them power up with aftermarket amp?
do you want to spend more on some other stuff, usually i recommend doing just the fronts with a nice amp and speaker combo, also sound deaden the doors.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 11:33 AM #19
plutonic's Avatar
plutonic's Avatar
Just want to replace the factory speakers and I want to stick with the 2ohm system. Replaced the subwoofer a few months ago, now I want to get the rest of the system done.
Haven't purchased a new head unit yet, but I know exactly what I want to get.
Yes, I will do the sound deadening on the doors, the materials are on order already.
Did some research in the last few days and I got an answer to some of my questions and decided to stick with the 2ohm system because an upgrade to a comparable 4 ohm system would take significantly more work and money and the outcome wouldn't be that much better. I picked a decent head unit with Bluetooth and usb connectivity which will do exactly what I need.
The only thing I have to find out at this point is that if there are more selection of 2ohm speakers out there somewhere besides Crutchfield.
Old 08-23-2019, 05:35 PM #20
riceandpho's Avatar
riceandpho's Avatar
they do make 2 ohm speakers, i think it was infinity, now if you bypass the jbl amp and use head unit power, its best to stay the 4 ohm.
you have some options, i never had jbl system, i always avoid the premium sound package and do my own custom stereo.
Old 02-28-2020, 02:14 PM #21
Ultraphage Ultraphage is offline
Ultraphage is on a distinguished road
I ended up keeping the 2-ohm amp and replacing the sub, and the larger speakers in the doors with 2-ohm crutchfield cheapies (powerbass?). I left the “tweeters” that were stock. Originally it sounded a little better, but quiet, then realized I forgot to adjust the little in-set dial on the amp junction box (forgot the real name of those things) you must purchase to connect an aftermarket head unit to the 4-runner factory system.
Now the only issue I have, is I think there is a little too much higher end in my music. I wonder if I could disable the center dash speaker, if that would fix that? I also sometimes have some knocking around in the sub enclosure with some low end heavy songs. Other than that, my car sounds decent, can get fairly loud, and is fairly well rounded. I bought a $100 head unit, 4 speakers, a couple of wiring harnesses, and the units that allow you to use the stock amp and steering wheel controls—-all under$300. Maybe 2 hours of work if you have a little helper putting it back together as your replacing. Well worth it.
Ultraphage is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 12:55 AM #22
dsanford dsanford is offline
dsanford will become famous soon enough
I just got into my 4Runner today and opened a can of worms that just kept getting worse. Now the only thing holding me back is undoing the crossover and speaker setup the previous owner had. If anyone has the OEM speaker and OEM tweeter connections, that would really help. The OEM connections in my setup have been cut. Yes I could wire them directly but I’m just not into cutting the factory harness and can hopefully put those connections back. If anyone knows who might have some, or where I could get these connections. Are these a common used connection I could scavenge off another Toyota model, or a different generation 4Runner?
dsanford is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 08:38 PM #23
Update on the last post.
Got the dash pulled apart, crossed my fingers and toes the whole time hoping I didn’t find a cut harness behind there.
Started removing the crusty half functional Alpine head unit, as soon as I removed it from it’s home I found what would take me the rest of the day to fix.
First I saw three sets of RCAs, and a particularly cut harness.
After unplugging the Alpine head unit, I knew I wanted to get all the aftermarket wiring out of there before I installed the new Sony head unit. That’s where things got interesting. I went through the glovebox and found a pamphlet and instruction manual for a Apline KTP-445U (Head Unit Power Pack). I presume this is what was used to have the factory amplifier power a subwoofer. I spent the rest of the day undoing what was done here.
4th Gen speaker replacement question-a3db7fed-5ed4-4e8f-9b06-6a1461ee76a6-jpg  4th Gen speaker replacement question-aa4d2b71-0c9c-4157-9987-b330c66654f3-jpg  4th Gen speaker replacement question-7c6786ca-08f9-456f-92fc-45dae2fc3718-jpg  4th Gen speaker replacement question-61e41102-90f4-452c-a140-4381c5d66b2d-jpg  4th Gen speaker replacement question-9edbf5e4-f37b-4df2-9ea1-3e164ac7fde6-jpg  4th Gen speaker replacement question-49e6ba78-675d-4ae2-b417-125c0fe5ddbd-jpg  4th Gen speaker replacement question-0f07fbcd-d934-461b-81e8-c30ceb0cbb7a-jpg  4th Gen speaker replacement question-6a6207b2-439f-4ad0-8ef4-fa04f249edce-jpg
Old 03-03-2020, 10:20 PM #24
Once I got everything opened up I was able to see what needed to be fixed. I pulled all the previous extra wiring and fixed at the wire taps at the amplifier. The harness wasn’t plugged into the amplifier. During the removal of all this I found a Alpine KTP-445U (Head Unit Power Pack). I assume this is what was used for the external amp and sub. I was on the look out for this thing because I found the pamphlet and install instructions in the glove box. Then I set off putting together the harness for the new Sony head unit. I used the Axxess TYTO-01 and ASWC-1. The steering wheel controls didn’t work with the previous head unit. The dash kit I used was the Metra 95-8210. Turned out looking pretty good I think. And now I have the peace of mind knowing I cleaned it up and restored what I didn’t like.
4th Gen speaker replacement question-7e379c0e-c5e5-4f7f-a883-ddcfe2218c8d-jpg  4th Gen speaker replacement question-aafd7de1-d5f4-4073-8cbb-d6815e11065b-jpg  4th Gen speaker replacement question-37f0bc18-d02f-47da-9eda-5f774afd9957-jpg
Old 03-03-2020, 10:53 PM #25
The there were a few gripes I had about the install.
First, the Axxess TYTO-01 has a potentiometer for audio level adjustment. This adjustment is almost useless. Directions say to turn the radio volume to 3/4 and adjust the potentiometer to get the desired loudness. When I did this, the audio was awful. Way too much power going to the speakers. So I adjust the potentiometer, and the audio had this pulsing effect as if someone was turning the volume up and down slightly.
Second, the sturdiness of the Metra kit is okay once it is in the dash but applying the dash kit, you have to be careful not to over do the screws holding the dash kit to the head unit. Also, if you’re not thinking ahead, you can really get the depth of the face all wrong. Thankfully I thought about this before I put the entire dash back together. It came out pretty good I think.
Lastly, back to the audio quality. I was curious why the speakers sounded so bad, I was planning on changing the front door speakers for now. Once I got the door panel off, I realized why it sounded so bad. The previous owner either paid someone to install a crossover and component speaker set of did it them self half ass. I the lower door speaker wasn’t even hooked up and the crossover was held on with hook and loop in the recess of the door. The factory speaker harness had been cut (typical for crossover and component install), and sound deadening had been lathered on behind the door panel. So now, I have to wire the speakers direct until I can’t find the OEM male and female side of the speaker harness and I’ll have to really put in some elbow work to remove the sound deadening so I can reapplying how I would like it (between the inner and outer skin of the door)
Any questions are welcome. This isn’t technically a write up but instead more a first time experience working on the 4Runner and what I went through.
I almost forgot, one good thing I did find while I was in there was a Code Alarm CA5053 and FlashLogic FLCAN ADS. I did not receive a remote for it but I found the correct remote online and waiting to see if the system still works and if I also inherited a remote start with this vehicle. :-)
4th Gen speaker replacement question-3f47a6f3-8ab3-41bf-81fe-63b8fadb9d5d-jpg  4th Gen speaker replacement question-c8a35c9d-816e-468f-87ec-bf7818fb0992-jpg  4th Gen speaker replacement question-d64a0855-3e34-4ae2-99df-9cecd59bd4f2-jpg  4th Gen speaker replacement question-dc4bfcda-5c6c-4274-95fe-5682b46c42bb-jpg  4th Gen speaker replacement question-b67d3c46-24f1-415c-9447-910209d661f0-jpg  4th Gen speaker replacement question-074bbece-8fe6-48f3-9822-e66ea5a6aa21-jpg
Old 03-04-2020, 04:07 PM #26
daltona117's Avatar
daltona117 daltona117 is offline
daltona117 is on a distinguished road
daltona117's Avatar
Did you do a direct replacement for the factory sub? I have the JBL system in mine and the sub is blown. Curious to see what you replaced yours with.
daltona117 is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 03:10 PM #27
I did not end up doing a sub replacement. There was existing wiring that someone else added for a sub enclosure and amp. I removed all that wiring and repaired what was changed. Much to my surprise, the factory sub still worked. From what I’ve read on the forums, the sub is commonly blown. Later down the road a sub upgrade may be in the cards but it works great for myself so far.
Old 03-05-2020, 03:13 PM #28
There are some great resources on here about upgrading the sub that I’ve read but didn’t save the thread. If I come across those threads again I’ll post the link here for you. From what I recall, there is a Kicker model that works great in the factory location with minor modification.
Old 12-21-2022, 11:57 PM #29
Fontan Fontan is offline
Fontan is on a distinguished road
Do you know the kicker model off hand that you're referring to?
Fontan is offline   Reply With QuoteReply With Quote
Old 12-22-2022, 12:30 AM #30
Cool
Originally Posted by drmorbius View Post
1. The front speakers are 6x9 ovals, the only crossover is a bipolar capacitor in line with one of the tweeter leads. You can upgrade to a better 6x9 or use an adapter to fit a 6.5" round speaker. The front speakers are not 2 way because of the separate tweeter however you can disable the tweeter and use a 2 way 6x9, one or the other.
2. Rear speakers are 6.5" round and there is no tweeter. The rears are kind of hard to hear because of the seat arrangement.
3. I would recommend keeping the speaker impedance the same for front and rear. The instructions that came with your head unit should tell you what resistance the speakers should be.
4. All speakers have plugs but they may be hard to adapt to aftermarket speakers.
Hope this answers your questions.
I am sure you know what you're talking about. Crutchfield is recommending 5.25 for the rear doors (2007) but maybe that is just due to the mounting depth? When I add 6.5 (JL audio C1 650s to the cart it says the mounting depth is 2.5 but that is shallower than the toyota rear door cut-out.
HTML code is Off
4th gen alignment question nyc4runnin 4th Gen T4Rs 10 10-04-2010 06:55 AM
WTB: stock speaker for 4th gen non-JBL drhowardjr Want to Buy/Trade 0 06-29-2010 04:11 PM
4th Gen Suspension Question JP4RNR Maintenance/Detailing 2 09-25-2008 01:03 AM
WTB: 4th Gen rear speaker mirrors RL Lemke Want to Buy/Trade 2 01-25-2008 02:37 PM
4th Gen 4R - rear diff question supercliff 4th Gen T4Rs 2 04-12-2007 03:42 PM
