if u have an aftermarket deck in all u need to do is use that harness that u pluged in from the truck to the new deck, first find the speaker leads, one small plug was for the rears so cut and tape the one off the deck, then the front should be with the big plug, cut and tape off, now run 4 pairs of speaker wire, best to run 2 sets at a time and run it under the seat then thru the cent and back to the harness for the small plug, find the positive and neg on the speaker leads, harness should tell u, then do the same for the front, also run the rca cables the same way, shouldnt take more than 1 hour for a clean fresh install, remember to run the power on the driver side, under the sill, then the ground under the seat, there is a ground bolt that can be use right behind the left nut that holds the seat, should be to the right a little, use that bolt for ground, plain and simple, all u need is about 7 feet of speaker cable thats can run 2 pairs of speaker, and 6 feet rca will do just fine, power about 12 for some extra to use incase of upgrade or moving around, and 2.5 feet of ground.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
