Originally Posted by juiceboxer
if you are not swapping out the head unit the you can continue to run the factory tweeter. What speakers are you thinking of running, what defines inexpensive to you?
Well, I am swapping out my head unit. I might just leave the factory speakers in after all...just depends on how it sounds after I swap head units.
So you are saying that the tweeters won't work with an aftermarket head unit? My friend that had a 2001 Limited said his factory tweeters/speakers worked fine with his aftermarket head unit.
I just wasn't sure if replacing the just the lower door speakers would affect the tweeters, especially if the 6.5s that I was going to put in already had a tweeter.
