10-06-2009, 03:18 PM
3rd Gen amp install location
I am having trouble determining where to install my RF punch 60 amp. It is pritty small, but to thick to fit under the drivers seat. I want to hide it so i just have to remove speaker wire to get the sub enclosure out if need be.
where have you guys mounted your amps?
99 4 Runner Limited. 3" Toytec Ultimate lift with SuperFlex rear coils. 231mm Tundra calipers. Rear diff breather extension. 285/75-16 Nitto Trail Grapplers. Savage full skids & sliders w/ kickout. ISR mod. LED gauges. Shrockworks front plate bumper w/ loop. 4xInnovations rear plate bumper.
10-07-2009, 05:24 PM
It might fit under your passenger seat. There is a little more room over there.
2001 SR5 2WD - 170k and counting.....
Exterior: 265/70/16 Firestone Destination L/E on Sport Wheels, 5% Tint, Wade Wind Deflectors, Toyota OEM Bug Deflector, Plasti-Dip, DRL Mod, DDM HIDs (35w, H4, Hi/Lo, 6000k)
Interior: Pioneer AVH-P5200BT/JL Audio C5-650 6.5" Components/JL Audio Evolution C2-400x /WeatherTech Digital Mats
10-09-2009, 08:28 AM
Guest
Guest
rear cargo area in that pocket which is on the right side, has a cover on it. havent had my coffee yet so forgive me for the terrible description. by putting the amp here you can cover it back up.
10-09-2009, 04:48 PM
An amp will not fit under the passenger seat if you have a limited (edit: I see you do) due to the rear heater. I just stick my sub amp behind the sub box, nice and easy access.
2001 Silver Limited 4WD 4Runner
10-20-2009, 01:20 AM
I hardly if ever use my cargo area with the rear seats folded down so I have mine mounted (one to drive my subs and the other to drive my door mount speakers) on the back of each rear seat. Aesthetically clean, completely hidden out of sight especially if you have a tonneau cover. Works great for me.
StreetRunner - 1997 4Runner SR5, Leather, 3.4L, ATM, Chrome 20's", Custom Chrome Grill, Sony XR-C8200 Head Unit /10 eCD Changer, Audiovox AVDBR1 Blu-Ray/DVD Player, Clarion VMA7901 Head Rest Monitors, Sony Xplode 2K Watt 2Channel Power Amp, Sony Xplode 2K Watt 4Channel Power Amp, 2 Sony Xplode 12 inch Sub Woofers, Magellan Gps, Blue LED Dash/Climate, White LED Map/Dome/Rear, 6k HID's, 6K DRL's.
10-20-2009, 11:21 AM
^ That's exactly how I have mine too.
Check out my garage.
10-21-2009, 01:04 PM
I won't tell you to do this but it worked for me. I had a JL 250/1 under the rear passenger seat where the Jack is located. I actually never had it overheat either.
-Pete
07 Shadow Mica V6 Sport
Audio: Eclipse AVN 6620| Alpine PDX 4.150 & 1.600 | CDT HD62 x2 & Fiberglassed 12'' & Lots of Soundproofing
Lighting: 4300K HID, 3000k HID Fogs, LED Interior, Krager HID Driving Lights
Outside: Daystar 2.5/1.5, 285/60R18 Toyo OC AT | T&H High Bull Bar
10-21-2009, 03:27 PM
I've considered that spot. I might try it if I ever upgrade.
I currently have my smallish amp under the driver seat. There's about 2.5" of clearance before the seat motor gets in the way. It's a PITA to make wire connections while the seat is still attached, but I managed!
11-14-2009, 11:36 AM
I have two amps installed where the factory subwoofer would go in the rear quarter panel. I would imagine it gets pretty hot, however I have NEVER had a problem. (except when my wife backed into something...not a good story) It does prove to be difficult to service them because I have to remove the entire rear interior panel.
11-14-2009, 02:17 PM
I had my amps in the same location, but now they are too large to really hide anywhere. I can get my 4 channel amp under my seat but if it isn't all the way back it sticks out. My sub amp is just sitting behind my sub box, I have yet to build a mount for it.
Ridog, I want to hear this wife backing into something story, it sounds like sparks could be involved .
02-12-2019, 12:10 AM
Amp location
I have an Alpine PDX 2.150 I put under the driver seat of my 00'. There is a hole already cut in the carpet right in front where I ran my 6 gauge power and all my audio cables and I have no issues with it. Doesn't get hot or in the way at all.
HTML code is Off
