06-12-2005, 02:51 PM
#16
Re: Re: My LED Project
Originally posted by AlexJet
You gave this website: http://autolumination.com/festoon.htm
There I found: "Festoon Dome LED Light Bulbs". If I'll buy one of this dome LED bulbs, do I still need to get a resistor, or they will work with 12v?
they should already have the resistor inside of the housing.
Check out my 2004 4Runner Audio upgrade.
06-12-2005, 02:53 PM
#17
Oh, if you get some, let us know how they look.
I think they basically did what I did, the main difference is they have them installed inside the glass tubing thing.
06-12-2005, 03:12 PM
#18
I'm in Toronto, Canada, so I wrote them an e-mail, asking if they can ship to Canada. As soon as I get a positive reply I'm going to order some. Otherwise I'll have to find someone in states who can order them and then ship to me. Probably I can get someone help from this forum. It's so difficult sometimes to order stuff to Canada, nobody wants to deal with customs. I'll post images after I'll get and install them.
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
06-12-2005, 03:13 PM
#19
Now, when choosing your supply voltage, I used 14.5. I put a multimeter on the battery terminals and noticed that when you rev the truck up, that the voltage can climb up to about that.
One thing to keep in-mind, when performing calculations, is that the battery
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
06-12-2005, 05:17 PM
#20
Re: My LED Project
Well, I finally got some of my LEDs put together and installed on the Runner.
I also replaced the bulbs in the doors too,
It's pretty neat now, it not only lights up the door, it lights up ground too. The stock bulb never did that.
Do you know what type of the bulb in the door lights?
06-12-2005, 05:20 PM
#21
They were 194's.
06-12-2005, 10:19 PM
#22
Re: Re: Re: My LED Project
They were 194's.
Is that the same little ones that are in our running boards?
Dec '04 4ROTM: '03 Limited V8 Nav Black: Grey Leather, Side Airbags, Spoiler, Moonroof, 6-disc Changer, Wireless Headphones, Tow Tongue/pin, First Aid, Pocket Cargo Net, Flat Cargo Net, Double-decker Cargo, Cargo Cover, Floor Mats, Sulfur TSB, Moonroof TSB, Seat Rattle TSB, Body Mount TSB, Debadged, JDM Chrome Handle Covers, Hitch Cover Brake Light, Hitch/Trailer Locks, Tow Wire Converter, 4-wire Extension, Coat Bar, Sylvania Silverstar Highs/Lows/Fogs, JDM Chrome Tail Light Trim, Hilux Surf Trash Stash, Front Side Tint, Moonroof Tint, Custom Black & Chrome Liscense Plate Frame, 12V Cooler/Heater, Microfiber Cleaning/Dusting Cloths, Yakima Snow/Surf Rack System, T&H Chrome Bull Bar, Custom Mesh Front Emblem, All-Weather Mats, Xtreme Cargo Mat, Cargo Logic Tote, OBX Pedals, Valor Exhaust Tip, Stainless Door Sills, Driver's Roof Handle, DRLs, Hilux Surf Brushed Aluminum Rear Bumper Guard, JDM Switch Blank Coin & Pen Holders, Maglite Swivel Belt-Clip Mount, Kleenex Armrest, Warn Shackle Hitch Receiver, Blind Spot Mirrors, T4R.ORG Sticker, Vinyl Headlight Eyelids, Toyota Hat, Toyota Mug, & Portable AC/DC Power Jumpstarter Compressor Light Combo.
06-12-2005, 11:49 PM
#23
Yep same ones
06-13-2005, 09:34 AM
#24
Re: My LED Project
Here is shot of the map lights. Here I used 4 3mm superwhite LEDs.
These sure light the inside of the Runner up. Plus it has that cool superwhite glow to it.
How do you open map lights for bulb exchange? I tried to pull it, but it doesn't really work. I didn't want to force it, because it looks like I was going to break some clips.
BTW. Could you also tell how to open door and running boards lights?
06-13-2005, 10:16 AM
#25
OK, I'm going off memory on the map lights but you need to take a really small screwdriver, and actually pry out where you normally push to turn them on.
The doors are also just held in with a clip if I remember right, just use that same really small screwdriver to pull it out.
The running boards are easy, just look under the running boards. You'll see the connector, just twist it and it should just pop right out.
Hope that helps
Chris.
06-18-2005, 02:31 PM
#26
will the pre assembled led fixtures fit in the headlight housing?
06-18-2005, 02:39 PM
#27
Ok, I made a deal with them and ordered few LED. I just receive e-mail that my order will be shipped on Monday. So next weekend I'll also do my LED project. I hope I'll have them by the end of next week. I can't wait to receive and install them. I want to try to do some mods with my DRL. If everything will go fine I
06-28-2005, 06:30 PM
#28
This afternoon finally I received the package. It took them 10 days to get it here. Looks like everything is fine. Tomorrow or Thursday will try do change some bulbs. I'll post some pictures while doing this upgrade.
06-30-2005, 01:51 PM
#29
Ok. I tried to use 194 type LED for running boards -> no way, those LEDs are worth then stock bulbs.
cdoyle where did you get your LED for running boards?
I've also done map lights and doors one. Those look nice. I'll post some images later...
Project to be continued ....
06-30-2005, 07:03 PM
#30
I made mine own, using some 80ma 5mm LEDs. I tilted each led so it would help spread out the light some, since those LEDs had such a narrow beam pattern. They look pretty good.
HTML code is Off
