10-03-2004, 10:43 PM
My LED Project
Well, I finally got some of my LEDs put together and installed on the Runner.
After a couple trial and errors, I'm pretty happy with the results.
Here is a photo of one of the completed LED wedges.
This one has 3 5mm superwhite LEDs epoxied into a empty wedge that I
bought here
The LEDs themselves I bought from HERE
I did try some of the already built ones that they have, but the LEDs that they used seem to have a more 'purplish' color tint to them, I was looking more for a blushish/white tint. Plus the LEDs I used for the parking lights have a rating of 22,000mcd, which seem to light up the housing better.
Here is a shot the headlight assembly with the LEDs on.
I think it looks so much better then the stock orange colored bulb that was in there.
Here is another shot with the headlights on too.
It does make my Silverstars looks a yellow doesn't it. Would look even better if our Runners came stock with HIDs.
The parking lights weren't the only ones I replaced. Here is shot of the map lights. Here I used 4 3mm superwhite LEDs.
These sure light the inside of the Runner up. Plus it has that cool superwhite glow to it.
I also replaced the bulbs in the doors too,
It's pretty neat now, it not only lights up the door, it lights up ground too. The stock bulb never did that.
Now on to the Running Boards
Here you can get a good comparison on how bright they are.
Here is a shot of one of those 'Xenon' bulbs that were posted on here a few months back.
Ya, it's OK but not very bright. Actually less bright then the stock bulb.
Now look at this.
I still need to buy some more LEDs to finish the rest of the running boards. Plus I want to do the License plate lights too. I'm also going to construct something to replace the dome lights too, they look so yellow compared to everything else now.
If you decide to do this, and order the wedges, one thing I noticed. The first time I ordered them, I got white ones like pictured above. The second time I ordered them, they were a clear wedge (which at first was cool) but then I also noticed that they are slightly smaller. So it's alot harder to fit everything into it. Especially when using the 5mm LEDs. So if you order some, see if he has any of the larger white wedges left.
So what do you guys think?
I know awhile back there was a thread about those 'xenon' 194 bulbs, and I have to say these LEDs are way brighter then those.
2004 Titanium Limited V8 Pics
Car Audio Central's own Mafia style RPG. Sign up for free and let Chrisfromwa know you're from 4Runner.org. I'll set you up with cash and weapons to get started.
10-03-2004, 10:58 PM
Sweet. I especially like the running boards lights......with the stock, you can barely notice them, let alone actually use them for much.
Now for a few questions:
Are you the first on here to do this?
How difficult is it?
Are there any risks involved?
How much has it all cost so far?
Did you say the ones in the heads are parking lights? I guess this is a stupid question, but when do these come on?
Dec '04 4ROTM: '03 Limited V8 Nav Black: Grey Leather, Side Airbags, Spoiler, Moonroof, 6-disc Changer, Wireless Headphones, Tow Tongue/pin, First Aid, Pocket Cargo Net, Flat Cargo Net, Double-decker Cargo, Cargo Cover, Floor Mats, Sulfur TSB, Moonroof TSB, Seat Rattle TSB, Body Mount TSB, Debadged, JDM Chrome Handle Covers, Hitch Cover Brake Light, Hitch/Trailer Locks, Tow Wire Converter, 4-wire Extension, Coat Bar, Sylvania Silverstar Highs/Lows/Fogs, JDM Chrome Tail Light Trim, Hilux Surf Trash Stash, Front Side Tint, Moonroof Tint, Custom Black & Chrome Liscense Plate Frame, 12V Cooler/Heater, Microfiber Cleaning/Dusting Cloths, Yakima Snow/Surf Rack System, T&H Chrome Bull Bar, Custom Mesh Front Emblem, All-Weather Mats, Xtreme Cargo Mat, Cargo Logic Tote, OBX Pedals, Valor Exhaust Tip, Stainless Door Sills, Driver's Roof Handle, DRLs, Hilux Surf Brushed Aluminum Rear Bumper Guard, JDM Switch Blank Coin & Pen Holders, Maglite Swivel Belt-Clip Mount, Kleenex Armrest, Warn Shackle Hitch Receiver, Blind Spot Mirrors, T4R.ORG Sticker, Vinyl Headlight Eyelids, Toyota Hat, Toyota Mug, & Portable AC/DC Power Jumpstarter Compressor Light Combo.
10-03-2004, 11:15 PM
Hi,
Thanks, glad you like it.
Ya those running boards look so much better now.
As far as I know, I think I'm the first one to do this
Difficulty wise, I would give it a 5 out of 10.
The hardest part, is trying to hold the LEDs, and then trying to solder them together, without droping them. Or getting the LEDs too hot and ruining them. I'm not sure how in the world the place you buy the wedges from does it, or how they cram 6 3mm LEDs in there. They must have a machine that does it for them or something.
One thing to note LEDs by themselves can't run off of 12v, so you need to put a resistor in series. Go here to get the calculation of what resistor to use resistor calculator I ran all the LEDs in series with 1 resistor.
Now, when choosing your supply voltage, I used 14.5. I put a multimeter on the battery terminals and noticed that when you rev the truck up, that the voltage can climb up to about that.
One thing I'm going to try next time is, I found some resistors on the net, that are physically smaller then the ones you buy at radio shack. So it might make it easier to cram them into that wedge.
Harm to the 4Runner, it shouldn't. As long as you didn't short anything out putting it into the wedge, you should be fine. Nice thing about LEDs, there is almost no heat from them, and they take very little current to make them light.
The parking lights on mine always come on when the headlights are on. You can also have just the parking lights on too. It's the first setting on the headlight control.
Cost so far, I think I'm around $40 or so. That's including the epoxy, solder, leds, and the wedges.
10-03-2004, 11:48 PM
Super Moderator
Super Moderator
The LED's you put in look great. Just a quick question, how hard was it to put the LED's in the map lights and door lights? That could be the next thing on my agenda.
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
10-04-2004, 12:09 AM
Wow, awesome! How long did it take to do all 8 wedge bulbs? Nice job!
I bought the 5-LED "Matrix" bulbs from autolumination.com and currently have them in my car. I like how they point in all directions and really reflect off the reflectors in the maplights. I agree with you on the color though, they're a little purplish. I'm not good or very experienced in soldering so I chose to get the ready-made ones, lazy me!
2003 4Runner SR5 V6 4x2 - Pacific Blue Metallic/Taupe Leather
10-04-2004, 10:17 AM
Originally posted by tkr128
.....I'm not good or very experienced in soldering.......
Ditto, so I would like to pursue the ready made solutions. Are there any threads discussing them besides this one?
10-04-2004, 02:04 PM
Good Job. I am thinking about doing my entire tailight assembly with LED's, but need to find out more about flasher relays. I know to know what type of load caused them to function properly and at what load they think that a bulb is burned out. Would something like this be in a wiring schematic?
-T
2003 SR5 V8 AWD - Imperial Jade Mica
3" Revtek Spacer Lift sitting on 285.60.18 Nitto Terra Grapplers
Kenwood 7120 DVD/Nav - K&N Intake - TRD Exhaust
10-04-2004, 05:40 PM
Actually these were pretty easy. The map lights I used the 3mm ones, I wasn't sure if the 5mm would be too tall, and would hit the lens or not. I think the rating on the 3mm's were 12-15000 mcd.
The doors I used 3 5mm, and they work pretty good.
10-04-2004, 05:46 PM
That I'm not sure? I also thought about doing the turn signals and break lights. It sure would look good!!
Another LED mod I would like to experiment with would be with the foglights.
I found on the net a guy who converted a 9006 connector to hold 4 10mm LEDs
see here
I would like to try this using the 5mm LEDs. Try and get at lest 5-6 LEDs maybe more if possible.
I want to do this, but I know it just won't be bright enough to even bother with, but yet there is that part of me that want to waste an afternoon and give it a try
10-05-2004, 09:25 AM
I purchased a battery power soldering iron called Iso-Tip. It is great not having a power cord following you around when working inside of vehicles. It works great. My other soldering iron is an adjustable Weller varing temp. model.
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
10-07-2004, 09:06 PM
You guys rock.
Ok, I had some LEDS for my brake lights in my 93 (keep in mind it has no high-mounted center brake light). I took them out because when I had the headlights on and pressed the brake pedal, it wasn't a very significant change in the appearance of the light. It changed patterns and if you weren't watching carefully, it wasn't a very noticable change ( it resulted in a lot of screaching tires behind me, especially at dusk).
Does anyone know of a LED brand that changes intensity instead of pattern? I miss having them.
AEKDB
10-15-2004, 06:36 PM
That looks really good. Has anyone done LED work to a 3rd Gen? I know my parking bulbs aren't the wedge-shape. Right now I have the stock turn signal bulbs and amber colored parking light bulbs. Both lights have been replaced with clear ones though, so it doesn't look like I want it to. I want both to be a good amber color. The current parking bulbs are kind of a light, cheap looking orange.
2006 SR5 V6 4WD
KF5KRC
OME 885 front, Icon/Superflex rear, LR UCAs, Demello bumper, Stubbs HD-SKO sliders, RCI skids, 285/75R16 Duratracs on Level8 MK6 wheels, Uniden Pro520xl w/ FireStik II, Kenwood TM-281A ham, Extra 12V outlets, Limited Grille, Fog Light Mod, Map Light Mod, exhaust chopped
11-04-2004, 02:16 AM
Try these guys for Brake light bulbs, they are for motorcycles and are very high quality.
Radiantz Inc
Custom Dynamics
Read this review, again bike related. He talks about how all LED's are not created equal. I think we need to pay heed to this advise.
LED ARticle wiht pictures and camparison
04 4Runner Limited V8, NV, SR, GY, RF, HP, P9, Z1, E5, XM Radio, BlueTooth Wireless, OME Lift 885/896, 285/70/17 (had 265/70's), SpiderTrax Spacers, K&N FIPK, Magnaflow exh, Shrock Bumper, Warn XD9k, Blitz 240 lights
http://www.toyota120.com/forum/showthread.php?t=2156
06-12-2005, 02:29 PM
Re: My LED Project
You gave this website: http://autolumination.com/festoon.htm
There I found: "Festoon Dome LED Light Bulbs". If I'll buy one of this dome LED bulbs, do I still need to get a resistor, or they will work with 12v?
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
