05-15-2011, 08:25 AM
#136
drill/tap the frame holes for 3/8's. Mounted using grade 8 3/8x1" with flat and lock washers. There is quite a bit of wobble, so I'm going to put a hood stop under the mount on either side and have it lang on the black part of the bumper under the hood.
05-15-2011, 01:41 PM
#137
@lonesouth.
you should go to pepboys and get some of those end link bushings(under $20) like i did. it helps with the wobble effect...not 100% but certainly helps dampen the vibrations of steel on steel. I am going to make a piece that goes diagonal between the two bars to stiffen it up a bit more also.
good work.
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
05-15-2011, 02:57 PM
#138
thanks for the idea! I'm talking about right under the lip of the hood. I'll drill the bracket and install an adjustable hood stop that will rest on the top of the bumper. Hopefully, that will be enough to stop the wagging.
Right now I have a suction cup under one side and a piece of cooling hose under the other.
05-15-2011, 05:09 PM
#139
never thought about suction cups. pretty clever
10-21-2011, 12:42 AM
#140
Had mine welded. Mounts cut and creased to not bend under pressure. Labor done by Iron Pig over a year ago. Great Job!
2004 Limited 4x4 | OME Heavy Duty w/Diff Drop | Rola Roof Rack - Extended | Hella 700 Bottom and 500 Top - Hella Rear Fog Lights | 285/70/17 Tires | Built In Headrest DVD Monitors | iPod Adapter | Viper Remote Start | K&N Air Filter | LED Interior and Exterior Swap | High Lift | 1.5 Wheel Spacer | Full Size (duplicate) Spare | Rear tire carrier | DO Front Bumper. Still a long way to go to catch up to a lot of you on here.
05-05-2012, 10:42 AM
#141
Where are those Hella lights manufactured? I've been looking for some American made offroad lights, but can't find many for a good price.
05-05-2012, 11:03 AM
#142
Good quality Hella lights are made in Germany. Mexican are not that good.
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
01-01-2013, 12:48 PM
#143
Registered User
Real Name: Morris
Registered User
Real Name: Morris
I had removed my lights a while back. I was cleaning out the garage and came across them yesterday. Decided to throw them back on for the hell of it
01-27-2013, 10:42 PM
#144
If anyone is interested in my brackets that I used to have installed, you can have them for free, just pay shipping.
Let me know or I'll scrap them, Ive have a Defiant bar for the past 4 years
2003 Limited 4WD V6
OME W/Toytec Topout, LR UCA's, 255/80R17 BFG KM2's, Defiant LB, Viair OBA W/Mack Horn, Tundra Split Spokes, Wet Okoles, 5% Tint, K&N CAI, and various other additions
06-11-2013, 10:34 PM
#145
I know I'm only a few months late on this post but do you still have the brackets? I'm interested in doing this but don't have to have any of the right tools to do it myself
07-05-2015, 08:59 PM
#146
im thinking of doing this but installing nutserts/rivnuts to make things as simple as installing a bolt
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
10-16-2016, 12:46 PM
#147
Real Name: William Teichroeb
This will have to be my next mod
Thanks so much for all the info guys. Was looking around quite a bit for a solution to moung some auxiliary lights on my 4runner. defiant doesn't appear to be around anymore, those front licence plate light holders don't look like they'd work with our plastic front licence plate mounts, and I don't want a 32" LED lightbar up front. This looks like one of my few viable options. I do think , at least in my mind that if we added a "knee brace" type 45 degree support to another right able bend going up, that the vibration would be lessoned.....going to see if I can find a local fabrication shop to make me 2 of what I'm talking about and I will post pictures when I'm done. This mod probably won't be done for a few months, as I won't be able to afford all the stuff at once. Was looking at some lights by black oak LED, all the reviews of them seem awesome and I spoke to a rep who was super helpful.
HTML code is Off
