Old 05-05-2011, 07:33 PM #16
moxley's Avatar
moxley moxley is offline
moxley is on a distinguished road
moxley's Avatar
Subscribing to this... I am looking at the Icon stage 1 to replace my XREAS this summer.
2004 White 4Runner Sport V8 4x4 - Toytec Boss lift, 1.5 inch BL, Light Racing UCA's, 285.70.17 GY Duratracs on 17x9 Fuel Hostage.
moxley is offline   Reply With QuoteReply With Quote
Old 05-05-2011, 09:18 PM #17
BlairB's Avatar
BlairB BlairB is offline
Real Name: Blair
BlairB will become famous soon enough
BlairB's Avatar
Real Name: Blair
Originally Posted by TraumaHawk View Post
Using the ICON coilover front shocks and adding the items use list, the spring coils will not support the weight. With the ICONS fully adjusted out to 2 1/8" your maximum lift will be 2".
I think the max lift comment does not apply to 4th gens. I know a few 4th gen guys with bumpers, winches etc... that run Icon and get the full 3 inches of lift.
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
BlairB is offline   Reply With QuoteReply With Quote
Old 05-05-2011, 11:04 PM #18
TraumaHawk's Avatar
TraumaHawk TraumaHawk is offline
TraumaHawk is on a distinguished road
TraumaHawk's Avatar
The generation does not matter. A prerunner style bumper with a winch works OK, but according to the accessories that are listed, a 118lb Shrockworks bumper, a 40lb winch and solenoid, 10lbs of custom copper length 2/0 winch power cables, a 20lb roller fairlead, 15lbs of steel winch cable, 10lbs of fog and driving lights, a 48lb battery (dual batteries or single Optima), 80lbs of front and transmission under armor, 50 to 70lbs of sliders and that 400lbs of extra weight becomes a serious issue. ICON front coilover springs are 13.5" long and are rated for 650lbs max. ICON coilovers can not be adjusted out farther than 2 1/8" of thread showing to achieve more lift and overcome the weight. If pushed past that point then the shock tube buckles. ICON states that the shock springs can not handle that much weight and that they do not offer a higher spring weight capacity of 650 lbs for the Toyota. The ideal weight is no more than 250lbs of accessories to still achieve 3" inches of workable lift, after that the 3" starts to decrease. ICON highly does not recommend the use of spacers as this has adverse affects on the dynamics of the behavior of the shock/coil spring.
COMO CHINGAS OFF ROAD
AAT: Senior Trail Advisor, Lower Larga 2N06X - USDA Forest Service
TraumaHawk is offline   Reply With QuoteReply With Quote
Old 05-06-2011, 03:43 AM #19
magert54's Avatar
magert54 magert54 is offline
magert54 is on a distinguished road
magert54's Avatar
Ok, so get stage one then right?
I have been reading around and herd many testimonies about people replacing the rear coil with the piggyback saying its better. also a 1.25"-1.5" BL should not affect the ride of ICON should it?
As for the UCA, ICON has the cover over the bearing to protect it from debris (selling point for me). Does camburg offer anything like that?
Rar, Its my DD but i tend to take it off-road in colorado. I wish to be able tackle mid level trails with minor issues. I have no intention of dessert running so i wont have the overheating issue you speak of i think.
2006 4.7L V8 SE
Build Thread Colorado
magert54 is offline   Reply With QuoteReply With Quote
Old 05-29-2011, 12:48 PM #20
magert54's Avatar
magert54's Avatar
?Bumpered
2006 4.7L V8 SE
Old 06-04-2011, 10:52 PM #21
magert54's Avatar
magert54's Avatar
Rar, SuperBump anyone have suggestions?
2006 4.7L V8 SE
Old 06-05-2011, 12:19 AM #22
darkie3495's Avatar
darkie3495 darkie3495 is offline
Moderator
darkie3495 will become famous soon enough
Moderator
darkie3495's Avatar
Piggybacks may not be needed for your application unless you plan to carry more weight in the back and plan to stick with icon.
You shouldnt feel any negative affects with a BL and the icon setup. A lot of people run the combo with no complaints.
Icon is the only one that offers a cover IIRC. The cap covers the top but debris still get in from the bottom. Just remember, if you do get the icons, you still need to clean it off from time to time or else you'll end up having to replace the bearing (speaking from experience).
Have you considered light racing uca?
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
darkie3495 is offline   Reply With QuoteReply With Quote
Old 06-06-2011, 06:45 PM #23
magert54's Avatar
magert54's Avatar
First off let me thank you soooo much for answering my question. Ive been looking for the past couple weeks for an answer.
Light racing UCA.
Ive been hearing and seeing people get them and I want to go with the all ICON look. ICON UCA are a selling the idea that they have a debris cover on the top. Well with that said i feel more comfortable going with it. I clean my truck after every off road excursion, so maybe light racing uca is the right choice and they might be cheaper. Im on the line now talking about it.
2006 4.7L V8 SE
Old 06-06-2011, 07:48 PM #24
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
Light racing UCA.
No worries.
I hear you about getting the full set. I didn't want to deter you from getting the ICON's..far from it. just wanted to call out that the cap doesn't keep everything out. If you clean your truck everytime, then you'll be fine. A few drops of Finish Line Dry teflon lube every few months and you'll keep them happy and squeak free.
Light Racing UCA are definitely cheaper. They are sealed so you won't need to maintain them and they won't squeak.
Old 06-06-2011, 09:29 PM #25
Overland Warehouse Overland Warehouse is offline
Overland Warehouse is on a distinguished road
In relation to concerns over weight carrying, our coilovers can be supplied with 700lb springs. This is the most common spring for those people carrying significant weight. Alternatively a 650lb spring works great for the lightly modded truck.
To the OP - sounds like you should go for a 2.0 system that you can adjust from 0-3" of lift. Make sure to purchase a system that is valved correctly for your intended weight carrying and use, otherwise you may find yourself throwing good money after bad.
Try to think long term. Cheaper systems might meet a budget now, but down the track you might find yourself investing in a better setup and that can be frustrating. Also we recommend you consider rebuildable shocks. All parts have a need for some TLC at some stage. Its nice to be able to simply rebuild rather than buy a whole new setup.
Just some thoughts.
Regards
Mark
Overland Warehouse is offline   Reply With QuoteReply With Quote
Old 06-15-2011, 01:50 AM #26
magert54's Avatar
magert54's Avatar
Thanks everyone for you help and advise
2006 4.7L V8 SE
Old 12-05-2015, 07:19 PM #27
10010110's Avatar
10010110 10010110 is offline
Real Name: ASWANG RUNNER
10010110 is on a distinguished road
10010110's Avatar
Icon for overland
What stage do you guys recomend for overland trips?
10010110 is offline   Reply With QuoteReply With Quote
Old 12-07-2015, 10:41 PM #28
Rocket61's Avatar
Rocket61 Rocket61 is offline
Rocket61 is on a distinguished road
Rocket61's Avatar
I had the rear v2's for less than a year before they started leaking. Also did not like how the digressive valving performed for daily driving over pot holes and speed bumps. Wouldn't buy again.
White 2017 TRD Pro
Black 2007 Limited V6 4WD - Sold
Rocket61 is offline   Reply With QuoteReply With Quote
Old 12-09-2015, 12:45 PM #29
Randyosb Randyosb is offline
Randyosb is on a distinguished road
I have the Icon Stage 1 and I love it. I am sure there are cheaper options-but I don't have much of a background in this stuff so I went with what seemed to be the best.
Only had it a few weeks so have not been off-road much. But great for inner-city rock crawling...and with the terrible roads and construction projects in Dallas there is lots of opportunity for that.
Randyosb is offline   Reply With QuoteReply With Quote
Old 12-17-2015, 09:55 PM #30
TheRealT-Dawg's Avatar
TheRealT-Dawg TheRealT-Dawg is offline
TheRealT-Dawg is on a distinguished road
i need some suggestions on this as well... my 05 2wd limited is going to be a pre runner eventually, so what are good mid travel/long travel rear shocks?
i specifically need rear shocks now because currently i have a spindel lift in the front with stock springs and bilstien 4600(i think)... the rear has the same bilstiens but i recently added toytec 2.0 HD springs and i think they are maxing out travel really bad... even the smallest bump i can hear and feel it "thuding" unless i go really slow lol...
2005 Toyota 4Runner Limited 2wd (Future PreRunner)
TheRealT-Dawg is offline   Reply With QuoteReply With Quote
HTML code is Off
