Old 04-18-2010, 07:00 PM #1
ZoomSpeed ZoomSpeed is offline
ZoomSpeed is on a distinguished road
Big 3 Ground points?
I'm about to do the Big 3 upgrade on my 2001 4Runner. 2 of them look pretty easy to get to (ground right next to the battery and alternator to battery positive), but I can't find the last ground point. It comes off the battery negative, then it gets wrapped up with some other wires and then goes down and disappears somewhere.
Is there another spot that I can ground to thats easy to reach?
2001 SR5 4WD Supercharged
ZoomSpeed is offline   Reply With QuoteReply With Quote
Old 04-18-2010, 09:21 PM #2
CajunRunner's Avatar
CajunRunner CajunRunner is offline
CajunRunner is on a distinguished road
I'm not sure where that other ground wire goes once it integrates with the wire harness, but the third ground point is actually on the back of the engine block to the firewall. Here is a picture looking from the passenger's side at the back of the engine block. You can see the bolt, the original (small) ground wire, and my 2 gauge ground wire covered with black loom. I added the 2 gauge ground and kept the factory ground wire intact.
Big 3 Ground points?-blk-grnd-1-jpg
I ran the new engine block ground cable to the passenger's fender wall and attached it with a ground terminal screwed into an existing, unused bolt hole.
Big 3 Ground points?-blk-grnd-2-jpg
1997 4Runner SR5 V6 4X4 290,000 miles
Audio: Alpine/JL/Dynamat
Electrical: Optima Red Top, 2 of the Big 3, NGK TE66 spark cables
Performance: Elbow Mod, AIRAID MIT, SS 3.0
CajunRunner is offline   Reply With QuoteReply With Quote
Old 04-18-2010, 09:54 PM #3
Perfect! Thanks for the pics.
Old 04-19-2010, 04:23 AM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
remember to remove all paint on the ground point, also ground an extra wire from the neg bat to engine, then to the frame itself, there should a bolt right by the brakets on the brake lines. remeber the body and frame are two different things.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 04-24-2010, 11:14 PM #5
crooper crooper is offline
crooper is an unknown quantity at this point
I did the big 3 with 4 awg wire in my Maxima and noticed absolutely no difference in stereo performance or headlight dimming (I had about 700 watts total with 4 components and 2 subs). Best part was being able to say "I did the big 3 wire thing! Check out those big wires!" I won't be doing this in my 4Runner, not worth the hassle.
2008 SR5 V6 4x4 - Nautical Blue - 3rd row seats
Mods: Energy polyurethane bushings... so yeah pretty much stock
crooper is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 10:52 AM #6
Treestand_Twerkers Treestand_Twerkers is offline
Treestand_Twerkers is on a distinguished road
I believe one of the grounding wires from NEG that goes down thru the wiring loom goes to a spot on the oilpan right under the oil filter. 14mm bolt.
Treestand_Twerkers is offline   Reply With QuoteReply With Quote
Old 05-12-2022, 06:26 PM #7
lewball lewball is offline
lewball is on a distinguished road
Correct, it’s a 12mm bolt. Ya can reach it from under the vehicle (point your ratchet towards the front & ya have enough swing to get it out & back in… if ya can’t get under the vehicle, then ya can reach it through the flap behind the drivers front tire flap that ya use to change the oil filter.
lewball is offline   Reply With QuoteReply With Quote
Old 05-12-2022, 06:36 PM #8
Grounds for the dash components
Just replaced both head gaskets.
Now I don’t have any dash components that work:
1) radio
2) Gauges
3) blinkers
4) climate controls (Heat & A/C)
5) door locks
6) window controls
Lights, horn, ‘Key in ignition’ beeper, Headlights, & Dome lights all work.
I can start the engine by going from the battery positive to the starter relay (odd of the 4) connector. I also get 12.6 volts through the 10 amp fuse under the dash.
I don’t have a ground going from the engine block to the firewall and pretty sure there wasn’t one previously. Ground by the oil filter is clean & tight, battery to firewall same. Alternator ground same. Diagnosis connector same…
HELP PLEASE
HTML code is Off
