Old 02-05-2012, 12:24 PM #91
DragonRunner DragonRunner is offline
DragonRunner will become famous soon enough
Been a while, I know. I want to tap the ILE at the dome overhead and just run a short wire forward to the maplights. I know the ILE is pin 2, solid white... But I've got to harnesses connected to the dome (I have a 2004 Sport with JBL Synthesis and wireless headphone option) and don't know which pin is which. LOTS of solid whites in these harnesses. Anyone have a pic or a good way to test for the right pin?
‘18 White ORP w/ KDSS; Shrockworks sliders; Method MR701s + Falken AT3W 265/70/17 SL; Bilstein 6112/5160s; OrangeBoxx MOLLE panel (R); GOBI rack & ladder; Morimoto Elite HIDs (50W 5500k); Infinity REF 3032 3.5” speakers (dash location)
DragonRunner is offline   Reply With QuoteReply With Quote
Old 08-16-2012, 08:55 PM #92
4boer2's Avatar
4boer2 4boer2 is offline
4boer2 is on a distinguished road
4boer2's Avatar
Hello all, I just completed this mod and everything went smoothly. However the map light console is much looser than when I took it off. Did I bend a clip? If so, does anyone have a part number for those? I might just epoxy it to the head liner.
4boer2 is offline   Reply With QuoteReply With Quote
Old 05-28-2013, 11:40 PM #93
Dennx Dennx is offline
Dennx is on a distinguished road
2007 T4R. I want to make sure I have the correct wires to tap into. Here's a pic of the 3-ribbon blue-striped wire at the fuse box. I tap the middle wire, correct?
Dennx is offline   Reply With QuoteReply With Quote
Old 05-29-2013, 11:28 AM #94
Bumping.
My Photos - My Biz - My Build - FJ Cruiser Corps
Old 05-30-2013, 03:59 PM #95
Bumping again.
Old 08-21-2013, 03:06 PM #96
I did this mod and all is good with the wife now ;)
Old 10-19-2013, 09:14 AM #97
satanos6668280's Avatar
satanos6668280 satanos6668280 is offline
Real Name: George
satanos6668280 is on a distinguished road
Real Name: George
did this mod yesterday but i ran a wire from the switched ground on the center dome to the grounds on the front map lights so whenever the dome comes on the maps would too but didnt like that both maps would light if one was switched on so i added 2 small diodes to back and now when the door is opened or the center dome is switched on all the lights work but you can also use each map light individually now its the way it should have been from the factory
04 limited v6 4wd 6" rough country fj lift pn#770s 35 12.5 17 wrangler mtr tire method 17 8.5 fat five rims
satanos6668280 is offline   Reply With QuoteReply With Quote
Old 10-21-2013, 04:01 PM #98
matthewkristof's Avatar
matthewkristof matthewkristof is offline
matthewkristof is on a distinguished road
So it was the middle wire in the 3 wire bundle?
Still need to do this mod
2007 SE, Galactic Grey Mica - original owner
Mods/Upgrades: Oh Crap Handle on driver's side, Hilux Surf Trash Stash, Amber Colored Auto-Dimming Mirror w/compass, USB ports using 115V switch, LED interior, Weathertech Digital Floor Liners, Homelink Garage Door Opener, Footwell Lighting, Automatic Headlights, Dual Cargo Organizers, Maplight Mod, Morimoto 5k HID Low-Beam and Fogs, LED exterior, 15% 3M tint, AVIC-6100nex, Pioneer speakers (TS-G1345R, TS-G1645R, TS-T110), Limited Grill, Mini Backseat Organizer, Heated Cloth Seats, KO2s
matthewkristof is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 04:57 PM #99
c_mack9's Avatar
c_mack9 c_mack9 is offline
c_mack9 is on a distinguished road
c_mack9's Avatar
Trying to read through this isn't easy for someone that has never done this, and the blurry pics from 2005 don't help either. Has anyone simplified this mod yet? I'd like to do it but the OP seems risky so I'd like to be 100% clear on what I need to do before I begin.
Originally Posted by LTDSC View Post
I always wondered how big yours in compared to mine because I think it looks huge
c_mack9 is offline   Reply With QuoteReply With Quote
Old 10-13-2016, 05:46 PM #100
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
Bump and +1 rep for an old thread!
It's been darker in the mornings now with fall here and not having the front of the cabin light up sucks. 10 mins, a couple feet of 18g wire and a 2 wire taps did the trick!
I didn't bother to remove the A Pillar trim. From the map lights, I just ran the wire to the door, tucked it under the top of the A Pillar plastic trim, ran it down the weather stripping, and tapped into the fuse box connector. Once you have all that figured out and done, just tuck the exposed wiring along the windshield into the headliner.
Thanks again!
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 06:46 AM #101
Denise James Denise James is offline
Denise James is on a distinguished road
"You can even get to know yourself better, courtesy of the local handwriting analysts. .... Let it turn the generator and have it run on electricity" Now, I like an SUV, but I ..... CAMBIUM PTP BACKHAUL assists residents with everything from party planning to personal training. .... very light yellow — for the interior of the train that will take people to the park.
Denise James is offline   Reply With QuoteReply With Quote
HTML code is Off
Past 4th gen owner, now a 3rd gen owner...3rd row on 4th gen? 2000runr 4th Gen T4Rs 12 03-16-2014 09:12 PM
3rd Gen vs. 4th Gen domstriker 4th Gen T4Rs 20 01-17-2011 09:13 PM
4th Gen Hilux Surf Mod Gallery Luxury Gallery 252 06-27-2007 10:25 AM
Fog light mod on 4th gen?? BlkSS1755 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 02-01-2004 08:07 PM
