02-05-2012, 12:24 PM
#91
Been a while, I know. I want to tap the ILE at the dome overhead and just run a short wire forward to the maplights. I know the ILE is pin 2, solid white... But I've got to harnesses connected to the dome (I have a 2004 Sport with JBL Synthesis and wireless headphone option) and don't know which pin is which. LOTS of solid whites in these harnesses. Anyone have a pic or a good way to test for the right pin?
‘18 White ORP w/ KDSS; Shrockworks sliders; Method MR701s + Falken AT3W 265/70/17 SL; Bilstein 6112/5160s; OrangeBoxx MOLLE panel (R); GOBI rack & ladder; Morimoto Elite HIDs (50W 5500k); Infinity REF 3032 3.5” speakers (dash location)
08-16-2012, 08:55 PM
#92
Hello all, I just completed this mod and everything went smoothly. However the map light console is much looser than when I took it off. Did I bend a clip? If so, does anyone have a part number for those? I might just epoxy it to the head liner.
05-28-2013, 11:40 PM
#93
2007 T4R. I want to make sure I have the correct wires to tap into. Here's a pic of the 3-ribbon blue-striped wire at the fuse box. I tap the middle wire, correct?
05-29-2013, 11:28 AM
#94
Bumping.
05-30-2013, 03:59 PM
#95
Bumping again.
08-21-2013, 03:06 PM
#96
I did this mod and all is good with the wife now ;)
10-19-2013, 09:14 AM
#97
Real Name: George
Real Name: George
did this mod yesterday but i ran a wire from the switched ground on the center dome to the grounds on the front map lights so whenever the dome comes on the maps would too but didnt like that both maps would light if one was switched on so i added 2 small diodes to back and now when the door is opened or the center dome is switched on all the lights work but you can also use each map light individually now its the way it should have been from the factory
04 limited v6 4wd 6" rough country fj lift pn#770s 35 12.5 17 wrangler mtr tire method 17 8.5 fat five rims
10-21-2013, 04:01 PM
#98
So it was the middle wire in the 3 wire bundle?
Still need to do this mod
2007 SE, Galactic Grey Mica - original owner
Mods/Upgrades: Oh Crap Handle on driver's side, Hilux Surf Trash Stash, Amber Colored Auto-Dimming Mirror w/compass, USB ports using 115V switch, LED interior, Weathertech Digital Floor Liners, Homelink Garage Door Opener, Footwell Lighting, Automatic Headlights, Dual Cargo Organizers, Maplight Mod, Morimoto 5k HID Low-Beam and Fogs, LED exterior, 15% 3M tint, AVIC-6100nex, Pioneer speakers (TS-G1345R, TS-G1645R, TS-T110), Limited Grill, Mini Backseat Organizer, Heated Cloth Seats, KO2s
04-02-2014, 04:57 PM
#99
Trying to read through this isn't easy for someone that has never done this, and the blurry pics from 2005 don't help either. Has anyone simplified this mod yet? I'd like to do it but the OP seems risky so I'd like to be 100% clear on what I need to do before I begin.
Originally Posted by LTDSC
I always wondered how big yours in compared to mine because I think it looks huge
10-13-2016, 05:46 PM
#100
Bump and +1 rep for an old thread!
It's been darker in the mornings now with fall here and not having the front of the cabin light up sucks. 10 mins, a couple feet of 18g wire and a 2 wire taps did the trick!
I didn't bother to remove the A Pillar trim. From the map lights, I just ran the wire to the door, tucked it under the top of the A Pillar plastic trim, ran it down the weather stripping, and tapped into the fuse box connector. Once you have all that figured out and done, just tuck the exposed wiring along the windshield into the headliner.
Thanks again!
07 T4R Sport Edition V6 4x4
10-18-2019, 06:46 AM
#101
"You can even get to know yourself better, courtesy of the local handwriting analysts. .... Let it turn the generator and have it run on electricity" Now, I like an SUV, but I ..... CAMBIUM PTP BACKHAUL assists residents with everything from party planning to personal training. .... very light yellow — for the interior of the train that will take people to the park.
HTML code is Off
