Originally Posted by rvcahawaii808
i have always kind of veered away from spacers...simply because over at tw they have a bad rep. any recomendation on a spacer? (how it affects ride, etc)
also how does the 4runner handle without the XREAS is it a big deal?
on a side note...is 3" of lift the max without aftermarket UCAs? before i kill my cvs
I think spacers get a bad rep when it is not deserved. I wheeled the hell out of my truck for a long time on spacers without a problem. Clearly the bigger the spacer the more it will change your right. I had Cornfed, and people have also had great success with Daystar. Another option you can look into is putting FJ Cruiser springs in the front. If you are a V6, it will give you about 3/4" of lift in the front and when you combine that with a small spacer it does not change your ride much.
How it handles without xreas really depends on what suspension you go for... my coilovers are firmer than the factory suspension so I notice no difference.
In general 3" in the max you can do without UCA's, I would not go above 3.5" even with UCA's. Aside from UCA's and CV's if you go past that amount of lift the suspension will not have the right amount of downtravel left and it can really hurt your ride, especially if you off road. You want a nice balance of uptravel and downtravel in the front suspension. It is almost identical to Tacoma front suspension.
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig
Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
