11-28-2010, 08:23 PM
Lift questions
I have a 2005 4Runner SR5 4WD and was wondering what I needed to get or what I should look into if I'm interested in raising my t4r up about 3 or 4 inches. I am considering new tires to compliment the lift as well. Wheels are not such a big deal.
I have currently have 265/65/17 stock wheels and tires, as well as stock lift at the moment.
Appreciate all the help I can get.
Kinda limited on budget, so cost is definitely a factor.
11-28-2010, 09:56 PM
to do 4 in. right its gonna cost, the cheapest way to get close to the height u want is a 3/2 spacer lift, or the spacer & rear coils, about 200 - 300 depending on where u get it. next upgrade step is 400, then 770, then 1200,etc. heres a page to check out the differences & prices. Complete Lift Kits - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
11-29-2010, 10:06 PM
Thanks! Never done anything to this 4runner so I'm knew to this whole process, but gotta start somewhere
11-30-2010, 12:11 AM
like chaz said, for 200-300 you will get your 3" +/- and anything over that is going to cost you. it becomes a whole different ball game then.
doing a spacer lift such as the cornfed 3/2 or daystar 2.5/1.5 is not a big ordeal as long as you have some basic tools and about 4-6 hours to do it. I have done 3 lifts and I am far from a mechanic but they were all pretty easy to do.
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
12-06-2010, 01:13 AM
I dont know anything about lifts for the new runners but If you want a cheap and good mud terrain tire, look into the BFGoodrich KM2's. They're quiet on the road and they will not slip off road. great reviews all around. I ordered a set of 35"s for $178 a tire. 3inch lift on your truck could probly fit 32"s maybe 33"s with a little rub but I dont know
85 runner- 35" KM2's, 4.88 gears, spool rear, lockrite front, longfields, chevy springs dual shackles, dual cases with 4.7 gear.
My runners like a panhandlers cup: I just dump money into it and hope 4 the best
12-06-2010, 02:12 AM
Real Name: Ervin
Real Name: Ervin
I agree with the KM2's...they're not unbearably loud on road and off road?....awesome! 3" of lift will definitely tuck 'em in but not without minor trimming and pounding....A 1" BL will solve that issue.
97 4Runner SR5 TRDSC URD Yukon Camburg Toytec Trekmaster 4Crawler SonoranSteel Level8 Nitto SavageOff-Road ARB Smittybilt MasterPull Powertank SpiderTrax B&M Jaos Gobi Flowmaster Cobra Firestik Alpine CompuStar Hella PIAA RigidIndustries WeatherTech
my build http://www.toyota-4runner.org/3rd-ge...formation.html July 2012 T4RoTM / 2012 T4RoTY
12-09-2010, 06:33 PM
Not that hard really.
3 inch spring or spacer
1.5 inch body lift
35" tire (2" lift)
On the front I have ome 3" springs, 5100's aswell with the height adjusted to the 3 from the bottom setting, LR UCAs, sway bar brackets, and a diff drop.
On the back I have toytec springs, 5100s, 1.25" cornfed spacer, airlift 1000.
I have the 1.5bl and I measured 7" taller at the fender then stock
December '08 T4ROTM
http://www.toyota-4runner.org/showth...threadid=43414
2004 Limited 4WD V8
12-10-2010, 02:55 PM
Do 2.5 suspension ($150 - 300) with whatever combo of spacers, coils, etc...., then 1.5 body lift ($150). That will allow up to 33" tires with no rubbing and give you a very aggressive stance. Good luck.
02 Limited 4wd: Procomp MT's, Black Cragar Soft 8 wheels, 1.5 body lift, OME 891 rear coils, BudBuilt skid plate, 1" diff drop, custom made bumper, sliders, Rancho Quiklift system front and RS9000XL's rear, EBC pads and rotors, KC SlimLites, Smittybilt XRC8, 1.5 wheel spacers, SONY XPLOD double din cd/receiver with 280 watt spkrs.
"There is no hunting like the hunting of man, and those that have hunted armed men long enough, never care to do anything else." Ernest Hemingway
HTML code is Off
