01-30-2005, 04:39 AM
"true" dual exshust (header back) any one?
Has any body done or tryed thid yet?
headers, H/Y pipe, mufflers, tips??? may be a couple cats if you realy wanted???
former owner
06-08-2005, 11:25 AM
4Runner Dual Exhausts
RXvedub and evryone else, haven't done it yet but here is what I did to my Tundra and it looks, works and sounds great.
Go to JC Whitney.com buy a dual in/dual out catalytic converter about $129 on sale, 2" in and out. Go to Sumitt and but Two Dynomax Super Hemi Turbo mufflers, 2" in and out, case should be 20-21" long, biggest they have.
Go to your local muffler shop have the "resenator" removed and weld in the converter, from there with 2" pipe out side by side, weld in the Hemi mufflers, pipes out over the axle out to one side, or one on each side.
I have this exact set up on my 2000 V-8 Tundra. It works great, no loss of torque and the sound is mellow until you get on it, then it sounds like a Mustang GT.....paid approx $500 for ALL. good luck, I will be doing this to my 03 4Runner soon. CSM-H
CSM-H
2005 SR5, DC V-8 Tundra
2006 Harley FHLT
guns, lots of guns
06-08-2005, 11:42 AM
Super Moderator
Super Moderator
Remember that your stock exahaust is stainless and you should spend the extra $$$ on stainless replacement pieces or the exhaust will just fall off the truck.
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
06-08-2005, 06:57 PM
Re: 4Runner Dual Exhausts
why not use the stock converters? I doubt any muffler shop will cut off your stock cat converters. Isnt it against the law or something?
Or are you saying in addition to the stock cats, use the JC whitney cats?
im confused
2006 Limited V-8 4WD Nautical Blue 122k and counting.
265/65R18 LT BFG All Terrains, ICON Stage 1, SpiderTraxx, WeatherTech Liners, Demello Hybrid Sliders Kenwood DNX-890HD.
06-09-2005, 12:04 PM
the stock cats are on the headers, the cat we are talking about is a third cat with no Oxegen Sensor behind it, so I dont think that will affect it.
former owner
06-09-2005, 12:11 PM
I bet you could take that one off. hmmm. maybe after its outta warranty. I can just imagine going to the dealer for any warrranty work with a true custom exhaust and missing a cat converter. They would shit a brick and use it as an excuse to not warranty anything! You know they would...
06-10-2005, 11:58 AM
Super Moderator
Super Moderator
A lot of exhasut shops are leary of messing with a cat or even replacing it wiht a high flow unit unless you have alot of miles on it and it needs a replacing.
My friend went with a high flow cat to match his header and exhaust on his Type R with 15k on the odo and he went to 4 shops before he found one that would touch it.
2010 Lexus RX350
06-10-2005, 02:57 PM
Real Name: Chris
Real Name: Chris
I think federal law states that you cannot replace a cat unless the vehicle has >50k miles or the cat is damaged. Soooo, take a hammer to it.
2005 4Runner V6 SR5 4x4 Titanium - purchased new in April 2005 - 155k miles
06-11-2005, 09:08 AM
Its actually a federal offense to remove a properly working cat. Although certain shops will do it.
Funny thing is, high flow aftermarket cats are generally better scrubbers than OEM ones alot of times even though their CPSI rating is FAR below that of OEM ones.
Carsound makes some really nice high flow cats as does Random Technologies.
As for warranty work, unless you were to mess with the cats with the 02 sensors, there is little that Toyota could say per warranty given the Magnuson-Moss Act.
The Magnuson-Moss Act
Protecting tweakers, tuners, and other users of aftermarket equipment.
You want to upgrade your vehicle with aftermarket equipment, but you
05 SE V8 4wd Natural White
Magnaflow Exhaust, Toyo Proxes S/T, Volant CAI, Stop Tech F/R SS Brake lines, Axxis Ultimate F/R Pads, Valvoline SynPower Dot4 Fluid, NGK Iridium IX Spark Plugs, Sylvania Silver Star Ultra lights (Lows, Highs, Fogs), Water Wetter, Front 4Runner Sill Protectors, Pioneer DEH-P80MP Deck, Alpine Type-S 6x9F & 6 1/2R, Infinity Bass Link II
06-13-2005, 09:15 AM
Third Cat, "Resonator"
[QUOTE]Originally posted by Casper
[B]Its actually a federal offense to remove a properly working cat. Although certain shops will do it.
CSM-H
2006 Harley FHLT
guns, lots of guns
HTML code is Off
