Old 02-16-2005, 01:41 AM #16
Hitman's Avatar
Hitman Hitman is offline
Hitman is on a distinguished road
Hitman's Avatar
Re: FOG LIGHT
Originally posted by BULECZKA
Hitman, I am interested in doing the mod on thr fogs so they work with my parking lights.....did you do your and did it work, can you send some information
No, I didn't do it on my 4Runner yet.... If I had access to the wiring schematics, I could tell you exactly how to do it.
I'll definitely post a short write-up when I finally get a chance to work on it...
2004 Sport 4x4 Galactic Gray
Hitman is offline   Reply With QuoteReply With Quote
Old 02-16-2005, 11:08 AM #17
Colemanfu's Avatar
Colemanfu Colemanfu is offline
Colemanfu is on a distinguished road
Colemanfu's Avatar
2nd that! I would love to be able to run my fogs with just my parking lights. Just for the cool factor. Now I can run my Lightforce's with my parking light but can only do that in traffice if I have on the yellow covers. And I still get flashed some mornings.
If anyone gets it sorted let us know.
C O L E M A N F U
DAYTONA USA
04 4Runner 4x4 SR5, OME.
Colemanfu is offline   Reply With QuoteReply With Quote
Old 02-21-2005, 06:56 PM #18
Mel Shingleton Mel Shingleton is offline
Mel Shingleton is an unknown quantity at this point
Does anyone know if there is a yellow bulb available for the so-called fog lights. Yellow cuts the fog unlike the white bulbs?
Mel Shingleton is offline   Reply With QuoteReply With Quote
Old 02-21-2005, 10:56 PM #19
Cleric's Avatar
Cleric Cleric is offline
Cleric is on a distinguished road
Cleric's Avatar
Yes, there are a few. Do a search for "yellow fog light" or something similar. There are multiple threads on this subject.
-T
2003 SR5 V8 AWD - Imperial Jade Mica
3" Revtek Spacer Lift sitting on 285.60.18 Nitto Terra Grapplers
Kenwood 7120 DVD/Nav - K&N Intake - TRD Exhaust
Cleric is offline   Reply With QuoteReply With Quote
Old 02-23-2005, 04:47 AM #20
RXvedub's Avatar
RXvedub RXvedub is offline
RXvedub is an unknown quantity at this point
RXvedub's Avatar
I have HID and yellow fog lights. I love it espacialy since i used to be a Lexus tech.
I can get you guys the bulbs Nokya brand... best color... for $40 shipped. I work at a performance shop that sells this stuff.
If you want HIDs let me know.
former owner
RXvedub is offline   Reply With QuoteReply With Quote
Old 02-24-2005, 06:53 PM #21
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
I'm investigating working on this mod to keep the fog light switch on the stalk functional. I need to get to connector C12 at the steering column. Besides obviously removing the lower bolts, how do you remove the drivers side lower dash panel? Does the top of it clip in and how do you get it away from the ignition key area without damaging it?
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 02-24-2005, 10:38 PM #22
ksneubec's Avatar
ksneubec ksneubec is offline
Real Name: Karl
ksneubec is on a distinguished road
ksneubec's Avatar
Real Name: Karl
Another member posted this website, which should hopefully help. If you figure out how to get the fog lights on with only the parking lights, please set up a thread!
http://www.castulucci.com/projects/carpc/oemnaviaccess/
2013 4Runner TE Salsa Red Pearl
My Baby- 2011 Jerez Black Metallic M3
Sold and Missed Dearly:2004 Toyota 4 Runner
ksneubec is offline   Reply With QuoteReply With Quote
Old 02-25-2005, 12:54 AM #23
Kmvreter's Avatar
Kmvreter's Avatar
ksneubec,
Thanks for the link to Randos work.
I'll be working on trying to get the fog lights to work with the current stalk switch but regardless of any other lights on.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-25-2005, 01:24 AM #24
Hitman's Avatar
Hitman's Avatar
Originally posted by Kmvreter
ksneubec,
I have read the wiring schematic for the fog light circuit and the only way to make the foglights work independently of the headlights (and hibeams) with the factory switch is to ground the light blue wire in the combination switch. It is unclear on the schematic whether or not this is actually a wire or just a simple jumper. The connections are labeled 11 and 17 for each side of the light blue wire.
The only way to find out for sure is to remove the the combination switch (C12 - headlights, fog lights and dimmer) and check for the light blue wire. Unfortunately, I have not had time to remove mine to do this mod yet.
Old 02-25-2005, 02:20 AM #25
Kmvreter's Avatar
Kmvreter's Avatar
I'm hoping that when I get to C12 I will be able to take pin #11 to #16 (or any ground) and not #17. Also want to take the fog light relay pin #2 away from the headlight fuse and put it with any other circuit that is hot on ignition (I'm planning to use pin #2 on the unused power inverter circuit). I might have to also use a diode in this line if I can't isolate it. All this last stuff should be easy to do in the engine bay fuse box. Keep you posted.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-25-2005, 02:27 AM #26
Hitman's Avatar
Hitman's Avatar
16 is the ground wire for the combination switch. It goes to J15 (junction connector) and then directly to a chassis ground in the kick panel.
That will give you power to the fog light relay any time the ignition switch is on, but you'll still need to ground the combination switch in order for the original switch to control the foglights. If you end up pulling out the combination switch, snap a picture or two... I'd love to see what the wiring looks like.
Old 02-25-2005, 03:16 AM #27
Kmvreter's Avatar
Kmvreter's Avatar
Yes, it's a 2 part mod: switch grounding and power source. I have the wiring diagrams. Hopefully I can get to it on the w/e if I find time.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-25-2005, 10:58 AM #28
Kmvreter's Avatar
Kmvreter's Avatar
I need to get at connector C12 but was looking in the wrong location. It isn't under the lower dash but actually is on the steering column. Here's the catch: how do you get the steering column cover assembly apart? I took out the bottom screw and some of it clips apart but it won't come apart at the steering wheel end. Are there more screws hidden by the steering wheel?
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 02-25-2005, 02:46 PM #29
RXvedub's Avatar
RXvedub's Avatar
turn the stearing wheel to the left, then right. there are 2 screw behing the wheel its self
former owner
Old 02-25-2005, 08:54 PM #30
RXvedub's Avatar
RXvedub's Avatar
DONE... I am putting a write up together with pics. Please hold for further assistance.
I got it to stay on with high beems and key on position. 2 Step process
former owner
HTML code is Off
fog light aiming and new fog/driving lights digphisher Engines / Suspension / Wheels / Tires / Audio / Accessories 54 01-15-2023 03:35 PM
fog lights PioneerMeta4 3rd gen T4Rs 14 05-30-2008 11:15 PM
OEM Fog Lights in Facia Speedy 3rd gen T4Rs 12 10-11-2006 05:26 PM
Fog lights install without a lot of info. Iman74 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 08-04-2006 08:17 AM
2003 4Runner fog lights question? testrider 4th Gen T4Rs 3 03-28-2003 04:15 PM
