Old 04-30-2011, 07:40 PM #1
747ifly's Avatar
747ifly 747ifly is offline
747ifly is on a distinguished road
747ifly's Avatar
pics of my stereo install
Just posting some pics of my stereo system and so forth. Kinda interesting.
Pioneer avicf900bt, Focal krx2, JL hd6004, JL hd7501, JL zr8, JL 10w6v3, 2 kinetik batteries, isolator, 2000 watt marine ac/dc inverter, viper alarm remote start, etc.pics of my stereo install-photo0324-jpg
pics of my stereo install-photo0333-jpg
pics of my stereo install-photo0329-jpg
pics of my stereo install-photo0330-jpg
pics of my stereo install-photo0315-jpg
pics of my stereo install-photo0316-jpg
pics of my stereo install-photo0311-jpg
pics of my stereo install-photo0312-jpg
03 sport v8 4*4 166,000 miles and counting OME884/895 springs, toytec topmount 3/4inch spacer, Bilstein 5100's front and rear, 255/75/17 goodyear silent armours, spidertrax, scuba mod, two KHC1800 batteries, 2000watt acdc inverter, viper alarm remote start, Pioneer AVIC F900BT, JL HD600/4, JL HD750/1 JL10W6v3, Focal KRX2, JL ZR8, backup camera, rear hatch switch, homemade front skidplate, Thule boxster611
747ifly is offline   Reply With QuoteReply With Quote
Old 04-30-2011, 08:43 PM #2
Offroader5 Offroader5 is offline
Offroader5 is on a distinguished road
Nice...I bet that sounds killer.
I'm debating on whether to glass up new a-pillar covers to house a 3" and tweeter...and then I'd throw a midrange in the front doors and large midbass in the rear doors.
John
'03 Limited 4.7 4WD - Overland 2.5
Camburg Uniball Uppers - 285-70/17 Toyo Open Country AT II
http://www.toyota-4runner.org/galler...er-thread.html
Offroader5 is offline   Reply With QuoteReply With Quote
Old 05-01-2011, 06:05 PM #3
747ifly's Avatar
747ifly's Avatar
Yeah it really sounds great for sure. Very good sound quality.
Tweeters on the a pillar in the 4 runner does sound nice. I also have fiberglassed some in to the a-pillar in the 4th gen 4runner. It may actually be possible to mount a 3inch speaker behind the factory tweeter location. I mounted a hertz 3 inch mid there before. Good luck.pics of my stereo install-photo0323-jpg
pics of my stereo install-photo0319-jpg
pics of my stereo install-photo0322-jpg
pics of my stereo install-photo0313-jpg
pics of my stereo install-photo0321-jpg
pics of my stereo install-photo0317-jpg
Old 05-01-2011, 10:41 PM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
hot glue and duct tape? its a big no no, hot glue will melt in the heat, im surprise u fit an 8 inch driver in the rear doors.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-03-2011, 11:20 AM #5
Did you end up with enough front clearance to the door panel on those rear 8's...looks like the surround would hit with enough movement? Looks like you made your own spacer/adapter ring. Does it stick out further than the stock one? I had wondered if an 8" would fit in those doors...and was even looking at 7" woofers thinking 8" would be too large.
So, you've fit a 3" in the stock tweeter location on the front doors? I was wondering if one would fit there. Was it a high end driver? I'm wondering how much depth is available there. My plan was to try a 3" extended range in that spot, but I have yet to pull the door panel and see what space I have to work with. If I can fit a nice 3" in the upper door, then I won't need to glass up a-pillars...I can just put tweeters in pods attached to the stock pillars.
The plan I have is for H-Audio (Audible Physics) AR-Duo set. AR6K's low in the front door, and the AR3K in the stock tweeter location.
John
Old 05-03-2011, 10:01 PM #6
747ifly's Avatar
747ifly's Avatar
That amount of hotglue shouldn't fail. And no, there is no duct tape used. You must be seeing the hushmat pieces.
About the three inch speakers in the tweeter location... Yes i put them there for a while. There is a quite a bit of depth theredue to the large factory tweeter mount. A lot of depth really, but remember, you have to get the panel back on. The only drawback is that the three inch speakers cone may be like 2.5 inches large and the factory hole is like 2 inches. So, sound may not be perfect. I mean, it worked surprisingly well; but, there is better ways to do it right i suppose.
About the 8 inch speaker in the rear door. Yes, I made a spacer ring. 3/4 inch. I cut the inside of the panel out. Just the excess plastic that sticks out towards the factory speaker. So... no, the woofer never hits the door panel at all. I cut the metal out of the door to 7 inches but maybe didn't have to due to the spacer ring. If you do this, definitely use a lot of hushmat. Also use woofer that are made for infinite baffle or free air. With the JL ZR8 the spacer would be perfect if you actually put a little hushmat under the spacer to give it like another millimeter or two. Surprisingly, after this they fit perfect. They are no rattles in my door except the window itself barely rattles. But, no rattles when the window is up all the way.
Old 05-04-2011, 10:06 AM #7
Yeah, the hole in the stock tweeter plate is a bit small, but it looks like there is enough room to cut the opening larger in the plate and still be covered by the mesh grill. Size of the hole won't have to be perfect...but the better I can get it to match the better I can seal the front and rear waves from interacting.
Deadening the doors is on the aggenda. I've done the entire rear cargo area already and I'm planning on going all the way to the front foot wells with it. The doors will get it inside and out and then a piece of egg crate foam directly behind the driver. I'll also use a couple layers of deadener as a gasket to decouple the driver from the sheetmetal.
Here's what I've got done so far:
John
HTML code is Off
Stereo Install Help! Kurt_Knight 4th Gen T4Rs 13 03-20-2014 07:47 AM
Please help me install aftermarket Stereo w/pics contradan Engines / Suspension / Wheels / Tires / Audio / Accessories 7 11-06-2013 02:05 AM
JBL Stereo Install imdav2u Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-03-2010 03:02 AM
Stereo install pic MorrisK64 Gallery 2 09-07-2006 11:55 PM
Stereo install on a 200 ltd trdtoyotaguy 4th Gen T4Rs 0 04-11-2006 03:49 PM
