04-12-2012, 03:20 AM
#166
2 Javelin:
There are good news and bad news. Good one is that I received the unit today morning. Bad news - I was running it for 40 min (4WD) while driving to work and had no issues at all.
I found an issue with 2WD, actually. It does not work if you just switch it on in 2WD (It lights VSC OFF LED and that is it). To make it work one should go to 4WD -> switch VSC OFF -> go to 2WD back. Probably, it might make ECU mad if you just switch vsc off in 2WD. Anyway, I failed to reproduce the same usecase as you got.
If that is not an issue of "zero point" lose or some similar stuff -I have no ideas for now. I will continue running the unit you shipped back.
T4R'03 215 1GR SR5. +2'' OME & Ironman, + 1,5'' Body lift, diff drop, 285x75x16 STT.
04-12-2012, 06:01 PM
#167
Thats Strange
I thought the whole point of the unit was to be able to turn traction off in 2wd without switching back and forth.
Matt
2005 Land Cruiser 100 Series in Galactic Grey Mica
2011 Trail Edition in Magnetic Grey
2005 SR5 4x4 SOLD
04-12-2012, 08:07 PM
#168
Originally the main purpose was to make vsc off work without misleading center diff lock light. If you bought the unit mainly for 2wd usage I can take it back and refund the costs.
Sent from my HTC
04-12-2012, 08:22 PM
#169
So the only way this mod works is when Im in 4Hi or 4Lo?
Matt
2005 SR5 4x4 SOLD
04-12-2012, 08:29 PM
#170
Not quite right. It works in 2wd in case 4wd-vsc off- 2wd like original mode.
04-12-2012, 08:36 PM
#171
Is there a way to Permanently disable VSC without the light coming on.
Or permanently disabling VSC then disconnecting the light?
I really don't need it. Its more of a hindrance than anything else.
Is there a wire I can cut or a fuse I can pull? I dont care if it goes away forever. In fact I would prefer it.
Matt
2005 SR5 4x4 SOLD
04-12-2012, 09:54 PM
#172
Originally Posted by Javelin
Thats Strange
My device works fine in any mode... 2HI, 4HI, and 4LO, but I did notice that the 4Runner doesn't like to switch between modes with the device activated. I just switch it off to change modes, if I need to.
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
04-13-2012, 01:38 AM
#173
Well Then, that leads me to believe that my device was malfunctioning, but Kliv says its working fine on his 4R
Mabye my 4Runner is broken
Shame on you Toyota for not putting a traction control switch on the 03-07 4R.
Matt
2005 SR5 4x4 SOLD
04-15-2012, 12:17 PM
#174
Guys, I'm in Spain till end of month. I am not ignoring PMs.
Sent from my HTC
04-25-2012, 04:28 PM
#175
let me know when you're back and producing again, I'd love to get this! My understanding is its $60 + shipping + Western Union fees?
I've been wanting to do the VSC off mod for a while but wanted a cleaner way without switching all around and this is it!
Thanks!
My Build Thread
2006 Grey Mica Limited 4wd, JBL, RCI Skids, FJ TT suspension, aFe stage 2 CAI + URD MAF cal, Sprint Booster, Cobra 75 CB, 17" MB Gunner6 wheels + 265/70 Cooper Discoverer AT3s, Poly Bushings, Rear Diff Breather Mod, Morimoto XB 4500k HID Lows, LEDs in and out, Husky Liners, Load Warrior.
04-28-2012, 04:01 AM
#176
2 jpless:
I will be able to ship one item on Monday-Tuesday.
As for price, you are quite right. It is 85$ CIF for PayPal or 70$+15$(WU fee at your end) in case of Western Union transfer.
04-28-2012, 11:20 AM
#177
Guys! I got the issue reproduced on my truck! It happened during long ride with 2wd. Selling is temporarily stopped till the issue resolved. Will keep you posted.
04-28-2012, 09:37 PM
#178
Sort of glad it happened to you. I'm not the only crazy one... Whew!
K4WHE
07 4Runner; Bilstein 5100's; OME front springs, Toytec rear springs; ATO skids; ATO hidden hitch; ATO Rola Rack mod; 4xInnovations sliders; Kenwood TM-D710A; FT-857,ATAS-120; E-Locker Retrofit
05-02-2012, 03:07 AM
#179
The answer is in the unit temperature - when it is getting warmer it starts working in a wrong way. We had winter here - that is why I way unable to reproduce it earlier.
Looking for bad guy and solution for it. There are several thoughts. It might be easy to fix without shipping it back. Will keep you posted.
05-03-2012, 12:53 PM
#180
Looks like we found the problem. ALL new units are affected. Long story short: we tried to make it better but as it usually happens made it worse. Thank you for pointing that out and for your patience in describing wrong behaviour. We fixed two units and I've been testing these in different modes (and temperatures )
I will let you know when I'll be confident in quality enough.
To 7 lucky guys who have new units :
If you know how to remove one redundant component from the board (or know smbd who know that) - it will take you 2 min to fix the unit. I will provide description when it is tested.
If not, please send the unit back( just unit). I ll take costs and will ship you new unit. Unfortunately, it will take 1 month+ to have new unit in US.
I am really sorry, but it is as it is.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
