Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 05-31-2011, 02:31 PM #31
Kliv's Avatar
Kliv Kliv is offline
Kliv is on a distinguished road
Kliv's Avatar
Finally, I installed my body lift and had time to check this mod. I was surprised when discovered that it works perfect in 2wd mode. You do not need to switch it to 4wd and 2wd back to make it work.
New fine-grained VSC OFF Mod for V6 1GR-imag0203-jpg
T4R'03 215 1GR SR5. +2'' OME & Ironman, + 1,5'' Body lift, diff drop, 285x75x16 STT.
Kliv is offline   Reply With QuoteReply With Quote
Old 05-31-2011, 03:04 PM #32
rdrunner rdrunner is offline
rdrunner is an unknown quantity at this point
Sweet so you just hit the with and go when in 2wd? If so I definitely will do this.
'05 Sport V6 4WD Titanium | Overland Warehouse 2.0 | Cyclone Prefilter | Goodyear SA 265/70/R17 | JAOS Lamp Stay + PIAA 520 Fogs | JRD Black Tail Lights | Pioneer 4100DVD | PAC-SWI | Alpine Imprint Processor | Polk MM6501's > Alpine PDX-4.100 | JL Stealthbox with Dayton Audio RS-HO 10" > Alpine PDX 1.600 | AVS VentShades | WeatherTech FloorLiners
rdrunner is offline   Reply With QuoteReply With Quote
Old 06-01-2011, 04:28 AM #33
Kliv's Avatar
Kliv's Avatar
Exactly. Hit and go in 2wd.
Old 06-04-2011, 09:04 PM #34
Sounds perfect! Send me payment info, I'm in.
Old 06-05-2011, 12:18 AM #35
Doozi's Avatar
Doozi Doozi is offline
Doozi will become famous soon enough
Doozi's Avatar
So, people buying this will need to acquire the "VSC-off" button, right? Anyone have a decent source?
Thanks!
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
Doozi is offline   Reply With QuoteReply With Quote
Old 06-06-2011, 03:03 AM #36
Kliv's Avatar
Kliv's Avatar
Right. We might include the button in a pack, but it will not be cost efficient. You can buy it in US much cheaper ...
Old 06-14-2011, 10:56 PM #37
jbtaco2002 jbtaco2002 is offline
jbtaco2002 is on a distinguished road
will this work with V8 4x4 4runners as well? thanks
jbtaco2002 is offline   Reply With QuoteReply With Quote
Old 06-14-2011, 11:22 PM #38
L.C.'s Avatar
L.C. L.C. is offline
L.C. is on a distinguished road
L.C.'s Avatar
Originally Posted by Kliv View Post
Cool! We have first volunteer! Thank you for cooperation!
Please send your contacts privately and I'll get back to you with shipping number.
We need few days to build new block and ship it to you.
I will gladly be the #2 tester if nobody else has stepped up to the plate. I have done a few reviews on other products before, including one on this site for a XenonDepot HID kit that I can link for reference.
I've been looking into this mod for a while and it looks like you have a very complete solution. I agree with you also as far as not having additional lights show that are not necessary or incorrect (the center diff lock light showing locked when it is actually not.)
Just let me know and I would be happy to install and write a detailed review. I have an '03 Limited V8 4WD, for reference to check compatibility.
-LC
L.C. is offline   Reply With QuoteReply With Quote
Old 06-18-2011, 03:16 AM #39
Kliv's Avatar
Kliv's Avatar
I thought that V8 owners have ECU with ability to switch off VSC... All you need is to buy a button and install it if you do not have it already.
If not, this mod will definitely work as wiring routine is the same (with small exceptions). I will double check it for V8'2003.
The only item is shipped to rdrunner for now.
Old 06-22-2011, 01:00 AM #40
L.C.'s Avatar
L.C.'s Avatar
As far as I understood there were still some 'loose ends' not accounted for, the wires for the switch are present but once wired in you would also see the diff lock light even though the diff was in fact still open. I could be wrong though.
That would be great if you could double check and see if it would be compatible, I will do a little more research into the mod as well.
Also for reference, here is a link to the HID kit review I did for Steve at XenonDepot:
http://www.toyota-4runner.org/access...tml#post677779
And another review I did (on another forum) for Marco at Billet Engineering & Sean at OS Giken on their TS2B clutch:
http://forums.evolutionm.net/service...lots-pics.html
Old 06-25-2011, 07:47 PM #41
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
so KLIV is saying he thinks just putting the vsc switch & relay in will work with any year v8 ecu? i'd imagine since vvt started in 05 that the ECU would be different than an 03, but curious if the 06-09 were the same. i believe the vsc off switch came out in 08, would be great if it also worked on my 06.
chaz is offline   Reply With QuoteReply With Quote
Old 06-27-2011, 03:22 AM #42
Kliv's Avatar
Kliv's Avatar
I have no V8 to check, but according to wiring diagram, V8'03 should have Trac off switch (or blue connector to install T7 button at least). This mod will help you as well, but it is better to search for blue connector first. In any case you will have to buy the button, so, you might buy it and try to install into existing connector. If it did not work - this mod would resolve the issue.
I checked that all wires have the same color, so, there should be no problems with mod installation to V8.
Old 06-27-2011, 03:31 AM #43
L.C.'s Avatar
L.C.'s Avatar
I will check for the blue wire this week when I have the time, do you know if installation of factory trac off switch will disable VSC as well? Or do I need your invention to do this?
Thanks!
Old 06-28-2011, 03:04 AM #44
Kliv's Avatar
Kliv's Avatar
From my point of view it should work. If it did not - I would help.
Old 07-09-2011, 05:40 PM #45
BigEd BigEd is offline
BigEd is an unknown quantity at this point
I'm interested in this. I have an 05 V8.
2 questions:
1) Am I right in understanding that this mod will cause the dash VSC lights to work correctly while the previous VSC Off, Atrak On mod will not cause the dash lights to work correctly?
2) will this work with an 05 v8?
Thanks
BigEd is offline   Reply With QuoteReply With Quote
HTML code is Off
TRD tacoma mats fit just fine GottaBeTRD 3rd gen T4Rs 25 04-18-2015 04:10 PM
Rough start... then everything is fine 49Runner 3rd gen T4Rs 2 02-14-2011 10:57 PM
Forerunner will not start, battery is fine Finnguala Classic T4Rs 7 12-22-2010 09:29 PM
265/70/17 on an 07 Sport is fine right? Rez90 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-04-2010 12:27 PM
