Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 10-03-2019, 10:22 PM #466
garrett1946 garrett1946 is offline
garrett1946 is on a distinguished road
Help
I discovered that the 4wd actuator was actually not working due to the wire going to the 4wd ecu from the vsc off device. When I touch it to the blue/red wire the 4wd works fine but the vsc off switch just lights up the abs light on the dash. This same thing happens when no wires are tapped into the 4wd ecu. When I attach the wire to the red/blue wire on the 4wd the 4wd actuator stops working and makes everything blink. It displays multiple wrong lights on the dash includiung center diff lock vsc off and 4wd even when none of these things are true. (I tested it by seeing if I was in 4wd and cranking the wheel to full luck. Also vsc wasn't off as far as I could tell.
Originally Posted by Mike07SE View Post
This is not related to this thread and should be posted in the general 4th Gen Forum for advice.
Sounds like if you landed on something hard enough you could have damaged the actuator in the t-case. Post up like I said in the other forum. Try to get underneath and inspect, take some photos, etc. for others to visually inspect and advise on.
garrett1946 is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 06:30 PM #467
Offcamber's Avatar
Offcamber Offcamber is offline
Offcamber is on a distinguished road
Offcamber's Avatar
To clarify, you still don't have everything working correctly with the VSC device wired per the instructions (or otherwise)? Does it look like the latest version is malfunctioning? I have the revised device sitting on the shelf waiting to be installed. Maybe I should hold off until there is confirmation it is working correctly.
Offcamber is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 07:45 PM #468
I double checked all my wiring and it seems to be all good. I messed up a few wires originaly but nothing shorted and when I disconnect the wire to the 4wd ecu everything works as usual but the vsc off switch just lights up the abs light on the dash when pressed and depressed. What could be wrong? Whej the 4wd ecu wire is taped into the red/blue striped wire the 4wd actuator flashes on the dash and I can't do anything. Shift drive modes center diff lock nothing.
Thanks.
Old 10-29-2019, 04:42 PM #469
Selling my unit
Hey guys. After many attempts I was unable to successfully install my unit. I have decided to sell it. It is in good condition except I took off the blue tape covering. I am located in California and will pay shipping. Shoot me an offer.
Old 11-19-2019, 03:44 PM #470
BendRunner BendRunner is offline
BendRunner will become famous soon enough BendRunner will become famous soon enough
Originally Posted by Kliv View Post
Thanks for the update Rob! Hope you enjoy it.
Please check Yellow and Orange wires orientation
As a reminder. Will refund 10USD for every broken unit sent back - Thanks!
Finally got around to doing this and switching wire orientation, correct lights illuminate now (VSC off)
Now, when I go to use the unit I can still feel the a-trac kicking on even when using the mod. Is that how it supposed to operate?
BendRunner is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 03:51 PM #471
Hotasice Hotasice is offline
Hotasice is on a distinguished road
Are you still selling this?
Hotasice is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 10:36 AM #472
jtwarner13 jtwarner13 is offline
jtwarner13 is on a distinguished road
Hey kliv, are you still selling these? I am interested in getting one, it will be my first mod to my 4runner!
jtwarner13 is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 06:12 PM #473
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
I'd like to know if Kliv is still making these
awhitney1 is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 02:39 PM #474
Joshks22's Avatar
Joshks22 Joshks22 is offline
Joshks22 is on a distinguished road
Joshks22's Avatar
Yes,i too would like one of these,@kliv,dm me if you are still making these,ive been needing one for quite some time
Sent from my SM-G965U using Tapatalk
Joshks22 is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 03:56 AM #475
T4R916 T4R916 is offline
T4R916 is on a distinguished road
Interested in this kit too. Pm if you’re still selling it.
T4R916 is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 06:18 PM #476
4wheelsburning 4wheelsburning is offline
4wheelsburning is on a distinguished road
Does anyone know if this is still available and will work in a 07 V8 4Runner?
PM me if available for sale
4wheelsburning is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 08:03 PM #477
ggill310 ggill310 is offline
ggill310 is on a distinguished road
Hello
I am curious how you connected the vsc mod device wires to the back of the speedo? I have it all open i am wondering what is the best way to make the connection?
Regards
GGILL
[email protected]
ggill310 is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 05:59 PM #478
midwestbandit midwestbandit is offline
midwestbandit is on a distinguished road
Hey Kliv, I’d like to buy one from you for my V8 4th Gen. PM me with payment info. Thanks!
- Joshua Metcalf
midwestbandit is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 04:34 PM #479
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Not sure if Kliv is still selling these, but if anyone is interested, I have had one for about a year now that I still haven’t installed due to other priorities, and would consider selling. I also have a brand new factory Toyota FJ switch along with the connector plug and the factory pigtail wires. Complete kit basically. Pm me if interested.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 10:04 PM #480
Currie_1's Avatar
Currie_1 Currie_1 is offline
Currie_1 is on a distinguished road
Currie_1's Avatar
still have this available ?
2005 Sport / v6 / Icon stage 2 / toytech 1'' body / DO Front / 285/75/17 BF Goodrich KO2s / Fifteen52 Turbomac HD / Prinsu Full Length / Baja Designs & Factor 55 Goodies / Overland Custom Designs Links
Currie_1 is offline   Reply With QuoteReply With Quote
HTML code is Off
TRD tacoma mats fit just fine GottaBeTRD 3rd gen T4Rs 25 04-18-2015 04:10 PM
Rough start... then everything is fine 49Runner 3rd gen T4Rs 2 02-14-2011 10:57 PM
Forerunner will not start, battery is fine Finnguala Classic T4Rs 7 12-22-2010 09:29 PM
265/70/17 on an 07 Sport is fine right? Rez90 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-04-2010 12:27 PM
