Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 05-20-2019, 04:16 PM #451
Kliv's Avatar
Kliv Kliv is offline
Kliv is on a distinguished road
Kliv's Avatar
Guys, there were a lot of questions regarding updated install instructions. Something went wrong with Google docs and it did not share 4.2 version. I put 4.3 which contains the changes regarding new fixed units. The only change is the orientation of Yellow and Orange wires. Orange one should go to the connector when yellow one should go to the bundle. Otherwise Central diff lock LED will not switch off when VSC is OFF.
Here is the link for the updated instructions:
Install Instructions_4.3 - Google Docs
T4R'03 215 1GR SR5. +2'' OME & Ironman, + 1,5'' Body lift, diff drop, 285x75x16 STT.
Kliv is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 04:25 PM #452
Kliv's Avatar
Kliv's Avatar
Originally Posted by RivMan View Post
Forgot to update this.
I received my updated unit a couple weeks ago.
Installed and works as expected!
Thanks
-Rob
Thanks for the update Rob! Hope you enjoy it.
Originally Posted by BendRunner View Post
Hey Kliv, I have installed the second new unit and the issue still persists. Is there something I need to change wiring wise?
Please check Yellow and Orange wires orientation
As a reminder. Will refund 10USD for every broken unit sent back - Thanks!
Old 05-28-2019, 12:42 AM #453
garrett1946 garrett1946 is offline
garrett1946 is on a distinguished road
Shipping Question
Hey Kliv. How long does shipping normally take to California and how much does it cost? Thanks!
garrett1946 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 07:51 PM #454
Purchase
Hey Kliv. I'd like to buy one. Can I get the info for the purchase? Thanks.
Old 06-13-2019, 02:22 PM #455
Kliv's Avatar
Kliv's Avatar
Hey folks, there is one unit in US for sale. 4Runner has been sold and it never get installed. Please PM to garrett1946 if you are interested in it.
Old 08-18-2019, 01:27 AM #456
Chankeye's Avatar
Chankeye Chankeye is offline
Chankeye is on a distinguished road
Chankeye's Avatar
finally got around to installing the vsc module i received from Kliv. Followed the instructions provided by his install link. No issues with the install and it works as it's suppose to. only light that comes on when the button is pressed is the "VSC OFF" light, press the momentary switch one more time and the "VSC OFF" light turns off and the Vehicle skid Control system is reactivated. Thanks again Kliv!
Chankeye is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 06:32 PM #457
Hey Kliv. I never said that my 4runner got sold. Still have it and I am installing the switch soon. Life is just getting in the way lol.
Old 09-23-2019, 07:00 PM #458
Question about mod
So I fi ally got around to doing the mod and I finished it but it appears that my abs light turn on when I press the switch and the vsc doesn't seem to be turning off. I noticed that a couple of the wires were in different locations than in the directions so I was wondering if someone could help me troubleshoot this.
Thanks
Old 09-24-2019, 02:46 PM #459
scribb's Avatar
scribb scribb is offline
scribb will become famous soon enough
scribb's Avatar
Thanks
You have an '05 v8, right? Curious to hear if this works for you as expected.
scribb is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 03:28 PM #460
No 06 v6
I have an 06 v6 and it didn't work. I k if htve messed up one of the wires because the abs light is lit with the switch activated and vsc is still on.
Old 09-25-2019, 05:26 PM #461
Is this thread dead? I really need some help. If it helps at all my 4wd also stopped working and I think the actuator might be jammed from possibly landing on a rock in my backyard. That or wiring.
Old 09-27-2019, 07:57 AM #462
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
This is not related to this thread and should be posted in the general 4th Gen Forum for advice.
Sounds like if you landed on something hard enough you could have damaged the actuator in the t-case. Post up like I said in the other forum. Try to get underneath and inspect, take some photos, etc. for others to visually inspect and advise on.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 10:10 AM #463
Well I was mainly saying that I have posted three times and no one has tried to help. I thought that maybe the 4wd thing was related to my wiring and that it could help troubleshoot it but I couldn't narrow it down because I did hit a rock as well on something.
Thanks
Old 09-28-2019, 01:31 AM #464
Turns out it was the wiring. The 4wd ecu has a red/blue wire and a blue/red wire and I chose the wrong one. This fixed the 4wd issue but my mod still isn't quite working. I think it's my wiring to the center diff lock switch.
Old 10-02-2019, 04:49 PM #465
Fixed everything I found wrong and still doesn't work.
I double checked my diff lock wires, my vsc off switch wires, and all other connections. When the 4wd ecu wire is attached, the 4wd actuator goes limp and wont let me shift to 4wd or anything. When I attach it to the other blue/red wire on the 4wd everything works fine but the vsc off switch just lights up the abs light and doesn't disable traction control.
Any help?
Thanks
HTML code is Off
TRD tacoma mats fit just fine GottaBeTRD 3rd gen T4Rs 25 04-18-2015 04:10 PM
Rough start... then everything is fine 49Runner 3rd gen T4Rs 2 02-14-2011 10:57 PM
Forerunner will not start, battery is fine Finnguala Classic T4Rs 7 12-22-2010 09:29 PM
265/70/17 on an 07 Sport is fine right? Rez90 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-04-2010 12:27 PM
