05-07-2011, 01:15 PM
IPod/IPhone Cable Routing
Just installed an AVIC-Z130BT and purchased the ipod/iphone integration cable. Right now I have the entire length of the cable stuffed in the glove box, but was wondering if anyone else had come up with any good ideas of where to route this cable where it was not in the way but still accessible. Don't want to reinvent the wheel if someone has already done it.
I would like to get a male to female plug mount for both the USB and mini-jack cables that are panel mountable. If I can find them, I could cut a small hole in the center console box and connect the ipod/iphone cable there. When I'm not using it, or if I wanted to hook up a thumbdrive or something I could easily remove the pigtail for the Iphone. I have also thought about using one of the blank switches on the center console and doing the same thing there, but there is no way to hide the cable that way, and I don't necessarily want that out all the time.
Love to hear any ideas that you may have come up with.
Always Something...
2013 FJ Cruiser V6 AT 4x4 | 2004 4Runner Sport V6 4x4
2002 Tacoma Extended Cab V6 4x4 TRD **Sold** | 1985 Pickup 4x4 - Buick 231 V6 - 6" Lift **Sold**
05-07-2011, 08:17 PM
I have a z120bt and I ran my cable through my center console tray. I just used some parts in my garage to try and "clean-up" the look. I keep my iphone cable plugged in. If I ever needed the USB for something else I figured I'd just use the SD card.
Either way, I like it in my center console tray because I can drop my phone in there, but it's still very handy if I need to check something. Also, it's setup to allow the cord to slide out of the hole at least 4 feet if I want to use the phone while it's plugged up. When not in use I just slide the length of the cord back in the hole.
Black 2004 Limited 4WD V8
05-12-2011, 09:48 PM
yeah, stuff the wires below the center console, do what revo runner did and drill a hole and pull it up there, or drill a hole in the glove box...that's what I would do, that way if you leave your ipod plugged in and leave your car, no one can see it and won't be tempted to steal it.
2006 4Runner Limited 4x4 Titanium Metallic
05-13-2011, 06:38 AM
Right now I have the ~8ft of cable hanging out in the glove box. Only problem with that is there is too much cable loose in the glove box to reach over to the drivers seat, and it's too inconvienent to reach over to the glove box to get your phone while you're driving. I'm still leaning to trying to figure something out using the center console. Thanks for the ideas though.
Always Something...
05-13-2011, 12:15 PM
I just cut a little notch in one of the blanks next to the DAC switch so the cord slides in and out.
2007 SportEdition V6 4WD Galactic Gray
Found on the trails of the Colorado front range
Daystar 2.5/1.5, Rear Diff Breather Mod, TRD Brake Pads, Full Synthetic 90w-135 Gear Lube, 265/70/17 Duratracs, Cobra 75, 3' Firestik, Refrigerated Console
Toyota Expert Tech/Lexus Certified Tech/ASE Master Tech
06-04-2011, 10:14 AM
Center Console
I stuffed all the wires beneath the center console, drilled a hole just below the AUX input and AC plug and ran the connector through it. It's hidden, but easily accessible at the same time.
2008 Urban Runner 4WD
TRD CAI, Husky Liners, 35% Front Tint with 50% over factory rears, FJ Springs, Bilstein 5100s all the way up, AVIC Z120BT, Sony Components, Alpine Amp, 10" Pioneer sub in Custom Stealthbox
My Audio Setup
06-04-2011, 02:32 PM
yup me too!
06-04-2011, 10:13 PM
Could either of you post pics of this? I think this is along the lines of what I originally wanted to do.
Always Something...
06-04-2011, 11:43 PM
I'll put some up as soon as I get the truck back together. I'm in the process of upgrading the stereo system.
My Audio Setup
06-05-2011, 02:34 PM
Originally Posted by platinumb
yup me too!
I also did the same. Drilled a hole in the corner below the AC outlet and it will slide in and out as far as I need it. Super easy
http://www.calendollar.com
2005 T4R Limited
custom grille grating, Borla Dual Catback, rubberized undercoating skid plates, LED replacements, stainless steel shift knob, '06+ JBL HU, iPod adapter USA Spec
06-07-2011, 10:32 PM
Here ya go! And I know, I need a grommet in the worst way!
My Audio Setup
06-08-2011, 01:01 AM
My pictures didn't turn out as nice, but the hole looks better. ;)
'08 Urban Runner 4X4: Blizzard White Pearl, TRD Catback, AFE CAI, URD MAF sens cal, Dirty Parts Dual Battery, OW 2.5's, LR UCA's, Stubbs HD-SKO, Budbuilt skids, , Sidertrax, 275-70-18 BFG KO2's.
'94 Mazda RX7: Fast as SH*T Sleeper. Too many mods to list here.
'94 4-Runner 4X4 V6: Downey Headers, MSD ignition, K&N air filter, Airlift 1000, Bilsteins, Energy Suspensions bushings. (Sold)
06-18-2011, 08:49 PM
Krazy, your clean "hole" job is impressive! (that sounded pretty awkwardly dirty when i read it aloud...sorry )
Can you give me details as to how you did it?
2003 Sport Edition V8 (sold)
2008 Sport Edition V8 (sold)
2016 Trail - Classic Silver Metallic - 17" Black TRD Wheels w/ BFG All-Terrains
06-19-2011, 09:12 PM
I installed the 2010 OEM Toyota USB / AUX port in the same spot as my 08 AUX port (inside the center console). The new port replaced the older 3.5mm port with both a 3.5mm and a USB. The reason I went this way is it simply snaps right into the same spot as the old port for the complete OEM look and function.
I'm not using the 3.5 mm its easy to wire up using an extension just like the USB. This would provide both connections you need. This way your not hacking up any cables from the HU or the vehicle.
Here is my thread for details.
New Member - New 4Runner - A few newbie questions
I still need to upload a finished picture.
08 4Runner V8 SE
Debadged | Black on Black Leather | Heated Seats | AVN-726E | Backup Cam | Integrated 2010 USB | 3 - 1.5 Truxxx Lift w XREAS | 275-65-18 Duratracs | Ballistic Hostel 18x9 | Auto Headlight Mod | Bluetooth Steering Controls
06-19-2011, 11:27 PM
ThreeFive0,
That is awesome, and just what I was looking for. I actually am out of town and have a KIA rental car that has a panel with a 3.5mm jack and a USB port (it also has a pretty descent bluetooth setup - can you believe that, in a KIA??). I was looking for something like this in the beginning, and because my bluetooth adapter requires both plugs (USB and 3.5mm) that option is perfect. Does that plug just require a square/rectangular hole to snap into? What type of connections are on each side of the plug?
This is definitely what I was looking for - I appreciate you dropping by with this info!
Travis
P.S. Love to see some finished pics...
Always Something...
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
