Lower the Bump Stops?
I installed a DayStar 2.5 / 1.5 and ditched the leaking XREAS for a set of Bilstien HD's. Probably should have got the 5100's, but it drives fine and no issues.
Just one question: If the front suspension were to fully compress now, would it touch the bump stops, or with the lower strut position as it is, would the strut/front shocks bottom out first?
I jacked up the rear to try to compress the front suspension, but it doesn't go down enough to see.
