I bet you blew the parking light fuse, and I also bet you have a dimmer/illumination wire grounding out. When you hooked up the stereo Im not sure what harnass you used if it was a 70-1761 those harnassas sometimes have an orange, and an orange-black stripe, if either of those wires are hooked up incorrectly they will blow a fuse, check whats behind the radio and if you want be extra safe just disconnect any illumination/dimmer wire and tape it up. Just leave the black,red, yellow, and speaker wires hooked up, and replace the blown fuse and I bet you will be in business again.
