Old 07-01-2019, 06:00 PM #1
ExtremeLED ExtremeLED is offline
ExtremeLED is on a distinguished road
Thumbs up How to Choose an LED Light Bar or Pod Mounting Location
Determining the perfect location to mount your new LED Light Bar or Pod(s) is based on many factors: budget, technical abilities, intended lighting use, and finally, personal preference.
Some locations are easier to mount and wire than others. Here is a list of locations that we will review, in order of those that are easiest to mount first:
Front Bumper
The easiest location to mount your LED light bar is typically on the front bumper. Often there are already holes in the bumper so purchasing additional mounting hardware is not required. Even if there are not existing holes that will work for your mount location, drilling a bumper is a quick and easy job so you can mount your new light exactly where you want it. From the bumper, it is also a snap to get the wiring to inside the engine compartment.
The mounting flexibility of the bumper also makes it suitable for just about any LED light. For example, You could place a 30" LED light bar or two 5" LED Light Pods on the front bumper.
The cons of the bumper is that the light direction is coming from the same direction as your stock headlights. Though this isn't a huge downside, you won't get the advantage of lighting your way from multiple light angles, which often provides overall better visibility than just one angle.
Lower Windshield Pillar Mount
The lower windshield pillar mount is a great place to mount a pair of our LED Light Pods and offers a greater amount of light angle differentiation from your stock headlights than the bumper mount location, increasing visibility. This location does require additional mounting hardware, such as our JK pillar mount or TJ pillar mounts, but they are pretty economical in price and simply bolt on using the existing mounting holes on your Jeep (no drilling required).
Wiring from the pillar mount location requires some drilling, but it is pretty straight forward and can be easily filled with a cheap plug that you can get at Ace Hardware, Lowe's or the like, in the unlikely event you decide to remove your lights at some point in the future.
Above the Windshield
This location is excellent for allowing you to have the greatest amount of light angle differentiation from the headlights, providing for the best overall visibility. It also has the room to use the largest of LED light bars, like our 50" LED light bar, giving you the most amount of lumens of light than the other locations. This location does require you to purchase additional mounting hardware, and wiring will require some drilling, but if getting the maximum amount of quality light is your goal, than this is the ideal location. Plus, it adds a certain "bad-ass" look that you might be going for
A Combination
Now no one says you have to pick just one! You can combine any of these locations to give you even more light and mean aesthetics. So go ahead, pick your poison!
ExtremeLED is offline   Reply With QuoteReply With Quote
bumper , led , light , location , mount
HTML code is Off
CB Mounting Location...? hargravey 5th gen T4Rs 19 08-14-2016 11:41 PM
265-75-16 in factory spare mounting location? I_bRAD 3rd gen T4Rs 10 01-26-2013 10:08 PM
Cb mounting location TN_GIJOE Classic T4Rs 3 03-27-2012 10:33 PM
GPS Mounting Location BostonBeachbum 4th Gen T4Rs 4 04-09-2008 07:35 AM
CB Antenna mounting location? J's4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 5 09-27-2003 10:46 AM
