07-31-2019, 05:13 PM
#496
official vendor
official vendor
For anyone that might be interested. I've started an Instagram account for my new business that you can follow, and that can be found here. This will keep you informed on everything new going on.
Mike
08-01-2019, 02:49 PM
#497
Do you offer the rears alone?
08-02-2019, 10:17 AM
#498
official vendor
official vendor
I do, but it's more cost effective to get a full set. I'll send you a PM.
Mike
08-08-2019, 05:05 PM
#499
Do you still have those adjustable end links for sale? If so, how can I purchase?
08-08-2019, 06:03 PM
#500
read the first post in its entirety.
Originally Posted by MStudt
Pictures are from an FJ Cruiser, but the 4runner's are the exact same. He does have a relocation kit installed on this FJ.
quick heads up, that isnt the same as a 3rd gen 4runner. the pickup points are different.
once im done with my travel at the end of the month i really need to pick a set of these up.
99 4runner limited; imperial jade mica
IG: mesooohoppy
08-09-2019, 10:05 AM
#501
official vendor
official vendor
I'll shoot you a PM shortly.
Yes, I'm aware 3rd Gen's are different. What you quoted was about the 4th & 5th Gen disco's, and those are exactly the same as FJ's.
Mike
08-22-2019, 03:32 PM
#502
official vendor
official vendor
08-27-2019, 10:00 AM
#503
Why size is the shortest length bolt in the 5th gen standard kit? I had a similar issue as someone earlier is the thread with the bolts being a little short. I used the shortest of the three lengths in the rear and the bolt ends inside of the nylok. No big deal just want to pick of two slightly longer bolts. Thanks in advanced.
2016 White TEP w/o KDSS, 15% tint on front windows, 35% on all others including windshield (all ceramic), temporary Daystar lift, Gobi rack with 40" E series light bar and two 6"srq lights out back, RCI sliders without tread plate, and Bussmann aux fuseblock custom built to power all accessories
08-27-2019, 10:50 AM
#504
official vendor
official vendor
If you get a 7/16-14 x 2-1/2" you'll be in good shape.
Mike
08-28-2019, 08:53 AM
#505
Mike
Just noticed in the pictures above there is an additional aluminum washer? On two of the bolts. My set didn’t have this, is it possible I’m missing something? Also, after tightening everything up, the rod end bearing boots just pop over the head of the bolt, had any word about this from others? Thanks again for your prompt response.
08-28-2019, 09:57 AM
#506
official vendor
official vendor
The spacers are new addition, and isn't something that I would worry about just yet. If you have a popping sound from the front with your steering wheel at full lock, let me know. The spacer will eliminate that. There's nothing to be concerned about with the boot either. Some people have used a small zip tie to hold it in place better.
Mike
08-30-2019, 10:36 AM
#507
Mike,
Can you let me know what size quick release pin is used for the front disco for the 5th gen? Mine are bent or stuck or have the ring pulled out. I need to replace one of mine. The bolt sometimes rotates and allows the pin to interfere with the stock sway.
Thanks,
Will
http://TeamShiftPoint.com
William - 2018 Cavalry Blue TRD PRO 4Runner
3.4 swaps with trd s/c completed (wired up ourselves, tach works): 90 4runner 4wd AUTO - 90 4runner 4wd AUTO - 93 Toyota Truck 4wd 5spd
08-30-2019, 11:56 AM
#508
official vendor
official vendor
Originally Posted by TeamShiftPoint
Mike,
Thanks,
Will
3/16" diameter
Mike
09-02-2019, 10:19 PM
#509
Mike
Pm sent regarding this. Thanks.
09-09-2019, 11:16 AM
#510
official vendor
official vendor
I have an update on lead times. All standard links will ship within 24 hours. We currently have stock on all 4runner models, FJ Cruisers, GX's, and Tacoma's.
Mike
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
