11-09-2020, 07:04 PM
#586
official vendor
official vendor
Originally Posted by fourfive
I will be interested in a set of 4 joints pending price. Since I'm just wanting the ball joints, should I still sign up on your website?
I would still sign up just in case to forget to post it here.
Mike
11-19-2020, 01:10 AM
#587
Originally Posted by MStudt
New sway bar link teaser!
These should be available on my site at some point in October. A few things about the new sealed ball joint end links. These ball joints are something that I've been working to produce for about a year now, and are made just for me. These will work my hex tube, both old and new! So anyone that bought links from me 2 years ago can replace the heim joints with the sealed ball joint. The studded end is also OEM thread and length, and will have a much better fit. The sealed ball joint is also a solid 1 piece design rather than a design with a welded stud.
Sign me up for the first patch, can't wait to upgrade mine .
11-20-2020, 02:57 PM
#588
official vendor
official vendor
You'll have to sign up on my site to join the list.
Mike
11-20-2020, 02:58 PM
#589
official vendor
official vendor
Teaser pic as I get closer to releasing the new links (middle).
11-23-2020, 04:12 PM
#590
Is there a torque spec or suggested tightness for the top nuts on the front end-links for a 3rd gen? I want them to be tight enough but don't want to unnecessarily squeeze the bushings.
11-24-2020, 11:26 AM
#591
official vendor
official vendor
Tighten until the have a slight squish to them, but not so much they're bulging out. It's a bit difficult to put a torque spec on bushings since it could be off due to the lock nut.
Mike
11-24-2020, 03:04 PM
#592
Real Name: Eric
Real Name: Eric
Mike
I'm a Mechanical Engineer myself and am the bolted joint guru (if I do say so myself) at my company. I could provide you with the torque spec for the nylon lock nuts if you provide me with a few unknowns;
1: Thread Size and Pitch
2: Grade of bolt
3: Prevailing Torque of the nylon lock nut. This means use a lower rated torque wrench and find how much torque is required to spin the nut on the threads while engaged with the nylon. Yes, it will vary, but you can get an average if you test enough different combinations.
1984 SR5, 1989 DLX, 2011 SR5 4wd
11-24-2020, 03:48 PM
#593
official vendor
official vendor
2: Grade of bolt
I'm good, but I greatly appreciate the offer. I will reach out to you for another spec though, and maybe you can help me with that one.
Mike
11-24-2020, 03:59 PM
#594
Real Name: Eric
Real Name: Eric
Mike
No problem. What else you got?
11-24-2020, 04:18 PM
#595
official vendor
official vendor
I'll shoot you a PM.
Mike
12-09-2020, 05:43 AM
#596
Sway Bar quick disconnect Links
are these still available for a 2010 FJ?
12-15-2020, 05:26 PM
#597
official vendor
official vendor
Always
Mike
12-17-2020, 09:40 AM
#598
Real Name: Elliott
Real Name: Elliott
Are you still making the 4th gen discos?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-17-2020, 12:02 PM
#599
official vendor
official vendor
All the time.
Mike
12-18-2020, 11:59 AM
#600
official vendor
official vendor
Small update on the new links. My parts are being picked up today 12/18 (finally), and I should have them on Monday 12/21. Once I have them I'll need a couple days to get my site updated, and links built. I'm hoping to have these live on my site by 12/23. I do my best to ship orders within 24 hours, but with the holidays that will change. I will be closed from 12/24 - 12/27 & 12/30 - 1/4 as well.
Mike
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
