Originally Posted by Token_Indian
So I just purchased 2.5 fox's all around for the 14' SR5 runner and was wondering at what height would it be recommended to upgrade the sway bar end links?
I think I will be raising it to 2.5in to maybe 3in the front and it will be paired with aftermarket upper control arms.
As for the rear, just enough to level the ride with the front, I think 1.5in?
Would it make sense to switch out the front end links with the upgraded pair and keep the rear stock or would the increased height stretch the stock links too much?
Thanks in advance.
Would make more sense the switch out the rear with an upgraded pair, and leave the front. The rear will be longer so you can get your sway bar back to its OEM position. The front links will be the same length as OEM, and you want it like that.
Mike
