Notices
Old 01-01-2017, 11:42 AM #1
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
FS: eimkeith PCK® (Panhard Correction Kits) for 3rd gen $93.50, 4th/5th Gen $98.20
UPDATE - 5th Gen PCK®s available also
UPDATE - you guys can hit me here to order a PCK® (my PM box is getting full, lol!)
These are weld-on bracket kits (one Panhard Lift Bracket and one Panhard Drop Bracket) to correct the angle of the panhard bar on 2-4.5" lifts, designed in response to a thread on T4R.org.
The axle-end (lift) bracket is cut from 3/16" plate to match the thickness of the factory mount and contoured for easy alignment to the existing axle mount with minimal fitting:
The lift bracket raises the axle-end of the panhard bar 2 inches by itself, without interfering with the frame under full flex with factory bumpstops in place.
The drop bracket is selectable for 2, 3 and 4 inch lift heights and is cut from .120" plate to match the thickness of the factory mount.
It is contoured for slide-over alignment with the existing frame mount with minimal fitting, using the factory pivot bolt hole for proper location. The drop bracket also includes two 3mm hardened steel spacers to retain the factory mount inner diameter.
The Panhard Correction Kit returns the panhard bar to horizontal (per original design), eliminates the need for an aftermarket adjustable panhard bar to recenter the axle, and in most cases (up to 4 inches of lift) raises the roll center for improved handling (4-4.5 inch lift maintains the roll center of an adjustable panhard.)
The kit is $93.50 shipped to addresses within the continental US (PM me for shipping costs outside of CONUS, currently shipping to Canada is +$40 )
Send me a PM with your email address and shipping address if you want one - I'll send out a Paypal invoice for the kit.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 01:19 AM #2
mark52cents mark52cents is offline
mark52cents is on a distinguished road
Awesome idea. Will part of the kit work with a exciting drop bracket?
mark52cents is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 06:09 AM #3
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
yes - the addition of the axle-side lift portion can help minimize some of the issues caused by your existing drop bracket by helping to raise the roll center (the roll center is lowered with a drop bracket, so you should use as little drop as possible in conjunction with a lift bracket.)
keith
eimkeith.com
Old 01-02-2017, 05:21 PM #4
magikbean562 magikbean562 is offline
magikbean562 is on a distinguished road
sent you a pm
magikbean562 is offline   Reply With QuoteReply With Quote
Old 01-09-2017, 03:17 PM #5
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
Some install pics (thanks to Tyler James, Inc.)
http://uploads.tapatalk-cdn.com/2017...eb5ec4935d.jpg
and viola! FLAT AND LEVEL Panhard Bar on lifted 3rd Gen:
keith
eimkeith.com
Old 01-30-2017, 06:34 PM #6
FROGrunner's Avatar
FROGrunner FROGrunner is offline
FROGrunner is an unknown quantity at this point
FROGrunner's Avatar
Can you purchase only the lift bracket or is this a lift and drop kit only?
97' SR5 4X4- elbow delete, ISR, 40W DDM LED headlights, TB gasket mod, coolant bypassed, 14" BAMuffler, poly rack bushings, dirtydeeds custom rear tube bumper with poison spyder shackle mounts, King 2.5 coilovers, BFG AT KO 285/75/16, CBI ditch light brackets, HAZARDOUS LIGHT cubes, light bar, and LED interior lighting.
FROGrunner is offline   Reply With QuoteReply With Quote
Old 01-30-2017, 07:47 PM #7
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
The kit includes both, to accommodate lifts from 2-4.5 inches (although it certainly helps 5+ also)
keith
eimkeith.com
Old 01-30-2017, 09:48 PM #8
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
Subbed. I'll need this in a couple months when it gets warm enough to work on things.
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 01-30-2017, 10:02 PM #9
mountain mike's Avatar
mountain mike mountain mike is offline
mountain mike is on a distinguished road
These really helped tame my body roll and improved the overall handling of my runner. Bump for a well thought out product that got my panhard level. No more beeping from the vsc!
2001 Black Sport Package
mountain mike is offline   Reply With QuoteReply With Quote
Old 01-31-2017, 06:26 PM #10
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Hmm, I wonder if these will work with my 80 panhard rods. Let me compare the pics. Looks like a great product.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 01-31-2017, 08:05 PM #11
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
Thanks!
keith
eimkeith.com
Old 02-01-2017, 12:51 AM #12
1986Runner 1986Runner is offline
1986Runner is on a distinguished road
Looks great! I may have to get this whenever I get around to lifting mine. ��
Quick question: It appears you can still mount in the factory holes, say if you ever wanted to ditch the lift and return to stock height. True?
1986 4Runner SR5, 22re, 5spd, 4x4 (Sold)
1999 4Runner SR5, 5VZ-FE, 5spd, 4x4
1986Runner is offline   Reply With QuoteReply With Quote
Old 02-01-2017, 03:08 AM #13
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
FS: eimkeith PCK (Panhard Correction Kits) $86
Yes sir, that's correct.
keith
eimkeith.com
Old 02-01-2017, 03:34 AM #14
Oneluv13T4R's Avatar
Oneluv13T4R Oneluv13T4R is offline
Real Name: Miah
Oneluv13T4R will become famous soon enough
Real Name: Miah
Couldn't these work for a 4th gen? I need them for my 3rd and 4th gen rig.
4th Gen 2WD to 4WD CONVERSION
2003 SR5 T4R Pac Blue Metallic w/rear locker, on 35" Mastercraft MXT’s, TC uca"s, TC lca"s, 2.5 King C/O's w/remote resi TC lca gusset kit, Taco Tabs, 2.5 Icon remote resi w/adj on rear Shock Hoops, adj panhqrd A 3.5" lift springs, 10" HD Series AirLift bag, hidden winch W/ 10k Smittybuilt, DMZ eng mounts
Oneluv13T4R is offline   Reply With QuoteReply With Quote
Old 02-01-2017, 03:43 AM #15
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
not sure; I haven't had the opportunity to look at a 4th Gen in person - but if you decide to try it, please let us know!
keith
eimkeith.com
HTML code is Off
Panhard bar drop vs adj panhard bar Swimmerboy2112 3rd gen T4Rs 30 01-15-2018 04:29 PM
Speedometer Correction sittinpretti03 3rd gen T4Rs 13 08-30-2013 11:33 PM
Toyota IFS Eliminator kits and Classic kits. FREE SHIPPING AddictedOffroad Addicted Offroad 0 02-14-2011 01:45 PM
Speedometer correction TexasA&M Off-Roading 18 08-07-2010 03:24 AM
Speedometer correction on an 89 Klez Classic T4Rs 0 03-10-2005 02:36 PM
