Originally Posted by SHagood
I actually am, thanks for tagging me!
Are these still available and will the coilovers fit a 4th gen?
So from some quick searches it sounds like the front will fit, but might require you to shave a hair off the misalignment spacers for the lower mount. Should be easy enough with a belt sander or grinder. For reference they install spacer/shock/spacer to center the coilover so it doesn’t hit your swaybar. So the spacer may need a quick grind to squeeze it in.
