Notices
Old 01-17-2018, 09:59 PM #46
bandi bandi is offline
bandi is on a distinguished road
Originally Posted by CajunRunnerRN
do you have any photos? I do have a shrockworks front and rear bumper. Would your recommend a vertical or horizontal mount. (the passenger side hood area)
See above is this thread for pictures bud'...
I recommend horizontal to keep the entire pump high and dry as can be...
bandi is offline   Reply With QuoteReply With Quote
Old 01-18-2018, 01:40 PM #47
Liquidmantis's Avatar
Liquidmantis Liquidmantis is offline
Real Name: Will
Liquidmantis is on a distinguished road
Real Name: Will
Oooh, I didn't know #5 was an option. That makes for nice options and really helps solve the dual battery, air compressor, aux fuse/relay box, and high clearance bumper washer bottle relocation juggling problem.
Liquidmantis's modest [boring] build thread
2016 MGM TEP w/KDSS | OME BP-51 w/ 2889 rear | SSO Bumper | Warn Zeon 10-S Plat | TRD Pro wheels | BFG K02 275/70/17 | RCI sliders | RCI alu skids | Gobi Stealth No Rise | 1Up USA hitch rack
Liquidmantis is offline   Reply With QuoteReply With Quote
Old 01-23-2018, 11:37 PM #48
Yes it does !
I expand on the version based on requests/needs...
Old 01-24-2018, 09:42 AM #49
INFORMATIONAL POST....
Originally Posted by Titanpat57 View Post
I looked it after I read a little further....looks like they dont make it for 2016+....HMMMMMMMM....if only I knew a clever fabricator with mad skills....
Originally Posted by 007Tacoma View Post
Why 2016+? My 2015 has the CARB Approved Smog Pump that I'm so happy to have paid for.
I think it said the Shrockworks was for 2010-2014...leave it to Toyota to kill a good space
I installed it today for a test fit on my 2016 and no issues at all... not sure if 2017/2018 have anything different going on or not, but as long as they have the reinforced mounting point for the second battery, it should be fine !...
Originally Posted by Shrockworks
One advantage of the 2010-2014 FJ however, is that it has a reinforced mounting point on the passenger side front of the vehicle. This location is a mirror image of the driver side, which holds the stock battery. This is desirable for a second battery because the body has been reinforced in this area and has considerably more structure than the thin wheel well sheet metal found near the firewall in the common second battery location.
As you can see, my 2016 has the reinforced mounting point....
Here are the pictures..
Driver's side reinforced mounting point..
Passenger side picts'..
Old 01-24-2018, 11:15 AM #50
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
I was wondering what you did with the smog pump.....ill take a picture of mine today for clarification.
Thanks
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 01-24-2018, 09:33 PM #51
Thanks
Smog pump goes to the passenger firewall location, with my smog pump bracket, or using the shrockworks mounting system... then one of my ARB compressor brackets go over the smog pump...
For the pictures you quoted above, I just removed the pump for a fit test of the shrockworks battery bracket...
This is my ARB compressor mount over my smog pump bracket (smog pump in back near firewall in center)...
This is my ARB compressor mount over the shrockworks smog pump relocation bracket (smog pump would go under the right side in image)...
This is my ARB compressor mount over the shrockworks smog pump/water reservoir relocation bracket (smog pump would go under the right side in image, water reservoir on the left)......
Old 01-24-2018, 09:38 PM #52
Titanpat57's Avatar
Real Name: Patrick
Titanpat57's Avatar
Real Name: Patrick
You are the master....
Old 01-25-2018, 03:16 PM #53
Real Name: Will
Real Name: Will
Yeah, I'm definitely thinking about moving things around under the hood again. I'm not looking to get a high clearance bumper currently, but I don't want to paint myself into a corner either.
I was originally looking at a Bandi mount but ended up moving my compressor off my passenger-side quick-fab bracket to a Slee bracket on the driver side because I thought either a firewall or front dual battery rig would be incompatible. Moving the compressor back to the passenger side will make driver side electrical bits easier. I can throw my on-board tender and a SwitchPro or SPOD on the Slee bracket.
So, front aux battery means moving the smog pump. Front aux battery and HC bumper means moving smog pump AND reservoir, right? Any downside to just getting the Shrockworks smog and reservoir bracket version for potential future proofing, other than a few bucks extra cost?
Old 01-27-2018, 09:57 PM #54
Yes, if going to a HC bumper, you need to relocate the water reservoir, or it will stick way below in in danger, although i did see a few bumper mfgr's shielding around it, but i don't recall the aesthetics of it being memorable...
If going with the bandi ARB bracket to use in unison with the shrockworks smog pump and water reservoir relocation brackets, then the downsides is you need to mount the bandi bracket to the shrockworks bracket, hence you need to purchase that too... but you could only get the bracket ($95) and get their water reservoir ($258) later, or use a generic one of similar sizing... Although for $25 extra I could make an adapter so you could hold you off of the shrockworks bracket, but like i did do myself, I called them and ordered the bracket for the water pump/smog pump only, with no tank...
Old 02-13-2018, 08:25 PM #55
cutty01 cutty01 is offline
cutty01 will become famous soon enough
Hi Leroy, sent you a PM a couple of day ago, but haven't heard back. I know you get busy so I am posting to the forum in case someone else knows the answers. Cheers!
I have a few questions for you?
1) What is the vertical clearance between your mount that accommodates both the Shrockworks air pump/washer reservoir relocation kits and the 5th gen 4Runner hood when closed?
2) Is there any difference in clearance between the above mount and one of the mounts that works with only the air pump relocated (i.e. washer reservoir left in stock location) or are they same?
Thanks\
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
cutty01 is offline   Reply With QuoteReply With Quote
Old 02-13-2018, 10:33 PM #56
I want to get one of your mounts, but I want to buy one that allows me to make future mods. Eventually I will relocate the air pump using the Shrockworks kit when I go to dual battery and then relocate the washer reservoir if I get a front bumper. But first I want to see if your mount will accommodate one of those cheapo Masterflow MF1050 compressors (rebranded under many other names). Eventually I will upgrade to one of those dual ARB air compressors.
Thanks\
Yep, saw your message... I was busy packing and sending my youngest son off to serve in FEMA Corps for a year.. He flew off this morning...
I'LL COPY MY REPLY HERE BELOW:
Interesting amount of options your looking for, but unfortunately although not impossible, it could be a lot of work....
I do make an option for the ARB to go on top of the... (#4) Shrockworks smog pump kit...
or on top of the...
(#5) Shrockworks smog pump/water reservoir...
I could possible make an adapter at an additional cost (+$25) to go on top of (#5) so that you could use that generic pump laying on its side, however the one you listed has a side air line which would conflict vertically with the hood if mounted on top of one made for the Shrockworks kits.. or even flipped, the line would face downward and be inaccessible... plus i don't have a actual width of the pump to know if it would even fit (no data on web site of real width, it only lists 7.87" which includes the air line/chuck)...
I'm actually doing a similar setup this weekend for someone, although using a Viair 400p. The customer sent me their Viair pump to fab to exactly as there are not enough online specs to build from digitally, and it has a end located air line....
So your questions...
My #4 and #5 compressor mounting plate are positioned vertically within less then a 1/4" off the top of the smog pump, i.e the position of my compressor mounting plate.
This is the same vertical position for either #4 or #5 mounts, however due to height limitations with the hood, #5 is actually offset towards the engine as to clear the shrockworks water reservoir.
Basically, with #4 and #5, and similar to the other versions, the height is limited, even with the ARB the air port on the compressor needs to be rotated to the side 45* and use a 90* fiting to run the air line out to an air chuck location (absolute wits end sells nifty mounting points BTW)...
Now, you were asking for a standalone of version #5 that would install without the shrockworks mount in place, so that can be done, although at an additional cost (+$25) for an adapter to do so...
I mean for a temporary cheap option, as I use my ARM twin/single pumps for fab'g only, so I use the Viair 88p portable in a canvas bag (amazon - Bucket Boss 69000 Cable Bag)... actually, Viair has a full rage of compressor with varying size/air CFM outputs to select from....
I have a outdated version arb mounting plate ($75) which positioned way lower vertically than all my current models, I could pull it from its packaging and see if it would need the dimensions of masteflow height and let ya know...
Let me know....
Leroy (bandi)
Old 02-14-2018, 05:58 PM #57
mechIFR mechIFR is offline
mechIFR is on a distinguished road
Payment would be either...
PayPal/Venmo [email protected]
or
Googlelewallet at [email protected]
Be sure to provide shipping name, address, and email for tracking...
Let me know....
Leroy (bandi)
Hi Leroy - Sent you an couple emails earlier this week. Would like to order a base mount with two options: (1) optional manifold mount and (2) ARB tank mount. Happy to send payment now if easiest for you.
Jim
mechIFR is offline   Reply With QuoteReply With Quote
Old 02-14-2018, 07:01 PM #58
Leroy (bandi)
Thank you for the detailed response and special thanks to your son for his service to help those who are impacted by disasters.
Old 02-15-2018, 06:48 PM #59
Thank You... I'll pass on the thanks' to the Boy... So far he is real excited about the program, he's doing the 1 month at their training facility in MS, then he will be deployed outward... He received $$$ for essentials and also college $$$ for his service.
I work for FEMA myself, so I get to work along side the FEMA Corps "kids" (not supposed to call them kids, but 18-24 years age) and they are a great asset. Anyone can apply, and after and even during, they can possibly get hired on with FEMA full time CORE or as Reservists. It's a great resume topper, plus opens doors to a whole new world of opportunities as they work within all aspects of FEMA, not just one division, and also along with State and Local OEMs.
https://www.nationalservice.gov/prog...ccc/fema-corps
Old 02-15-2018, 06:55 PM #60
Jim
Thanks for the message Jim, I will check my email and see why its not working correctly, or if it dumped you in spam...
Sending PM to get you lined up..
HTML code is Off
ARB Twin Air Compressor Bracket for 5th Gen. jangoforhire 5th gen T4Rs 144 10-14-2020 07:21 PM
ARB Twin Compressor mount underhood? Victor 4th Gen T4Rs 1 04-15-2015 01:16 AM
ARB Twin Compressor BNIB - $450.00 amartin4410 For Sale: Non-T4R Items 2 02-09-2015 04:01 PM
ARB Twin Compressor air tools; which do you use? Okki 5th gen T4Rs 1 06-16-2013 12:35 PM
