4th gen front recovery points, rated to 13,000 lbs/ each
Fit 2003-2009 4Runner, GX470, and 07-09 FJCruiser
Come with 2 recovery points and hardware.
You do have to remove the factory tie downs for use with hard shackles, for 06-09, an angle grinder makes quick work of this.
I do recommend using a bridle to share the load across both frame rails to reduce strain on your equipment and your rig.
$100 shipped
Here's what your 06-09 will look like with OEM tie downs removed.
