Notices
Old 06-02-2019, 01:08 PM #1
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
FS: 3rd Gen Hella Fog Lights $95 Kansas City
SOLD
I have a set of Hella fog lights removed from a 2000 SR5. These were a dealer add-on, and are only compatible with '99-'02 years. They fit in the same location where the factory equipped fogs would be.
Compared to the factory fogs, these produce a stronger light output. (Light output pics and explanation below courtesy of sogoood on here).
These were removed from a midwest truck, so there is rust on the brackets and the black coating is peeling away. The rust is surface level only, so it can be easily sanded and resprayed. The lenses on both are free from any cracks. The hardware is included (not pictured). I would recommend replacing them as they are a bit rusted.
$95 shipped including PayPal fees. SOLD
I can include an optional fog light switch stalk (fits pre '01 models only) for $15 more.
additional pics: 4Runner Hella Fogs - Google Photos
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 06-02-2019, 01:10 PM #2
ToyotaBrah's Avatar
ToyotaBrah's Avatar
Light output pics and explanation from sogoood:
Originally Posted by sogoood View Post
Pictures taken with one Hella DE. Distance from shop is about 1 1/2 car length. The width of the beam couldn't be captured from that distance so it is seen diagonally.
Hellas ribbed/fluted design gives a wider beam pattern like the Rigid Ind DOT fogs, Koitos aren't fluted. Internally there is a cutoff shield. The light intensity depends on what bulbs you have. The bulbs included are PIAA 55w High Intensity. The body is designed for 55w bulbs and can also withstand heat from hid bulbs if you want to retrofit.
Old 06-03-2019, 01:14 AM #3
sogoood's Avatar
sogoood sogoood is offline
sogoood will become famous soon enough sogoood will become famous soon enough
sogoood's Avatar
This is a "Hella" good deal!
dibs on the fog light stalk. ill send you a pm shortly haha
2002 Dorado Gold 4runner SR5 fully loaded/leather/JDM goodies
OME 882 fronts.LC 8 wrap rears/SCS Ray10 17x9" -38 Copper/Falken 285.70.17 P-rated/1.25" Spidertrax/TBU/JDM Hilux Surf Window Visors+LED Spoiler+Power Fold Mirrors/Hilux Surf Corners+Headlights D2S 5.0 x Panamera 2.0/Jaos Mud Flaps/Viper 5901/Blackvue dr750s 2ch/quarter tank of gas
Awaiting install of TrueNorthFab plate bumper and useless cool jdm parts
sogoood is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 01:03 PM #4
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Can you still swivel the foglights up and down and loosen up the screws fastening the foglights to the brackets?
Old 06-03-2019, 02:13 PM #5
ToyotaBrah's Avatar
ToyotaBrah's Avatar
Will check tonight and get back with you!
Old 06-03-2019, 10:18 PM #6
ToyotaBrah's Avatar
ToyotaBrah's Avatar
Sprayed a little Fluid Flim on the threads, and with a 7MM socket, I was able to easily turn the screw. The other way to adjust them is to use the Philips head screw on the front, but my JIS driver still slipped on them. And now that I think about it, when they are mounted on the truck, the only way to adjust them is from the back using a 7MM socket wrench.
I cleaned them up and took a few more pics. I opened up the rubber boots to show the insides as well. The fogs themselves are virtually rust-free. Just the brackets that have accumulated a bit of rust.
Pics in this link:
Old 06-03-2019, 10:33 PM #7
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Sounds good if they still tilt via the main adjuster (the long screw/bolt you put the 7mm onto). I’ll PM you when I get home from work in about 3 hours.
Old 06-04-2019, 12:12 AM #8
ToyotaBrah's Avatar
ToyotaBrah's Avatar
Correct, they still have full tilt rotation. One thing I'd like to point out: On one fog, I noticed when loosening the screw to tilt the housing down, I had to assist the housing a little for it to move. It's not seized, but it will need a little grease on the most inner moving points where the two side bolts mount, which can be achieved when the housing is freed from the bracket assembly. The other fog rotates up/down fine.
factory , fog , fogs , light , output
HTML code is Off
F/S Kansas City: 2001-2002 Tail lights, Front Calipers ToyotaBrah For Sale: T4R Items 3 07-09-2015 07:17 PM
TE's in Kansas City? jpowers 5th gen T4Rs 0 06-04-2010 11:13 AM
Kansas City 08 SR5 V6 4x4 FireEngineer New Members 5 11-04-2009 01:08 AM
kansas city ricnkc T4R Meet Announcements & Info 0 11-25-2003 12:18 AM
Kansas city ricnkc 4th Gen T4Rs 2 10-03-2003 06:57 PM
