Open to trade offers!!
Looking for a sport hood in galactic gray in good cosmetic condition
Full turbo system for v6 4th gen 4runners for sale! What you see is what is included. Aside from 4 exhaust hangers, an exhaust gasket and an exhaust bushing it is all there. I have made a document with the only other needed parts to make this work (basically 40 bucks in those exhaust parts) I have also included links to the fuel pump I used and the piggyback ecu if you go that route. Please understand that if you have a body lift thinks will fit better but it will still work for ones without body lifts. You will have to clearance the radiator support slightly to let the charge pipe fit and to make the overhead console fit. Otherwise all the oil lines, wires, etc are built to the proper length. I also have a box full of charge piping (over 200 dollars in pipe) that is yours if you buy everything. I have a thread not only for how I built everything but also for the piggyback ecu I installed which you can use as a "guide". It does make 4 psi in its current setup. As I mentioned before the only reason I stopped with this project is I'm about to graduate and I have other priorities right now. Trying to offer this for sale so that I don't have to part it out. 1000 or best offer. You could have it running boost in a weekend if you devoted the time to it.
Here is a link to my build thread showing the whole process.
John's Turbo v6 Build
thanks
