Notices
Old 12-13-2021, 11:47 AM #1
ambiguous's Avatar
ambiguous ambiguous is offline
ambiguous is on a distinguished road
ambiguous's Avatar
FS: ICON Delta Joint Tubular Upper Control Arm Kit 4Runner FJ GX Portland, OR
58451DJ - ICON Delta Joint Tubular Upper Control Arm Kit
Used about 10 months/maybe 9000 miles
Price $500 plus shipping/PayPal fees
OVERVIEW:
Take the performance of your 2003-UP Toyota 4Runner, 07-14 FJ Cruiser, GX470 and GX460 to new levels with the ICON Vehicle Dynamics Delta Joint tubular upper control arm kit. All ICON tubular upper control arms are constructed from CNC bent 1026 DOM steel tubing and then powder coated to a semi-gloss black finish for maximum strength and corrosion resistance. ICON upper control arms are engineered with built-in caster correction for optimal alignment specifications and confidence inspiring handling. A main benefit of ICON upper control arms is the potential for increased wheel travel when paired with our extended travel coilovers, this translates into superior performance and ride quality for your Toyota 4Runner or FJ Cruiser.
These upper control arms feature ICON's patent pending Delta Joint. The Delta Joint is a heavy duty high angle ball joint that combines the durability of a ball joint with the performance characteristics of a traditional uniball. While the industry standard uniball does a great job of allowing the control arms of a vehicle to articulate with little bind, they do have an inherent weakness that leaves more to be desired when used in a daily driven application - exposure to the elements. The Delta Joint features a zinc plated housing providing the first layer of corrosion resistance, while a tough grease seal keeps potentially harmful elements out of the inner workings of the joint. Metal on metal construction and a greasable design increase the longevity of the Delta Joint while at the same time allowing for noise-free operation. What makes the Delta Joint unique is that it brings the best of both worlds to ICON upper control arms with features that make it more robust than a uniball, and at the same time capable of greater angularity than a typical ball joint.
KEY FEATURES:
• ICON Delta Joint
• 1026 DOM Steel Construction
• CNC Bent Tubing
• Serviceable Dual Stage Bushings
• CNC Machined Bushing Housings and Sleeves
• Built-In Caster Correction
• Black Semi-Gloss Powder Coat Finish
TECH INFO:
Fits 2WD & 4WD Applications
WHEEL & TIRE FITMENT INFO:
Factory Wheels & Tires: Yes
Aftermarket Wheels & Tires: 17" or larger wheels with max 4.75" back space
KIT COMPONENTS:
• Tubular Delta Joint Control Arms
• Dual Stage Bushing Kit
• Necessary Hardware
ambiguous is offline   Reply With QuoteReply With Quote
control , delta , icon , joint , upper
HTML code is Off
FS: ICON Delta Joint Tubular Upper Control Arm Kit 4Runner FJ GX Portland, OR ambiguous For Sale: Suspension/Wheels/Tires 0 12-13-2021 11:40 AM
