I’d like to just sell face to face - especially for the tire carrier which will be too heavy to ship cheaply. Tri cities area of eastern wa.
Pics:
Imgur: The magic of the Internet
K9 EEZI-AWN MAXTRAX MOUNT SET (2)
$40
This is JUST the 2 mounting brackets - no maxtrax mounting pins (those are sold separately) or Maxtrax boards. You should be able to use these to mount to any roof rack type or a multitude of surfaces.
The MAXTRAX Mount is an ingenious way to mount 2 or 4 individual MAXTRAX to the side or the top of your K9 Roof Rack System. Designed to be used with the MAXTRAX Mounting Pin Set, which are high-quality black nylon and stainless steel quick-release pins (not included). The hole in the top of each pin is compatible with a TSA-style padlock. The mount has a flat back surface, and utilizes one of the included K9 Accessory Adapters to attach to the top of the rack. Set includes (2) mounts.
RAM Pod I Locking Vehicle Mount with 18" Rod and Socket Arm
$20
Sturdy way to mount a tablet, phone, gps, or other device in your rig. Solid aluminum rod inside. Uses the bolt of the front seat and can be bent for proper orientation. If you happen to have a 5th gen 4Runner this is bent perfectly to be the most stable with minimal movement.
Rigid Armor Toyota 4runner (1998-2020) Spare Tire Hitch Carrier
$350
Brand new and never installed. Was waiting to buy a set of new tires and wheels before I mounted this. Going a different direction now.
This carrier will now be released with a additional 2” hitch insert, in order to not loosen up the stock hitch. It carries a wobble free hitch insert and a 2-locking mechanism on the swing arm.
Drop down at 45 Degrees
2” Spare hitch
2000 lbs. rated toggle latch
.5 quick release pull-out pin
Hitch insert wobble free lock
Made from 8120 1/8 square tube
Weighs 35lbs
Max tire size 34”
Holds 100 lbs. arm strength
Works best with a oem 4 1/2” standard hitch or bigger
