Notices
Old 05-05-2019, 02:59 PM #1
caspice caspice is offline
caspice is on a distinguished road
FS 2nd Gen 1990 4-door MARYLAND $4000
Located near Westminster Maryland
GEN2 - First year for the 4-door.
29-years old and has 246k miles on the odometer. Still driven occasionally; mileage will increase.
3.0L 3VZE V6 engine. 5 speed manual transmission / 2H - 4H - 4L transfer case. 4.56:1 Differential Gear Ratio
Air conditioning, Power Windows/Locks/Mirrors, Power Sliding Sunroof, Power rear window, Rear wiper, Tilt Steering Wheel, Rear Heater, Roof Rack, Class I hitch, After-market Radio/CD
Passed Maryland State Inspection and Emissions Testing in 2017.
Put + 11,000 miles since I bought it.
Still Tagged and Insured in Maryland (Tags will be returned to the MVA upon sale of this vehicle).
Has a clean and clear Maryland Title (in my name)
Comes with two (2) keys.
Service, repair, maintenance, upgrades performed over the last year during my ownership:
Timing Belt kit, Water pump, Radiator Cap, Thermostat, Radiator hoses, Bypass Hose, Fan Clutch
Accessory Belts, Vacuum Lines, VSV for EGR, EGR Modulator and EGR Valve, PCV Valve, Battery Connectors, Alternator, Cold Start Injector and connector, Throttle Position Sensor and connector, Fuel Pump, Fuel Filter, Fuel Injector Connectors, Gas Cap, AC Compressor and Dryer, High and Low side valves.
Head Lights.
Horn.
ECU, Ignitor, Coil and coil harness connector, Distributor, Distributor Cap and Rotor, Spark plugs, Spark plug wires.
Exhaust system from manifolds back, new O2 sensor.
Door locks and Ignition lock replaced, Rear window lock cylinder re-key to match.
Heads and Gaskets done at 240,579 miles. Valves Adjusted. Passenger-side Valve Cover replaced. New Exhaust Manifold Gaskets, Oil Pan Gasket.
Had an open Manufactures Safety recall (Campaign # 50N) - R&H Toyota replaced the Steering Relay Rod.
Replaced Front Anti-Sway Bar End-links, Front shocks, Front Upper/Lower Ball Joints. Rear Shocks, Rear Coil Springs, Front Idler Arm.
Front Brake Pads, Passenger Brake Caliper. Brake Master Cylinder, Brake Booster Assembly.
Clutch Master and Slave Cylinders.
Air-lift 1000 air spring kit installed
Coverking Cordura Ballistic Tactical Custom-fit front seat covers; back of seat covers designed for MOLLE pouches.
Carpet Dash Mat
16" Steel Tacoma Rims. Kumho AT51 LT215/85R16 installed in August 2017 at 237,667 miles. Tires have about 10,000 miles of wear - lots of miles left to go.
Also includes the following new replacement parts: Clutch kit, flywheel, rear main seal, Fan Clutch bearing bracket assembly, Alternator Belt, Air Filter. Daystar KT09100BK 1.25" Rear Lift Kit
$4000.00
FS 2nd Gen 1990 4-door MARYLAND 00-0302191357-jpg  FS 2nd Gen 1990 4-door MARYLAND 00-0516181851a-jpg  FS 2nd Gen 1990 4-door MARYLAND 00-0516181853a-jpg  FS 2nd Gen 1990 4-door MARYLAND 00-0618171855-jpg  FS 2nd Gen 1990 4-door MARYLAND 00-0627171843-jpg  FS 2nd Gen 1990 4-door MARYLAND 00-0516181857a-jpg  FS 2nd Gen 1990 4-door MARYLAND 00-0516181854a-jpg
caspice is offline   Reply With QuoteReply With Quote
Old 06-10-2019, 11:52 AM #2
Sent to Auction
clutch , front , maryland , miles , rear
HTML code is Off
Super clean 1990 2-door 93toy Classic T4Rs 9 11-17-2013 12:01 AM
1990 Toyota 4 Runner 2 door-$900? Peak Classic T4Rs 21 03-24-2013 10:58 PM
1990 two door 4 Runner 2003-4x4runner Classic T4Rs 4 01-13-2011 12:38 PM
1990 4Runner 4x4 - 2 Door DaddyOutlaw Classifieds - buy & sell (no commercial ads please) 0 04-03-2010 04:22 PM
1990 2 Door Sport for sale fj55tlc Classifieds - buy & sell (no commercial ads please) 0 01-21-2004 11:47 PM
