Notices
Old 11-04-2019, 12:06 AM #1
daytripstoeurope daytripstoeurope is offline
daytripstoeurope is on a distinguished road
FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras $17K Harrison, AR
Hey all! My name is Jacob.
Located in Harrison, Arkansas. $17000 OBO
PM me for Carfax. T4R is not letting me embed the link. - Sorry for the inconvenience.
For sale is my very unique 1999 Toyota 4runner SR5! This has been a labor of love for me and my Toyota expert Milo who runs the Toyota exclusive Insane Fabrication System shop in Naples, Florida. I purchased this 4runner from him who was selling it on behalf of his good friend who was moving abroad and could not take the truck due to limitations on vehicle age. This was 2 1/2 years ago and I had the dream of making a fully equipped work/pleasure truck that was not only capable but cool. This truck is not perfect and has had its fair share of off-road driving, but it also has been babied and treated with respect.
This truck just made the 2500 mile round trip from Florida to Arkansas while pulling a 4x8 trailer with no problems and ran like a dream. It averaged 14-17 MPG at 65 MPH along the way.
I have changed the oil every 5k miles with full synthetic amsoil or mobil 1 with the appropriate filter as well. I am strict on proactive maintenance as Milo and I both are in the aviation industry and thus look at maintenance through that scope. I have tons of receipts and a pretty good service record on this truck.
1999 Toyota 4Runner SR5
-5 speed transmission
-5vz engine w/ 167K miles w/ 200lb compression cyl 1-6 NEAR PERFECT for a 20 year old truck.
-Aluminum radiator from Champion cooling system in June 2018
-Water pump/ timing belt done at 156K miles in August 2018
-Borla exhaust
-Trd headers
-38LB High torque flywheel from LCENGINEERING w/ offroad clutch -May 2018
-Safari Snorkel
-285/65/16 Tires w/ Aluminum wheels with negative offset for stability and stance.
- FOX remote reservoir shocks w/ TRD front coils and Dobinsons 400LB constant rear coils.
-JBA offroad Upper control arms.
-ARB Front bumper
-Gobi roofrack and ladder
-CBI swingout rear bumper w/tire carrier, gas carrier & side protective bumpers
-Big 3 Wiring Upgrade
-Weather Tech mats
-Weather Tech windows rain deflectors
-Rago Fabrication rear window molle panels
-Ranger offroad ceiling storage net
- JUST COMPLETED SEPT 2019- new aisin injectors, new fuel pressure regulator, new intake manifold gaskets, new NGK dual electrode plugs, new Denso ignition coils, NGK spark plug wires.
-Backup camera
-2XFront 12" Spot lights on bumper VERY BRIGHT
-Rust protection applied to FRAME.
-AP rocksliders with the welding done RIGHT
-Rigid 30" Light bar VERY BRIGHT
-Side shoot LED lights
- 4X rear LED Spot/flood light combo
-Warn 9.5XI 9000k Winch with new motor installed sometime in 2017.
-Dobinsons Drawer setup with front box containing Power supply and space for fridge- We can discuss selling the fridge with the truck.
-120 Volt power through via 600W Samlex Pure Sine Inverter
-12Volt plugs throughout with independent control via the aux battery
-National Luna dual battery system with appropriate circuit breakers and wiring AND northstar group 31 battery as auxiliary.
-ARB compressor w/ 1gallon hidden tank and remote fill chuck behind passenger seat.
-2inch front diff drop mod
-Bud built front and mid solid steel armor
-Remote battery charging posts for easily charging rear aux battery.
My service history: I am sure I am forgetting somethings.
2017
Brake shoes and pads
Front axle oil seals
Rear axle oil seals and wheel bearings.
Legal but dark TINT
AP Rock slider install
Frame was rust protected against the Florida climate using chassis saver.
AC Charged
Dobinsons awning
Dobinsons Drawer Setup
Gobi rack installed
Lighting installed
New Aisin Mass air flow sensor
New warn winch motor
New rear lift struts
New Aisin fan clutch
Redline 75-90 gear oil change in Transfer case and Transmission
New aisin fuel filter
Toyota steering rack sub assembly bearing rebuild.
2018
New redline performance lower control arm bushings in Jan 2018
Rebuilt cv axles with Toyota rebuild kit.
New toyota front and rear main seals- august 2018
High performance clutch and 38 LB flywheel from LC engineering- august 2018
Toyota U joint drive shaft bearing rebuild w/ toyota spider bearing parts.
New Aisin Throttle position sensor
New timing belt, idler, tensioner, water pump and aluminum radiator in august
New AGM fuel pump- October
New aisin clutch slave and master cylinder.
New Denso upstream o2 sensor and downstream AF sensor (California model)
2019
2x new toyota front brake hydraulic line hoses
6X new aisin injectors, fuel pressure sensor, intake manifold gaskets, NGK wires and DUAL ELECTRODE plugs, New denso ignition coils.
New vaccum hoses
Sunroof works w/ new cables and motor and has been rebuilt from scratch, however, I personally do not open it regularly since it has been rebuilt.
Please contact me via PM and we can discuss. Thank you for your time!
Sincerely,
Jacob
FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_3096-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_1910-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-343359d1567806906-fs-3rd-gen-4runner-167k-4wd-5spd-5vz-w-drawer-system-many-extras-k-harrison-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-343361d1567806932-fs-3rd-gen-4runner-167k-4wd-5spd-5vz-w-drawer-system-many-extras-k-harrison-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-343357d1567806605-fs-3rd-gen-4runner-167k-4wd-5spd-5vz-w-drawer-system-many-extras-k-harrison-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-343365d1567807017-fs-3rd-gen-4runner-167k-4wd-5spd-5vz-w-drawer-system-many-extras-k-harrison-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-343366d1567807043-fs-3rd-gen-4runner-167k-4wd-5spd-5vz-w-drawer-system-many-extras-k-harrison-jpg
daytripstoeurope is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 12:28 AM #2
Additional Pictures.
FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0326-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0329-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_2069-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_1981-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0793-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0795-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_2094-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0791-jpg
Old 11-04-2019, 12:34 AM #3
Pictures
FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0852-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_1981-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0820-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0805-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0815-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_1956-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_0802-jpg  FS:3RD GEN 4runner 167k 4WD 5SPD 5VZ W/Drawer system & many extras K Harrison, AR-img_2136-jpg
aisin , front , rear , toyota , truck
HTML code is Off
4Runner Drawer/Storage system bagelsjustbagels General Discussions 41 09-24-2018 11:10 PM
FS in NH: 1996 4Runner 5spd, elocker, many extras. NO RUST clemson4r For Sale: Vehicles 10 06-06-2016 10:09 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
