Notices
Old 11-15-2021, 10:56 PM #1
crazydubman's Avatar
crazydubman crazydubman is offline
crazydubman is on a distinguished road
::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored
::sold::
Hey there everyone,
It seems the time has come to finally move on to something larger for my family camping/wheeling adventures. This is my 1997 4runner that I have had since 2012. It has taken be so many placed its hard to count. From a number of places in the sierra's, to death valley, mojave, Pismo, and most of the national forests in California, and has never let me down. It was with me when I met my wife, moved, and had our first child. It was bone stock when I got it and have put more blood, sweat, and tears into it than I care to admit.
All in all, it is a great vehicle that will take you to some amazing places and allow you to make countless more memories along the way.
Looking for $17,000 (Price Drop) obo. Lots more into it as with everyone's build but need to start somewhere. Let me know if you have any questions and thanks for looking.
Build specs and info
1997 Toyota 4runner Limited
3.4 - 182k miles
Auto
4x4
Factory E-Locker
- Head gaskets, water pump, timing belt done at 158k when I bought it
- Radiator replaced around 165k with new along with all new OEM coolant hoses including rear heater hoses under cab
- LBJ's replaced with OEM units - 179K
- Starter solenoid rebuilt with OEM components - 181K
- Catalytic convertor replaced 2/20 with Cali compliant unit – 181K
- O2 sensors replaced 2/20 with Denso units – 181K
Modifications…
Suspension:
Front:
- SAW Tacoma extended travel 2.5" coilovers
- Camburg Upper control arms
- Swaybar removed
- Whiteline Lower Control arm bushings
- Total chaos Alignment Cam tab gussets
- Total Chaos spindle gussets
- Total Chaos upper control arm strut tower gussets
- EIMKeith Lower control arm reinforcements (still need to be welded in but will go with 4runner in sale)
Rear:
- SAW 06 4runner extended travel 2" shocks (25" extended)
- OME 861 springs
- Swaybar axle side 1" offset brackets installed to allow swaybar not to hit elocker guard at lift height.
- Daystar Comp 4.5" progressive bump stops
- Control arms and panhard 1.5x.250 wall heims and Johnny Joints.
- Limit Straps
- EIMKeith Panhard relocation brackets
- EIMKeith Frame side Lower link mount reinforcements
- EIMKeith Upper axle side link mount reinforcements
Wheels and Tires:
- SCS STEALTH 6 - 16x8" - 3.5BS
- Goodyear MTR/K 315/75/16 – Plenty of tread left
Drivetrain:
Front:
- 4.88 Gears
- Trutrac LSD
- Lotus Development CV's (possibly have a couple spare boots that will go with sale will need to look)
- Wheelers offroad Poly steering rack bushings
- 1" Revtek diff drop
- Factory breather
Rear:
- Factory E locker
- 4.88 Gears
- Extended Breather with filter (Mounted inside rear quarter panel)
Engine and Performance:
- B&M 70266 Trans cooler
- Boyle Future Technologies Hi output alternator (roughly 80A at idle/140A peak)
Brakes:
Front:
- Tundra 231mm 13wl brake upgrade
- Wheelers offroad Stainless brakelines
Rear:
- Toytec 4" extended brakeline
Lighting:
- OEM 2001 Headlight and front corner marker light swap
- Hella 80/100Watt H4 halogen headlight bulbs
- Hella Micro DE projector fogs with 100W Hella H3 bulbs
- VisionX “Horizon” 12" 40 degree flood LED light bar
- LED replacement taillights with 7W Cree back up lamps
- Maxxima Lighting M09300Y LED turn signals
- Daystar Switches
- Blue Sea 12 fuse, fuse block
- Blitzpro 6" smoked LED rack lights (perimeter lighting)
Interior/Electrical:
- 2001 4runner sport beige cloth seats front and rear excellent condition. No tears or rips and bolsters still good (Swapped from original leather as the drivers was getting worn and wanted something that held you in place better. Also wanted the factory child seat restraints on the back seats.
- Kenwood V71A 2M/440 Ham radio
- Kenwood SP-50B External speaker
- Diamond NR-770HB Antenna
- Kenwood CD player
- LED dome, map and cargo lighting
- Custom HPDE rear cargo floor with Tie downs
- Raingler Cargo net dividing cargo and passenger areas
- Weather tech floor mats or OEM, can’t remember
Exterior / Accessories:
- Whitson Metalworks full length roof rack
- Clearanced front fenders and molding to clear tires at full stuff and lock
- Tubbed firewall and inner fenders to clear tires at full stuff and lock
- Relocated washer fluid reservoir for tire clearance
Armor / Protection / Recovery:
- Addicted Offroad front bumper
- Addicted Offroad Rear bumper Custom modified for additional ¼ panel and taillight protection and tire carrier by Any7Offroad
- Demello Offroad Sliders for 06 4runner (3-4" longer than normal)
- Milemarker 9000 winch
- 60" HiLift jack with mounts on roof rack (will include with sale)
- Any7Offroad Synthetic winch line
- Any7Offroad Aluminum fairlead
- Any7Offroad Gas Tank Skid
- Any7Offroad IFS and belly skids
- "The Source" 10lb CO2 sport series tank with 30ft hose and mount about half full – Mount shown in picture of cargo area (Possible throw in with sale for right price)
Have some trail spares as well
Used but good condition OEM lower ball joints (Changed them out to be proactive but saw no play and joints are still tight)
New OEM outer tie rods
CV axle Possibly a boot kit but would have to check.
Build is in great shape but is by no means a show queen. It does have clear coat peeling on the hood and a small amount on the top of the rear hatch.
The fender trim is fading in areas as well. If you have gotten this far into reading this post then hopefully you understand that. It runs solid, no leaks, AC blows cold, and all controls work. Its a solid wheeler/camping rig that will take you pretty much anywhere a non caged full bodied vehicle should go and some places you shouldn't in comfort.
Pictures
::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_e9838-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_e9836-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_e9839-jpg
Todd:
1997 4runner limited - crawling/camping
http://www.toyota-4runner.org/3rd-ge...ner-build.html
crazydubman is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 11:05 PM #2
Some pictures of the current condition.
::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9966-1-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9967-1-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9968-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9976-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9978-1-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9987-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9988-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9989-jpg
Todd:
Old 11-15-2021, 11:50 PM #3
More pictures
::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9991-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9992-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9993-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9995-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9996-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9997-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_0002-jpg
Todd:
Old 11-15-2021, 11:53 PM #4
More pictures
Skid plates were pulled to clean and get pictures of frame and skid plate braces. All but the gas tank skid were pulled and re painted satin black before being reinstalled.
::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_0014-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9969-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9970-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9971-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9972-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9973-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_9977-jpg
Todd:
Old 11-24-2021, 06:38 PM #5
cynnko cynnko is offline
cynnko is on a distinguished road
Hey dubman, is this still available?
I'm in Westwood and would like to check this car out for a test drive.
cynnko is offline   Reply With QuoteReply With Quote
Old 11-24-2021, 07:01 PM #6
yes 4runner is still available.
Shoot me a PM and we can discuss further from there.
Todd:
Old 11-24-2021, 07:51 PM #7
I can't seem to PM anybody, maybe it's because I just registered.
If you can send me an email at cynnko at protonmail.com we can talk over there.
Old 12-09-2021, 07:48 PM #8
Bump with a price drop.
Todd:
Old 12-09-2021, 08:03 PM #9
Here are a few more pictures that I missed adding originally. (Skids, hood, firewall tub, front suspension reinforcement)
::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_1276-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_1277-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_1319-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_1320-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_1311-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_1278-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_1295-jpg  ::SOLD:: FS: 3rd Gen 1997 Limited 4runner Built/Locked/geared/armored-img_1296-jpg
Todd:
Old 01-02-2022, 11:40 AM #10
Bump
Still available
Todd:
Old 01-05-2022, 11:48 PM #11
patrick28x patrick28x is offline
patrick28x is on a distinguished road
I sent you a visitor message. I am interested, can you PM me contact number. Thanks, Patrick
patrick28x is offline   Reply With QuoteReply With Quote
Old 01-06-2022, 03:31 PM #12
Hi Patrick,
Just sent you a PM on instagram. I have the same screen name "Crazydubman"
Todd:
Old 01-12-2022, 02:42 AM #13
::sold::sold::sold::
4runner is heading down to Irvine for a new life of wheeling and family trips.
Thanks for looking.
Todd:
4runner , any7offroad , front , oem , rear
HTML code is Off
JWaldz '99 Adventure Build - Dual Locked | Geared | Mid-Travel | 35s | Armored JWaldz 3rd gen T4Rs 1032 06-28-2020 04:21 PM
FS- Exp built Armored,Lifted,Geared and locked 4th Gen 141k $21K NYC,Upstate,Bos Nyc-Runner For Sale: Vehicles 12 03-23-2017 11:45 PM
1994 4runner 35's - geared - locked - armored $4999 Jonny Fresh For Sale: Vehicles 0 08-04-2014 04:08 PM
1999 4Runner limited, locked, armored on 35's mikgrail3 Classifieds - buy & sell (no commercial ads please) 12 10-05-2009 09:36 AM
FS: 1997 4Runner SR5, Lifted, Locked, Geared. CHEAP. $6k gapguy Classifieds - buy & sell (no commercial ads please) 7 10-17-2005 10:17 AM
