Old 12-23-2021, 03:35 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Internal pics of 3rz-fe with 178k miles (normal wear?)
Edit: Because of a TOS update with the image host I originally posted these photos on, the photos were set to get removed. Luckily I reuploaded them here, but the original order might not be the same. Your lucky your viewing them, going back through all my posts has been a pain in the ass and this is the last one.
I removed the exhaust camshaft on my 3rz-fe because of complications during a valve adjustment. I was going to post this on the main 3rd gen sub-forum, but decided against it.
I'm posting these because I'm wondering if this is a normal amount of wear for an engine with 178k miles and 23 years. My guess is its slightly below average in terms of condition for an engine with this mileage, judging by varnish and wear patterns on cam lobes and bearings, but I don't have much to compare to.
The front bearing cap is still installed because as you can see the service bolt wont let me clear it. In one of the photos you can see a valve lifter is missing, this is because I cracked it on the cam and will replace it.
I should of taken photos of the bearing caps, maybe later. I had them in containers. If there are any photos that anyone wants for reference, I'd be happy to provide them while I have my engine apart.
I'm leaving out some photos because I took an absurd amount which are mostly duplicates. If you want to view the whole album you can find it here (if broken the updated link is in the first paragraph).
1998 4runner 2.7 manual
Last edited by Pyral; 05-16-2023 at 03:16 AM. Reason: Maintaining photos (linkrot)
Pyral is offline   Reply With QuoteReply With Quote
Old 12-29-2021, 09:56 PM #2
ZSW99 ZSW99 is offline
ZSW99 is on a distinguished road
Looks pretty good to me. The only 3rz I’ve taken apart was over 350k miles when I opened it up and it had a little more varnish on the cams and on the surfaces of the heads. Mine looked like it had maybe more wear on the cam lobes than yours does but the bearing surfaces looked similar. I made the same mistake with the bolt in the gear blocking the bearing journal. Just clean everything and reassemble it with some oil when you put it back together so it doesn’t run dry on start up
ZSW99 is offline   Reply With QuoteReply With Quote
bearing , cam , engine , photos , wear
Rear brakes wear down before front? 37K miles Peakbagger 5th gen T4Rs 34 05-08-2022 06:29 PM
Spark plug concerns? Normal wear?? zguy1 4th Gen T4Rs 9 12-08-2020 09:27 PM
Rear Brake Pad Wear - Normal? JayceeP 5th gen T4Rs 1 08-31-2014 09:22 AM
Brake Show Wear, normal ? Lug1 3rd gen T4Rs 0 12-26-2013 03:10 PM
Wear on spark plugs pics Aquabear 4th Gen T4Rs 1 03-15-2012 09:06 PM
