Originally posted by NCSCOTT
That suspension kit is not compatible with the X-Reas shocks correct???? Your were required to get longer travel shocks right??
Thanks
You will need to disconnect the x-reas to install the OME or any upgraded suspension lift or shocks. Yes, it is both the coils and shocks. If you ever plan to be around the Winston-Salem area hit me up and you can take it for a spin to compare the differences with the x-reas. However, the way I understand it, the x-reas has no or negative benefits in off-road applications.
The first thing I noticed with the OME, while still running the stock tires, was that it tightened up the ride all around very nicely. Not harsh at all, but just much more responsive to driver input. Most of my vehicles in the past have been 4x4 vehicles with firmer shocks, the last was a Tundra w/ the TRD package, and the soft stock shocks felt like a minivan to me!
As mentioned in a previous post the nose-diving when braking and body roll in the turns was greatly reduced. Off-road the benefits are even more easily noticed. My personal opinon is that you will have a better ride with the OME and no x-reas vs. x-reas by itself or with a spacer lift.
Hope that helps!
