Thread Tools Rating: Thread Rating: 11 votes, 4.64 average. Display Modes
Old 01-13-2018, 12:58 PM #376
Alaska_4Runner's Avatar
Alaska_4Runner Alaska_4Runner is offline
Alaska_4Runner is on a distinguished road
2012 SR5 Premium
@harper7 awesome build, subscribed!
Do you have a the part numbers for your conversion?
Thank you, looking forward to seeing more.
Originally Posted by harper7 View Post
I will get a sheet together with the part numbers but I don't know the price of them. I'm guessing over $3000+ as the last order they showed me with 12 parts was $1700.There are 30 parts,close to 100 plastic attach clips and I had to fab my own bumper attach brackets out of stainless as the Limited/SR5 ones are different and sit lower.They could'nt find the part numbers for the brackets as the bumpers come as an assembly and different part numbers.
Thanks guys, It turned out to be way more of a headache then I ever expected and I've done a frame off restoration on a 70 RS/SS Camaro before. Mainly because it takes so long to get parts from Japan and nobody knew what and how many parts it involved.
2012 SR5 Premium Magnetic Grey: KING Shock Coilovers with res // Total Chaos UCA & rear link kit // GOBI Stealth Rack + Rigid Industries lights // sPOD & Source System // 2014 TE Rocker conversion // C4 Fab Rock Sliders // Bandi mount w/ARB Twin Air Compressor & Rear Locker // Pelfreybilt HWM w/ WARN ZEON 10-S Platinum
Alaska_4Runner is offline   Reply With QuoteReply With Quote
Old 01-22-2018, 01:06 AM #377
bradhannon bradhannon is offline
bradhannon is on a distinguished road
I took the Metra dash adapter for my Pioneer out and made the cutouts for the antenna motorized mount switches,hole for the air gauge and a drilled holes for a 8 inch long rod that I use to hang my Samsung Tab 7.7 tablet as it has a book cover case that works perfect and the rod is also good to hang my Midland CB so I can just hit the button and talk.
Here's pics after the completion and all back together.
And here's with my tablet in place and tethers wirelessly thru my rooted Android phone app and the sound goes thru the Pioneer Z120BT with bluetooth.
I put in glow in the dark mic holders for the Kenwood mic and the Midland 75-822 CB
I also recently swapped out my BajaDesigns Stealth 40" LED bar for their newer and more powerful OnX 44 bar
A couple of months back I also upgraded the rear lower control arms to Metaltech's offset ones and the springs to Toytec Superflex springs.
Height difference between my old SAW's and the Toytec rear springs..... about a 1/2" gain and a little stiffer.
Rear lower control arm comparison of stock vs. Metaltech's....probably twice as strong!
What rod did you use for your tablet? Is it custom?
Sent from my Pixel 2 using Tapatalk
bradhannon is offline   Reply With QuoteReply With Quote
Old 03-07-2018, 04:41 PM #378
skratchd's Avatar
skratchd skratchd is offline
Real Name: John
skratchd is on a distinguished road
skratchd's Avatar
Real Name: John
Well my new gears and lockers arrived yesterday. I've been wanting and waiting to do this mod for a long time.I think it will really help with the lack of low end torque on these 5th Gens, especially with the bigger tires .
I got the front clamshell and 3rd member already built up and regeared with 4:56's/ ARB lockers F&R from East Coast Gear Supply.Just have to swap them out,hopefully this weekend and run the air lines down to them.
Anybody with a hint of mechanical aptitude should be able to do it in your own garage.
I also finally completed my fog light HID projector retrofit last weekend and the Vision-X Tantrum rock light install a couple of weeks ago. I'll have pics up when I get a chance but real happy with the outcome.
Here's some pics of the Gears and Lockers ......
Rear 3rd member with the new 8.2" 12 bolt Nitro 4:56 and ARB RD193 Air Locker
Front 8" clamshell with Nitro 4:56 and ARB RD121 Air Locker
Out with the old and in with the new! V
CV axles out and ready for the front clamshell V
Rear third member with 4:56 gear and ARB RD193 locker V
Cleaned out with a new gasket and ready for the new rear diff V
Axle pulled out just enough to install the Diff V
Locker Solenoids
Did you have to lift the motor to get the clamshell out and in?
skratchd is offline   Reply With QuoteReply With Quote
Old 10-25-2022, 04:45 PM #379
SHAKEnBLAKE SHAKEnBLAKE is offline
SHAKEnBLAKE is on a distinguished road
Just the flares were going to be painted silver.I originally thought the side flares from the Limited and Trail were the same with the exception being the Limiteds were painted body color.
Not the case. They are completely different in shape and texture.The Limited are smooth and the TE's are sort of pebbled or textured look.They don't mix.
I know it's been years, but I'm thinking of a trail front bumper swap. Do you think if I had the side flares from the trail bumper painted (black) to color-match my stock smooth SR5 flares it would look too weird? Alternatively, anybody know if they ever made smooth ones?
Also, I know you modified the mounting brackets to get the trail bumper on, but I haven't seen anyone post pics or an in-depth explanation of the mods needed. Any tips/details in that department?
SHAKEnBLAKE is offline   Reply With QuoteReply With Quote
Old 10-30-2022, 10:23 PM #380
Photobucket
Does anyone know if the SR5 lower grill would fit in that spot where the round fog lights are?
Also, do I really HAVE to change the fender liners? Can I get away with just the front bumper cover and the bumper-mounted flares painted to match my SR5?
Old 01-14-2024, 09:08 PM #381
jcrana0088 jcrana0088 is offline
jcrana0088 is on a distinguished road
nice mods. what tires are you running?
jcrana0088 is offline   Reply With QuoteReply With Quote
