Old 04-06-2005, 09:24 AM #16
lee's Avatar
lee lee is offline
lee is on a distinguished road
lee lee is offline
lee's Avatar
fyi, [img] tags are not html.
its forum code that changes into html
2006 4Runner Sport 4wd
XREAS
JVC kw-nx7000 head unit
lee is offline   Reply With QuoteReply With Quote
Old 04-06-2005, 10:30 AM #17
20054runnerfan's Avatar
20054runnerfan 20054runnerfan is offline
20054runnerfan is an unknown quantity at this point
thanks for the heads up...
2005 Black SR5 4 Runner
Current Mods:
Front Windows Tinted 20% Rear 5%
Viper 791 Installed w/remote start
Alpine Alpine IVA-D310
Alpine Nav
Harmon Kardon Drive and Play
MB Quart PSD 216 6.5 Front
MB Quart PSD 216 6.5 Rear
MB Quart Premier 4" in the dash for Center channel
JL Audio 300/2 for front
JL Audio 300/4 for front and rear
JL Audio 1000/1 for subs
3 JL Audio 12W6V2s
Alpine PXA -701
LCD's in the front head rests
20" Zink Monza Black
265/50/20 Nitto 420S
Jason Burtman Black Heads and Tails
http://www.cardomain.com/ride/2035120
20054runnerfan is offline   Reply With QuoteReply With Quote
Old 04-29-2005, 02:18 AM #18
Bill42's Avatar
Bill42 Bill42 is offline
Bill42 is an unknown quantity at this point
Bill42's Avatar
I am just going to attach this info at the end of this sticky thread. If you have a Mac (search Apple) then to post an avatar and photos do the following.
Avatar: Maximum size is approx. 13,000. Open iPhoto. Select photo. Go to File. Select Export. It is automatically set to 3:2 ratio. If the photo is landscape then 140 goes in the width box. The height box will automatically size to the correct ratio. If the photo is potrait then enter the 140 in the height box. The width box will adjust accordingly. Save to desktop so you can find it. Click on the file on the desktop and hit File then Get Info to double check the file size. If too large then use a lower number than 140. Go to t4r.org homepage and go to User CP and choose Edit Options. Go to bottom and select Change Avatar. Locate saved photo on desktop and your Avatar is set.
Photos: Maximum size is 140,000. Easiest way is to follow the above Avatar example except instead of using 140 use 750. Again the other box will adjust accordingly. Also, double check file size. Adjust 750 down if the file is too large. Attach photo at end of Post Reply.
That is it. No aftermarket photoshop software, etc. necessary. Just iPhoto. Hope this helps.
2005 4Runner Sport Edition 4WD V-8 Salsa Red Pearl. Bridgestone Dueler Revos - 265/70/17. Hanna Quality Sliders.
Bill42 is offline   Reply With QuoteReply With Quote
Old 06-09-2005, 12:11 AM #19
Fakie's Avatar
Fakie Fakie is offline
Fakie is an unknown quantity at this point
Fakie's Avatar
ARGH! What is the deal? It won't let me change my avatar. I've tried resizing it with photoshop many many times, making the pic smaller and smaller and still it tells me the pic is too big. I took the above poster's advice, because I do have a mac, and it still didn't work. It is a photoshopped file, could that have something to do with it? What do I have to do? Sorry to bring an old thread back from the dead...
2005 Galactic Gray Sport V6/2WD
Fakie is offline   Reply With QuoteReply With Quote
Old 06-09-2005, 01:26 AM #20
Bill42's Avatar
Bill42's Avatar
I think I know what you are doing. The size of the avatar photo is not 140,000. This number is the size of the full photo in the body of the thread. The avatar photo is only approx. 13,000.
I sized the Avatar to 140 x 93. I just kept guessing until I found a ratio that worked. However, you may have to adjust the 140 up or down depending upon file size.
I can't help you with photoshop but the file size for the avatar must be approx. 13,000.
Hope this helps. If not, search "photoshop" and see if another member has been able to do it.
Good luck. BTW, if you do find out how to do it please add it to this thread. Thanks.
Old 08-30-2005, 04:05 PM #21
4x4 V6's Avatar
4x4 V6 4x4 V6 is offline
4x4 V6 is an unknown quantity at this point
4x4 V6's Avatar
checking to see if this works
2003 Limited 4 Runner
Black, V6, 4WD with Navigation System
275-55R20 MB Motoring Vapor Wheels Chrome
275-55R20 Falken Ziex S/TZ-04 Tires
Borla Cat Back Exhaust p/n: 140036
Full Size Bra
http://photos.yahoo.com/yotagene
4x4 V6 is offline   Reply With QuoteReply With Quote
Old 08-30-2005, 04:08 PM #22
4x4 V6's Avatar
4x4 V6's Avatar
Re: checking to see if this works
Originally posted by 4x4 V6
try try again....let's see if it works now:
Full Size Bra
Old 04-18-2006, 08:09 PM #23
leesdawgs leesdawgs is offline
leesdawgs is an unknown quantity at this point
seeing if it works...
13' 4x4 4Runner SR5. Silver
05' 4x4 4RUNNER SPORT. Sold... Upgrades: Sunroof, smoke grey leather seats. Modifications: WAAG brushgaurd, KC lights, folding hitch-mounted deer rack, Sirius satellite radio, Sony head unit, Sony 6x9's, Sony 6.5's, Sony tweeters, Sony 1200w ten" in custom box, two Sony Xplod amps, Volant CAI, NGK Iridium IX plugs, Flowmaster exhaust, no tip, cornfed 3inch lift, Spidertrax spacers, custom dark red calipers, original 17" Toyota wheels, 285/70/17 Cooper Discoverer STT's, ceramic pads all around, Husky floor liners throughout, custom VVTI V8 logo on hatch
leesdawgs is offline   Reply With QuoteReply With Quote
Old 04-18-2006, 08:10 PM #24
try this
Old 04-18-2006, 08:10 PM #25
thanks guys
Old 04-25-2006, 11:03 AM #26
MnRunr MnRunr is offline
MnRunr is an unknown quantity at this point
just testing, my first time
MnRunr is offline   Reply With QuoteReply With Quote
Old 05-22-2006, 11:02 PM #27
cphair cphair is offline
Real Name: Chris
cphair is an unknown quantity at this point
Real Name: Chris
Picture Test
Just checking to see if my pictures attach correctly.
HELP!!! (Posting Pics_-dscn10140001front-view-jpg
2014 Trail Edition
Gone... But Missed:
2004 Sport V6 - Stratosphere Blue, Gibson Exhaust, K&N Intake, Cornfed Lift, P285/70TR-17 Bridgestone Dueler A/T Revo Tires, JAOS Skid Plate
cphair is offline   Reply With QuoteReply With Quote
Old 05-23-2006, 12:15 AM #28
Bill42's Avatar
Bill42's Avatar
Outstanding in blue with the revos...!
Old 08-10-2006, 11:12 PM #29
clem18's Avatar
clem18 clem18 is offline
clem18 is an unknown quantity at this point
clem18's Avatar
Need to test if it works. Thanks
[IMG] http://images.kodakgallery.com/photo...9305_0_ALB.jpg [/IMG]
clem18 is offline   Reply With QuoteReply With Quote
Old 08-10-2006, 11:20 PM #30
clem18's Avatar
clem18's Avatar
Again...
Updated Pics: 2005 4Runner Mark86 Gallery 9 06-28-2018 07:17 PM
Updated pics w/ mods alpha Gallery 3 02-04-2006 11:38 AM
Please refrain from uploading pics unrelated to the T4R GatorGreg Gallery 6 01-28-2005 11:02 AM
How to submit pics chunderboy Software Related Questions & Answers 4 01-03-2005 02:15 PM
